Question about Whirlpool GHW9400SU Front Load Stacked Washer / Dryer
Diagram of the inlet water valve and solenoid on Whirl Front-Loading Washer Mod. WFW9400SW04
WATER KEEPS RUNNING IN WASHER EVEN WHEN NOT IN USE
SOURCE:
  • 1314 Answers
SOURCE: Whirlpool ghw9100lw2 front load washer doesn't use both hot and cold
first make sure the hoses aren't reversed hot on cold or cold on hot next turn off cold water remove the hose from the washer and check to see if the screen on the washer is clogged if not get a bucket turn on cold water and see how strong the water is then let me know what you find dont rate me till we are done
Posted on Jan 10, 2008
faggly
  • 74 Answers
SOURCE: Maytag performa washer hot water runs continuously
Littleone.. please check your instructions.. some washers now dont need Hot water connection to them...they heat their own as part of the efficiency settings on the wash programmes themselves!
Regards Faggly
Posted on Mar 19, 2008
SOURCE: Whirlpool AWG 384 Front Load
OK, I bought a new solenoid valve; problem fixed. Water now gushes in faster than it has for a few YEARS! Wash time now reduced by almost half. Thanks for suggestions.
Posted on May 30, 2008
emissionwiz
  • 85161 Answers
SOURCE: washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Posted on Sep 16, 2009
quatlew
  • 141 Answers
SOURCE: Replacing water inlet valve for Whirlpool Duet
Thats a two man job that you are trying to do yourself. The top of the washer has to be removed to replace the valve. Get some help to remove the dryer from the top.
Posted on Mar 15, 2010
Why the inlet valve is not stopping running water?
What happens with such electrically operated valves, is that a calcium (or other mineral buildup) prevents the rubber seals from stopping water flow. You need to replace the valve(s), or clean them thoroughly, using either LimeAway or CLR.
May 11, 2017 | Samsung WF337AA Front Load Washer
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Bosch washer 2460 signals water tap closed, is this electrical, checked incoming hoses , water and screens
If you have checked the hoses and screens then the most probable failure is the inlet water valve. I suspect that one of the electrical water valve solenoids has failed. If you using cold water try a warm or hot wash. If your using hot or warm try a cold wash. I am not sure on this washer if there is a mixing valve but may front loading washers have mixing valves that mix hot and cold water simply to help dissolve the HE type soaps. If changing wash temp makes no difference then a continuity check for inlet water valve coil resistance will have to be performed with an inexpensive ohm meter. If there is no continuity the solenoid has failed and the inlet water valve will have to be replaced.
This unit appears to have 2 inlet water valves one for hot and cold and one for just cold that is used for diluting soap. You will need to check all 3 solenoids for continuity. The inlet water valves are items 5 and 6 of this picture:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=192773&pkw_=basket&model_id=5110159&NewWindow=1
You can find replacement parts here::
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5110159&diagram_id=192773#d192773
Let me know if you need more assistance.
Kelly
Jul 11, 2011 | Bosch Axxis+ WFR 2460 Front Load Washer
My Kenmore Elite He4t front loading washer fills up with water when I'm not even washing clothes. I left some bed linens in the tub to be washed later in the week and when I opened the door to add some...
This condition is typically caused by faulty solenoid or solenoids at the water inlet valve. Unplug the machine, turn off the water, and remove the supply hoses. Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter and checking for continuity. A lack of continuity will indicate a faulty solenoid and the inlet valve assy will need to be replaced. Sorry for your trouble and I hope this helped. Best wishes.
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
My washer just stops about 2 minutes after starting it during the water loading cycle. i have tried unplugging and turning it off several times but it keeps doing it. any advice?
Check for a water supply problem.Take a look at the water inlet valve. Unplug the machine and remove the water supply hoses. Check the small metal screens inside the openings on the water inlet valve. Make sure they are clear of rust or debris. Check the solenoids. Test for continuity. A lack of continuity means a bad solenoid. I will attach a photo for reference. Hope this helped and best wishes.
Sep 09, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag MAH8700AWW water keeps running
Check the solenoids at the water inlet valve. Use a multimeter or ohmmeter and check the solenoids for continuity. A lack of continuity means a bad solenoid and the water inlet valve assy will need to be replaced. I will attach a photo for reference. Another possible cause would be a water level switch, but not with it running on only the cold water side. Hope this helps and best wishes.
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water doesn't stop
you have a defective hot water inlet solenoid valve. you have to replace that part.
tnx 4 using fixya,
drcool
Oct 25, 2008 | Washing Machines
Whirlpool GHW9400SU Front Load Stacked Washer / Dryer Logo
32 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
