Question about Vizio VX32L Television
I get sound but no picture
The back light is not firing...do I need to buy the backlight inverter master and slave? or just the master? Thanks!
  • Aaron Berger Jun 25, 2009
    So, I took it apart and there are 2 inverters - one on each side. Do I need to buy both? If so it'll be $160. I'm confused.
  • Aaron Berger Jul 24, 2010
    You guys are amazing! thanks!
  • 583 Answers
You just have to buy and replace the master not the slave.
thanks for using fixya.keep updated.
please do not forget to accept and rate this solution positively
Posted on Jun 26, 2009
    President:
  • 1,734 Answers
This is a quite common problem with the VX32L. There are faulty parts, especially the relevant board.
If you or someone you know can replace a whole ciruit board, then it can be fixed.
On this site you can get the replacement board:
http://www.shopjimmy.com/catalogsearch/result/?q=vx32l+back+light
You'll just need to find the right one by looking at yours. Yourbacklight board will have letters & numbers on it for a boardmodel#. It should be easy to find one and replace it.
Otherwise ask a authorized service dealer to fix it (will cost you another 70-100 bucks).
Posted on Jun 25, 2009
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
Power is on (Blue light) but the screen is black. Does not display picture.
There are two likely options: either one of the backlight inverters has burned or the power supply has a puffed cap and doesn't provide voltage for the inverters.
The simplest way to tell is to use a voltmeter and find if power provides 24V to inverters. It's easy to see where, there are at least 5 wires for ground and another 5 for the 24V line, so it's a no brainer to find them,
If there is 24V on the inverter then either the master or the slave is burned.
Chances are good you may be able to find which one by testing the fuses on them.
Finally, the master backlight board is 6632L-0346A and the slave is 6632L-0347A.
Hope this helps!
Bobby @ CoppellTVRepair
www.coppelltvrepair.com
May 12, 2010 | Polaroid FLM-4234BH 42 in. LCD HDTV
Bad backlight inverter on 42" RCA LCD
Does the backllght go out after a few seconds? Could still be a lamp or something else on the inverter boards. You could try used inverter boards from the same set with other problems (broken screen), Or a complete working backlight from another set but very delicate operation to swap the LCD display from one panel to another.
Apr 03, 2010 | Vizio VW32L 32 in. LCD HDTV
Picture goes black, have sound, red light comes on at the on button, 60'' phillips tv
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board,will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.It a long board in shape.
Mar 16, 2010 | Televison & Video
Picture come on for about 2-3 minute, then goes out has sound no picture, red light come on near power button
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backlight board to get the picture back.Tries Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
Mar 03, 2010 | Philips 60PL9200D Projection Televisions
Backlight Inverter Input Voltage
input voltage like 21.4dc is correct and not sure about master or slave inverter board. You have to check one by one. Here is part store offers cheap prices for boards, please ask required boards.
Sep 06, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Replacing backlight inverter board
Not always but usually the inverter board is part of the display panel, way to much money to bother fixin.
Jun 20, 2008 | Televison & Video
Vizio VX32L Television Logo
94 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
