Samsung HT-C555/XEU not playing dvd's just says loading or invalid disk.
SOURCE: Samsung DVD-V5500 won't finish loading
i have the same problem. i opened it up and traced it to a bad motor on the disc spinner. part # is rf-300fa-12350. it's a cylinder shaped motor. can't get the cylinder apart to try to repair the motor though
SOURCE: Sony DVD RECORDER/PLAY WON'T PLAY
Dvd players are only made to last a couple of years(the laser goes bad).If you play scratched disc's it won't last that long.Hopefully you didn't pay alot for the player,and if you did then you can get the laser repaired but its expensive.I usually wait until the things go on sale and pick one up for 20 or 30 dollars.When the laser burns out after repeated use I just buy a new one because fixing them is more expensive and unless you want to continue having problems its easier to buy new.These guys that put alot of money in these units are just wasting their money.
SOURCE: region codes for Samsung ht z110
Try this
1. Disconnect your player from its main power source for 30seconds
2.Reconnect your player to its power source
3.Press the power on button on your remote control
4.Press the Enter button on your remote control
5.Press 8,4,2,6 and 9
6.Press Enter on remote control and the your player will place itself on standby mode
7.press the power on button on remote control.
your player is multi region.
SOURCE: i have a samsung model ht-tz215/xeu dvd i switch
HI,
With regards to your recent query, when you
get a 'Protection' message on your unit it usually means the unit is
overheating. Please make sure there is nothing blocking the air vents on
the unit, nothing is sitting on top of the unit and that it is not near
any hot items like radiators. Please also check the cables that connect
the speakers, disconnect them all, reconnect, turn the unit off and back
on. If you have checked all of the above and the same thing still
happens, try resetting the unit, full instructions can be found in the
troubleshooting part of the user guide. Where did you purchase the
product?
ELSE
DO THIS
Pressing the STOP button on the front panel andholding it for 5 seconds". The power indicator flashes once and thesystem resets!
SOURCE: Samsung DVD-V8600.....DVD won't load
open cover and clean the laser with alcohol and try again
