Question about Gateway 500GR PC Desktop
My gateway 540 gr start for 5 seconds and turn off, the fan starts to then turn off.
  • 2,404 Answers
Disconnect everything except for the power to the motherboard. If you turn on the computer and everything still turns off, then try another known working power supply. If the machine stays turned on then connect power to your drives one at a time with the computer off each time to see which drive is the culprit.
If everything still turns off then reseat the CPU and the memory and if it still turns off then that means the motherboard is bad and it would need to be replaced.
Posted on Jun 25, 2009
Have acer 7540 On restart have error 0211 key
Try this fix:-
This problem was on a Gateway NV52 running Vista Home Premium (64) and this is how it was resolved, with the help of their tech support:
1. Turn off computer and unplug power cord.
2. Disconnect all external devices
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED's and listen for power supply fan.
7. If LED's are on or power supply fan starts spinning, watch for boot screen
8. If computer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
Sep 22, 2014 | Computers & Internet
I have a Samsung rs21!!! it wont cool in either compartment. when I plug it in the compressor fan does a quarter turn then stops. the compressor runs for about 30 seconds then cuts out? any ideas plea
most likely the start relay on the compressor that changes from start windings to run windings. the compressor will run for about 30 seconds on start windings then click out on internal thermal overload.
this can be confirmed by turning it on and letting it do the 30 second run then when it stops just wait and see if it cuts in and tries to run again (usually takes about 5 min) the second time it cuts in it wil most likely not run for as long (usually about 10 seconds). if this is what it does get a new compressor start/run relay.
as for the fan flick it with your finger and see if it spins freely.
Jun 05, 2014 | Samsung RSA1SHPN American Platinum Inox...
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
It is normal for a Gateway ML6732 that the fan starts when turn on the laptop and then stops the fan couple seconds after that? My laptop gets freeze all the time seconds after.
That is normal for when the laptop starts up. That is also a good indication that the fan is working ok. If the fan loud and noisy all the time then there is a build up of dust in the machine and it needs cleaning out,
Regards.
Jan 23, 2011 | Gateway ML6732 Notebook
Gateway Mt6730 starts up and then message comes up CPU Fan Overheating and shuts down in 5 seconds. Cleaned the fan but still does this.
Try cleaning the air vents too with a can of compressed air as dust can block these vents causing the CPU to overheat. The vents can be located at the back or sides of the laptop. Also a good idea is check and make sure that the CPU fan itself is working and spinning up.
Regards.
Dec 11, 2010 | Gateway MT6730 Notebook PC
Overheating
Overheating is a big issue with Gateway. It mostly involves problems with the fan. When Gateway receives a warranty fan problem they replace it with a fan that is reconditioned or rebuilt (probably from another cutomer's unit like yours) and they don't seem to last long. To make sure it is a fan problem, which is the most common, Turn on the laptop and wait to see if the fan is turning on. It won't take long, processors get hot quick. The fan should turn on and run anywhere from 3 to 15 seconds then turn off. It should do this approx every 5 to 7 minutes in order to keep the processor cool. If it doesn't work at all, works seeming sporadically, or the processor gets really hot before the fan starts, then it's a fan problem, and a NEW fan should be purchased. If the fan works properly, then it could be that the fan and heat sink need to be cleaned internally due to dust build up.
Jun 20, 2008 | Gateway MX3228 Notebook
Gateway 675 fan problem
Check the BIOS in the laptop. The CPU fan and unit fan is controlled by temp. U can set it for a lower temp. The Bios is accessed when U boot up... F2 usually, There should be a 5 to 15 second screen telling u what to press to get there.
Good luck
Mar 07, 2008 | Computers & Internet
LP 540
1. Have you recently changed a lamp and if so, Did you reset the lamp timer and is your filter (if it has one) clean?
2. can you hear a FAN start when you turn the unit on?
Jan 15, 2008 | InFocus SP-LAMP-017 Projector Lamp for...
Open Questions:
Get Data Recovery Backup Online Data Recovery Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Jun 18, 2018 | VIA Computers & Internet
See all Gateway 500GR PC Desktop Questions
Gateway 500GR PC Desktop Logo
363 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
