Question about HP Officejet 5510 All-In-One Thermal Printer
How to replace the ink cartridge from my hp officejet 5510
I need help with taking out the ink cartridge from the printer
  • 72 Answers
Replacing the Inkjet Print Cartridges
GO TO THE FOLLOWING LINK:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00033420&lc=en&dlc=en&cc=us&product=311255&rule=23005&lang=en
Have a good day,
Posted on Jun 25, 2009
Show me where to install ink for model hp officejet 5510
hello!
first, you need to lift up both the ADF unit and the flatbed scanner glass unit.
then, when the print carriage moves into view, press down and pull the ink cartridge for replacement.
Jul 13, 2011 | HP Officejet 5510 All-In-One Thermal...
Printer # 5510 - How do I open to replace ink cartridge?
If you mean HP OfficeJet 5510 then the following tutorial is for you:
HP OfficeJet 5510 Replace Ink Cartridges
If you do NOT mean HP OfficeJet 5510, please do not fail my solution. Instead, start a new thread with your make, model clearly defined.
Jan 13, 2010 | Office Equipment & Supplies
Ink cartridge
Lift the lid. The cartridges will move to the park position. Gently pull them out and replace them.
Jul 02, 2008 | HP Officejet 5510xi Printer
HP Officejet 5510 - Replacing Ink Cartridge
this should work for all 5500 hp printers i hope this helps you out richard from chicago i just noticed you have the wrong cartage you need hp 57 color that will make all the difference :-) HP Officejet 5500 series All-in-One model Black cartridge Color cartridge HP Officejet 5505 HP 56 HP 57 HP Officejet 5508 HP 56 HP 57 HP Officejet 5515 HP 56 HP 57 HP Officejet 5510, HP Officejet 5510xi, HP Officejet 5510v HP 56 HP 57 HP Officejet 5600 series Replacing the print cartridges
  1. Turn on the HP Officejet, and lift open the print-carriage access door. The print carriage will move into the access area. Figure 1: Opening the print-carriage access door c00034766.jpg
  2. After the carriage stops moving, push down on the top of the print cartridge to release it, and then pull it toward you out of the slot. Figure 2: Removing the print cartridge c00034767.jpg NOTE: It is normal to see ink buildup in the print cartridge slots.
  3. Remove the new print cartridge from the packaging and gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper contacts or ink nozzles. Install the cartridge immediately upon removing the tape to prevent ink from drying in the nozzles. Figure 3: Removing the plastic tape c00034768.jpg
  4. Push the new print cartridge into the appropriate slot at a slight angle, until it clicks into place. CAUTION: Do not attempt to push the cartridge straight into the slot. It must slide in at a slight angle. Figure 4: Inserting the print cartridge c00034769.jpg
  5. Close the print-carriage access door.
Aligning the print cartridges The HP Officejet will prompt you to align the print cartridges every time you install a new print cartridge to assure high-quality output.
  1. When the message displays, press OK . The HP Officejet will print an alignment page.
  2. Place the alignment page face down on the left front corner of the glass with the top of the page facing the left side.
  3. Press OK . The HP Officejet will align the print cartridges and display Alignment Complete .
Mar 18, 2008 | HP Officejet 5510 All-In-One Thermal...
The ink carthridge location
how do I get to the ink cartridge on a hp 5510 all-in one?
Feb 15, 2008 | HP Officejet 5510 All-In-One Thermal...
Hp Officejet 5610
check the belt drive, motor may need a replacement
Dec 16, 2007 | HP Officejet 5510 All-In-One Thermal...
REPLACING INK CARTRIDGS
For HP 5510 series for replacing the cartige, you need to lift the door just above the paper tray. Pull out the old cartidge, hold it so you can see the way it is inserted and click in gently in the same way.
Nov 19, 2007 | HP Officejet 5510 All-In-One Thermal...
HP Officejet 5510 All-In-One Thermal Printer Logo
221 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
