Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Wireless Laptop and Wired Desktop cannot communicate
Need to have wireless laptop and wired desktop share files and laptop to be able to use printer that is direct connected (usb) to desktop
    Genius:
  • 1,269 Answers
Simply printer sharing should be enabled on both computers as well as file sharing.
Helpful Links
Printer Sharing
Posted on Jun 25, 2009
Im trying to set up wired computer desktop to share my new s605 to my sons laptop wireless...do i need to use the CD enclosed with the printer and put it in my sons laptop to install the printer on his...
Yes you need to setup the printer as a shared printer using the printer driver CD.
Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer.
Please click on this link and follow my instructions to setup the shared printer.
http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Jun 03, 2011 | Lexmark Interact S605 All-in-One Color...
How do I set up the Linksys 54G router so that I can access my wired desktop from my wireless laptop and visa versa? Thanks. Fred
Are you asking about sharing files between the 2 systems? if so, no action is required on the router. you need to setup both computers to share files. see this link: http://support.microsoft.com/kb/304040.
There is another option. www.teamviewer.com has a program that actually lets you view the desktop of the other system. This works anywhere in the world. Allows you to share files. And best of all, it's free for personal use.
Either option works, but you do not need to change anything on your router.
Oct 27, 2009 | Linksys Wireless-G WRT54G Router
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Can't share files/folders between networked computers...
I can answer this but I'm kinda winging it so you will have to figure some of this out for yourself.
By default, XP does not let you share your data over the network. Go into folder properties and enable simple folder sharing.
Go to control panel/network and enable file and printer sharing for your network adapter. Reboot and go.
Mar 31, 2009 | Datamax Power Supply (120 VAC with Power...
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Connection problem
The first thing to check is that both of your computers are assigned to the same workgroup name. Right click 'my computer' and select properties. Change the workgroup name so that they are identical on both machines. You will need to reboot if you change the name one one or both of the machines.
Jan 01, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
File Sharing with Home Network...only one pc talking
The message for an unplugged network cable, means you have enabled wired network, but the cable isn't there. No problem if you are connected wireless.
To be able to access files on computers over your network, you need to enable filesharing for the desired directories or disks.
Right-click the directory or disk, go to sharing and set the correct settings. Maybe you have to allow for network sharing the first time.
Please post some feedback
Apr 22, 2008 | Dell Inspiron E1505 Notebook
Trying to network xp pc to wireless laptop
Right click on the drive you want to share. Ex: C:\Vol-xx = name. In the pop up window click Sharing & Security. This needs done to all the drives you want access too. To share a printer. Everyone must have the printer drivers installed. The Pc that has a direct connection to the printer must also Share the printer on the network. Open Printer & Faxes, highlight the printer you want to share. Click File than click Sharing follow windows instructions.
Small suggestion regards to the wireless side of the network. Suggest you setup security so others close too you can not tap into your network. (common).
Feb 14, 2008 | Linksys Wireless-G WRT54G Router
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
344 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
