Question about HTC G1
SD Card In G1 Retrieving info
I did the upgrade on my phone for the G1 and now it's telling my that my SD card needs to be formatted. But if I format it I will lose all of my info stored on there. I put it into my card reader and it's asking for the same thing... I need to retrieve what I have on my SD card as it is business related... Please help...
Thanks
I took my sd card out and rebooted my phone and everything is gone... how can i retrieve the info
Posted on Mar 05, 2010
Sd card not working on g1 phone. How do you fix it?
Hello
If you are charging the phone the SD will become unavailable. I heard it is only if using a 3rd party charger, but it also happens if you are connected to a computer via USB.
If this is not the case, it could be a formatting issue with the SD card.
To remove the card,hold the phone in landscape orientation, slide open the keyboard and you will see a little tab on the device (not on the slide part) to the right of the keyboard pad, near the bottom... open the tab with your fingernail and then you can push in the sd card to get it to release... make sure you unmount it in 'settings/sd card and internal storage' BEFORE you take the card out or you risk corrupting the info on the card...
Apr 11, 2011 | HTC G1
My sd card is saying blank and unsupported
Is your computer able to read the card with an SD adapter? If so, back up any information on it to the computer. Put card back in phone and go to settings->storage->unmount SD card->then format SD card. Allowing the phone to format the card usually has better results than formatting it in Windows because it's going to use the correct file system type.
Hope this helps
Ray
Mar 02, 2011 | HTC G1
Hi, my g1 has problem to read the sd card, when i try to use the camera, the phone says it does´nt have, and windows XP do recognize the phone
Need a little clarity on what your saying XP does recognize the SD card when you mount the phone to the computer, or it doesn't?
Well here is what you can try. and just remember ALWAYS ALWAYS ALWAYS do this before removing your SD card from your phone.
Settings>SD card & phone storage>Unmount SD card
Now if your phone has "Unmount SD card" blacked out then don't worry about just go ahead and remove the SD card.
Take the card and put it in a card reader and put it in your computer. Go to: Start>My computer> (and the drive corresponding to the SD card.) and then try to open it. If a window comes up saying something like drive E: is not formatted, Format now? and then Ok or cancel well if this comes up it could be one of three reasons; the SD card is not properly formatted, SD card is damaged, or the SD card reader is not working properly. So before trying to format the SD card try another card reader or try it on a different computer. If that doesn't work try to format the SD card. If formatting the SD card doesn't work, you may need to buy another one. If you do decide to get another one check Amazon.com they have good prices for the SD cards however if you prefer local buying best place to go (that I've found) is Radio Shack. They always have sales on the MicroSD cards. One other thing. For some reason. SanDisk Micro Sd cards seem to work the best for the G1. The transend cards are utter **** and worthless. Avoid buying them anytime your in the market for a new SD card or USB flash drive.
If you need further help feel free to check out xda-developers.com
Aug 07, 2010 | HTC G1 Smartphone
If i format my sd card what are the drawbacks?
nothing apart from having no way of retrieving what you delete. You could copy your file off the SD card to your computer and then format the SD card. That way you have the benefits of formatting but your files are still somewhere just incase!
Good Luck :D
Nov 28, 2009 | LG RUMOR Cellular Phone
Removed SD Card is everpresent in the notification bar on my Tmobile G1, even with a microsd card in the memory slot
Your SD card is corrupted. Since it's corrupt (or worse, broken), the G1 won't be able to mount it to your computer via USB and you will have to insert it into your computer via an adapter. From there you can format the drive (make sure it's formatted fat32) and it should be fine. I've fragged my SD cards a couple of times and had to format. If you are unable to re-format the SD card, then there may have been some sort of actual, physical damage to it, although that's unlikely.
Aug 23, 2009 | HTC G1 Smartphone
G1 16gb micro sdhc card not read on my pc
Umm..... did u try formating the card? before you do that backk all info on computer via usb cable. if the G1 says mount to usb go ahead and mount it. in your case it might not work. but try it anyway. if no good goto settings on the G1 then goto SD and internal memory and tap eject SD card then pull it out then push it back into the slot tell me if it works on the PC now.
May 23, 2009 | HTC G1
Sd card
I had the same problem. so what i did is i created a back up on my computer and format it the sd card. and it had a bad file in it that was causing the problem. once i format it the card it was ready to be used again. just make sure you look for that corrupt file so you don't put it again to the already clean card. also i removed the sd card from the g1 and plugged it straigt to the computer. I hope this can help you like it helped me.
Feb 12, 2009 | HTC G1
Transferring stored data from micro SD card on G1 to new one
plug your G1 to your PC via a USB cable that came with it .., once you plug it in you'll get a notification entitled USB connected .. select it and then choose mount ... once thats done open your My computer icon , you'll see an exrta drive that wasn't there be4 somethig like K or M .. open that and you'll see all the content of your SD card .. copy and past everything to a folder anywhere in your computer ... then all you gotta do is replace the SD card , repeat the same proccess but then time copy everything back to your new SD card .
Jan 30, 2009 | HTC G1
G1 wont take pictures
I  had a similar problem, I fixed mine by formatting the SD Card in my computer, installing it into my G1, then restarting. You miss out on whatever was on the SD Card from Google, but at least you get to use the camera.
Hope this helps, Eric
P.S. I've called tech support to see if I can re-download whatever was on my SD Card to begin with, and as of yet there is nowhere they could direct me to, to download whichever files were stored there.
Dec 21, 2008 | HTC G1
HTC G1 Logo
260 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
