Question about Kenmore 63942 Dryer
My dryer keeps turning off.
The lint screen is clean, gas is on, no block in exhaust line, and heats up fine. when buzzer sounds i press the button and it comes right back on. WTF?
right now there's a book leaning on the button, only because i dont want to use duct tape.
so is it a bad timer, sensor or button?
please help, im poor and can only afford one repair
  • 72 Answers
Its either overheating and kicking out the tstat if it wont start back up for about 30 or 40 min it could be the motor overload you may have bad motor
Posted on Jul 01, 2009
Dryer does not heat constantly. It starts to heat then turns off the gas. I need to dissamble it to test the parts.
Sounds like a block in the exhaust. Remove exhaust pipe and clean pipe. This is a huge fire hazard and your dryer is likely saving you from a fire. Remove large back panel on dryer. Clean all passages that handle airflow from lint screen back to exhaust. Restart. If this does not work, be happy that it is now clean :) The issue is likely your flame sensor at this point. Looks a bit like a spark plug. Short term fix. Clean probe with a dollar bill. Seriously, a dollar bill. Replace and restart. Order a new flame sensor.
Jan 11, 2014 | LG DLG0452W Gas Dryer
Gas Dryer - takes to long to dry
Friend,
huuum At your service!
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.If the vent line is kinked or blocked
2. Then check if the outside screen covering the exhaust vent if this is even half blocked
with lint there will be no heat! This screen is to keep small animals out!
Try checking this and if it is clogged or the spring loaded door is stuck closed.
Try to clean the lint out of the corners of the flap door,
and or remove the screen permanently!
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
Take the vent line off the rear of the dryer and try if it works. If it does you know it's the vent line and not the dryer that's the problem the dryer.
You will be fine
Bless You huuum
Feb 01, 2009 | Whirlpool LGR3624JQ Gas Dryer
Not heating also exhaust fan on dryer is not woeking screen show a problem has been detected with the model selection connection
Hello chuhunghuang
Welcome
You said, your not heating also exhaust fan on dryer is not working screen show a problem has been detected with the model selection connection
Try this first.
NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE! They sense this and stay clear.
It is 2 years that mine is off and all is fine.
Let me know how it goes!
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Oct 13, 2008 | GE Dryers
MY DRYER RUNS BUT WE GET NO HEAT?
Try this first.
You will be fine
Bless You huuum
Oct 06, 2008 | Dryers
Hoover Dryer 5030D does not heat up
Try this first.
You will be fine
Bless You huuum
Oct 06, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Neptune MDG5500AW Gas Dryer
Friend,
ngfam1 At your service!
CHECK ALL these spots!
Try this first.
2. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
You will be fine
Bless You ngafm1
Sep 05, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Dryer repaire
Friend,
1. If the dryer is gas and old, the pilot could be out or if it is newer it could have a defective or worn out a igniter!
2. The lint filter is full and needs to be cleaned.Try this first
3. The outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out! Try checking this second! if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently! I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Aug 30, 2008 | Dryers
Wont heat
Try this first.
Bless You huuum
Jul 25, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Propane Gas Dryer (Whirlpool DUET Front Loader) not drying
Did this tech do some wash to the dryer and feel that there was no heat?
He was not a good tech
Try this first.
You will be fine
Bless You huuum
Jul 11, 2008 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore 63942 Dryer Logo
118 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
