Question about Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier
Collection grid The hinged flaps on the bottom of the grid are broken thus the purifier is not working. Can I purchase a new collection grid?? I purchased the machine in Feb or '04
  • Michael Passee
    Michael Passee Aug 08, 2012
    I have the same problem with Model S1857. It is a shame that the courts allow the parent company to get of the hook for providing support for these machines. I have 4 of these machines with various problems and they were not cheap. One would think that there is something we consumers can do.
  • Michael Passee
    People with these quandra filters with problems must get together and help each other.
  • 94 Answers
You can purchase a new collection grid on ebay.
Posted on Jul 04, 2009
I HAVE 2 IONIC BREEZE QUADRA. FIRST HAD PROBLEM WITH 1, NOW THE SECOND ONE HAS SAME PROBLEM. HAVE CLEANED AND DRIED THOROUGHLY THE BARS AND FILTER, AND CLEANED REST OF WIRES WITH BRUSH. WHEN I TURN ON I...
If none of the hi voltage grid wires have broken then check to be sure grid wires are truly cleaned.
If not cleaned in a while like every 2 weeks they will have carbon build on them. And from my experiences with cleaning them is the build looks similar to the color of the wire. Try some qtips dipped in alcohol or cotton balls. The build comes off like flaking metal. Also be very tender with these wires they break fairly easy. When done cleaning turn upside down and back so beads can scrape up and down on wires. Also you do know once clean the parts especially the big collection bars they need to dry for at leased 24 hours before ever powering unit back on. Hope this helps.
Dec 13, 2010 | Sharper Image Ionic Breeze® Quadra® 4.0...
Red lkight is on where yellow light indicates you need to clean?? Mike MAmbach@aol.com
Try cleaning the collection grid. If that doesn't work, try blowing out the dust inside the unit. (Air compressor if you have it would be helpfull.) Otherwise you may have to just buy another grid. Not that many online try ebay.
Feb 23, 2010 | Sharper Image Ionic Breeze GP SI730 Air...
I own an Ionic Breeze Quadra unit. It has been working fine and I really like it because it removes bad odors from the house. Mine has just started making a hissing noise. Any suggestions? Thanks
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Sharper Image Air Purifiers
Need replacement grids for Sharper Image Model S1637 since clips at bottom have broken off of grid.
Replacement grids have been posted to ebay. You can replace the complete unit for $45 on ebay so that would probably be a better solution. The last grid I purchased on ebay for similar was around $20.
Jun 03, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Ionic Breeze Hybrid GP air purifier only 1/2 grid gets dirty.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
Apr 24, 2009 | Sharper Image Hybrid GP (SI724) Air...
Do i need to replace one or two missing wires?
try soaking the plate in ammonia ..it has been known to bring them back despite the missing grids....hopefully they arent where the contactor fingers ride.
Mar 21, 2009 | Ecoquest Living Air Classic Air Purifier
Sharper Image Hybrid GP Germicidal Air Purifier SI724 NO POWER
Oh there are a lot of known issues! I used to work for sharper image and I believed in this items very much so until mine broke. However after a year I figured out how to fix it. Take the big square collection grid out and the back screen off. Now get you a thick rag and be very careful because there are several tiny wires going up and down. Smaller than dental floss, you need to be very careful because you can either brake them or slice your finger wide open( Under any circumstances I can not be held liable for the information I am giving you try this at your own risk). Now with the towel very gently go up and down each wire like you are polishing a brass pole(once again these wires are thin and can break or cut you). Do this from the back side of the unit and from the inside where the collection grid that you took out sits. Take your time and be thorough, and presto your 400 dollar air cleaner is working again.
Nov 21, 2008 | Sharper Image Professional Plus Ionic...
Broken ionic breeze
Try this site to get replacement collection grids.....
They have several different ones listed so I just copied the webpage so you can see which one would be most suitable for your specific model.
http://www.thefind.com/search?query=ionic+breeze+collection+grid
Hope this helps.. :)
Aug 13, 2008 | Sharper Image Ionic Breeze 3.0 Air...
Air purifier
ozone is what you are smelling,also purchase a extra collection plate from ionic pro so the cleaned plate can dry complete.
May 10, 2008 | Ionic Pro TURBO Air Purifier
Sharper Image Professional Plus Ionic Breeze? QUADRA GP Silent (SI861) (2 Pack) Air Purifier Logo
447 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Mike Squire
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
