Question about Microwave Ovens
LG microwave oven MB1142DP isn't turn on, display and interior lamp off
Main power cable, fuse and interior connections checked and ok. Display is off, voltage at input power connector of the Electronic board is ok, but there is no voltage at output connector. I need the service manual about LG microwave oven MB1142DP
Check for the schematic diagram and troubleshoting guide, using model information.
By example:
www.google.com
type the model and Search buttom
pdf files appears..
good luck..!!
Richard / Guatemala
Posted on Jan 03, 2011
  • Microwave Ovens Master
  • 9,098 Answers
We repair these on a regular basis for customers nationwide with our guaranteed $39.95 service.
Details of the service plus *critical* safety, disassembly, and troubleshooting info is at our site, which is linked at our
listing here on FixYa: http://tinyurl.com/yzjozk
Posted on Nov 18, 2007
Unit has no power nor is display lit up. Have power to cord. tripped breaker. is there an internal fuse behind control panel
Microwave ovens have an internal fuse to protect the unit. Once you remove the white cover it is easily located on a board where the main power cable first goes into. Despite what you hear about dangerous radiation generated by microwave it is sage to turn on the microwave with the white cover off because the radiation stays within the microwave cavity. If you buy pass the door interlock then you may be exposed to some radiation escaping from the door opening. No match can go wrong in a microwave. Usually its something simple like a bad connection a burned fuse .or a burned power supply if it is microprocessor based unit.
Mar 05, 2015 | Microwave Ovens
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
LG microwave not working fuse is ok
The cable is ok? is the cable plugged in in a socket, with live power? check with a little lamp.
No wire lose in the plug that goes into the mains?
Jan 23, 2015 | LG Microwave Ovens
The microwave doesn't work at all. no display, light, anything
Plug a lamp in the wall receptical in place of the microwave oven, if okay! it means the main fuse in the oven has blown. There are a number of reasons why this happens, a bad fuse, door switch that has malfunctioned, "common" cracked high voltage diode, shorted capacitor, and an open magnetron. I suggest a professional.
Mar 09, 2012 | Panasonic Microwave Ovens
THERE WAS APOWER PROBLEM AND MY MICROWAVE COMPLETELY STOPPED WORKING.NO DISPLAY AND NO SIGN OF AN OUTPUT
Check the main fuse inside the oven on the floor of the cabinet near where the power cord enters.
I believe you will find it needs replacement.
May 27, 2011 | LG Microwave Ovens
Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
Jul 25, 2010 | GE Microwave Ovens
Fans and lights don't work on our Advantium sca2000bbb. Display does. The main fuse is OK. Is there another?
Some relays must have got stuck open. Check the following schematic. You should check the Main relay, RY14 and RY15 for lamps and relay RY6 for the fan.
http://www.microwavedisplay.com/advantium_sca1000_sca1001_sm.pdf
For your own safety, always make sure you are working safe. Microwave units can be very deadly. Consult an expert if in doubt.
Jan 04, 2010 | GE Advantium SCA2000B Microwave Oven
Microwave is not getting power
may i please ask you if you have a meter? check that 120 volts is going in? check the buttons that you press. also check the fuse check the mains cable for any breaks. also you may want to test the display to see if any power going in?
Apr 07, 2009 | Maytag MMV4205 Microwave Oven
No power to Panasonic NN-S252 microwave oven
follow the incoming mains lead into the microwave their is a small pcb with a fuse their check this first
Nov 14, 2008 | Panasonic NN-S254BF Microwave Oven
Kenmore microwave
If you jump power from the two ends of the fuse with a wire, does it work at all? Also, it may be that the control panel is just out, at least the display panel. If you open the door will the interior light turn on?
Aug 13, 2008 | Kenmore 63793 Convection / Microwave Oven
Microwave Ovens Logo
218 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
