Question about Crane Penguin 1 Gallon Humidifier
Not working correctly
I got my humidifer last year for my office. It worked just fine and I when I turned it all the way up I would be able to see the moist air blowing from it. But I plugged it into and nothing. It does not seem to be making any noise, but it is blowing "air". What should I do?
  • 2 more comments
  • carterj1018 Dec 09, 2007
    Our penguin humidifier worked great for about a month and then stopped blowing mist. The air blows but the water level never goes down. I cleaned it but I can't get it to work.
  • BillyFive Dec 09, 2007
    I have the same problem, it was working for a good hour on high (where it would blow a cool mist) then it stopped with the mist and now just blows air. I can't tell if it is even working.
  • Anonymous Jan 31, 2008
    I had the same problem. Worked on High and then stopped working. I am not even sure that it was blowing air. I am on my second penguin humidifier. I hope that this one will last longer than 2 months. Has anyone gotten there to work again. I even cleaned it and it still didn't work. hope someone can come up with a solution
  • Anonymous Mar 08, 2009
    We've had ours for about 3 months. Yesterday it stopped making the "mist" and only blows air too.
    Problem Solver:
  • 7 Answers
It could be a problem with the water level sensor. It may have gotten stuck, and is unable to correctly sense the amount of water. I just posted the instructions from the manual here.
Posted on Feb 12, 2008
I had my humidifier for almost 1 year. I did not use it over the Spring and Summer months. I started using it again about 2 weeks ago. I set it up with water turned it on and but morning it had leaked...
Call the manufacturer with your information. They will more than likely need proof of purchase (your old receipt) and you will have to pay shipping if the warranty is still valid.
Dec 15, 2014 | Air Innovations Ultrasonic Digital...
My forced air central humidification system does not work
you need tocheck for power at solinoid valve or continuity of valve where water enters the unit. THe furnace must be on and humidistat calling...
Mar 12, 2009 | Humidifiers
Aprilaire 560 not keeping contant power to cause humid. to work
You may be havig problemm w/ the current sensing relay, try bupassing the current relay and see if the hum. comes on and if it comes on the try rapping the wite wire from the main blower 2 times. hope that helps
Feb 02, 2009 | Aprilaire 550 Humidifier
Continous water flow on a 1042lh humidifer
theholts220 - Sounds like they needed to install a bit larger transformer . You can also buy a A 50 Sensing relay that attaches to the wires for your motor and when you turn on the furnace it will allow the power to go to the humidistat. Very strange though they do not use a lot of power. Check and make sure the wires are not pinched or touching metal somewhere.
TLuzzo - The humidistat seems to be working when you turn it down. The wires for the solenoid should be hooked up to your furnace circuit board. The instruction manual will tell you where. If you dont have a spot on your circut board the A 50 sensing reley is they way to go. They are inexpensive
Jan 24, 2009 | General Filters 1042-LH Humidifier
Aprilaire 600: water only runs in "Emergency" Heat mode
When your unit is on normal the outside unit works and the inside only the fan runs. your heat pump does not remove any humidity when it operates so the installation cotractor did not wire it to operate then. you can change the wiring on the humidifier to operate all the time by wiring it to the fan (g) terminal then it should work just turn it all the way to the lowest humidity when you are in cooling mode.
Jan 07, 2009 | Aprilaire 600 Humidifier
Humidifier not working
Depending on the age, transformers do go bad. It will have a odor to it if it is burned out, I just checked and the doorbell transformer at home depot is sufficient to run the humidifer. Dont worry that it is 20VA instead of 10VA. The VA is just the load it can handle, the higher the number, the higher the load. The transformer at home depot is around $15 dollars. You will use the 2 outer of the 3 screw terminals for the low voltage. I hope the helps. Steve
Dec 11, 2008 | Honeywell HE220A1019 Whole House...
Does your humidifier use an ultrasonic transducer for vaporizing the water?
May 08, 2017 | Crane Penguin 1 Gallon Humidifier
HE120 By-pass humidifer - Sponge Drum not rotating!!
Model HE908A drum is turning but we get no condensation
Dec 25, 2007 | Honeywell HE120 Humidifier
Water not running through humidifer
Mine had the same problem no water through the solenoid. It turned out to be the little adapter with the needle hole on it, attached to the solenoid on the intake side. It was clogged, cleaned it out and works great now.
Nov 18, 2007 | Honeywell HE220A1019 Whole House...
Crane Penguin 1 Gallon Humidifier Logo
999 people viewed this question
Top Crane Humidifiers Experts
Danny Kuhlmann
Andrew Taylor
Andrew Taylor
Are you a Crane Humidifier Expert? Answer questions, earn points and help others
