Question about Kenmore 99123 Electric Kitchen Range
4 yr old Kenmore Elite Glass top range model # 790.99123.40 - Front right side has three levels of burner - small/medium/large - which indicates the size of the burner to be used. The center ring or small burner does not work the medium (middle ring) and large (outer ring) work. Can I replace that burner? Do I need to replace all three or just the center one? What do I need to do and how do I do it? - thanks - broken in elk grove ca.
3 Suggested Answers
  • 29 Answers
SOURCE: My Kenmore glass top range,
SOUNDS LIKE YOU MAY HAVE A WIRE BURNED. CAN YOU USE A MUTIMETER?
Posted on Jan 29, 2009
  • 360 Answers
SOURCE: kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
I have a kenmore elite range model no. 790.9911. The right front burner wont turn off. Is it the switch, burner or control board
On this model (with the glass touch controls, right?), it is usually caused by a bad, sticking relay on the relay board, located on the back side of the oven, down near the bottom. Some of these models had a safety recall... You might want to check to see if yours is one of the affected models. (The model number you gave is not complete; find the complete model # & serial # on the range itself, usually on the range frame, visible when you open the drawer or open the door.
Dec 13, 2014 | Kenmore Kitchen Ranges
I have a Kenmore Elite Kitchen stove top (one with the burners underneath a glass plate). Model number: 911 99004990. I believe it was purchased close to or around March of 2000. The problem I have with...
I have the same problem with ours! Our 2 small burners don't work at all and the 2 larger ones only work bright red hot. I called Sears and they said there is no recall on my particular model, but there are tons of recalls on other models. The problem is with the venting from the oven doing damage to the wiring (shorting them out maybe?). We're trying to find someone who knows anything about this and if we can get it fixed as our stove is only 3 years old.
Nov 15, 2010 | Kenmore Kitchen Ranges
Large right front glass burner snd surrounding
The item number for this through repair clinic.com is 770583 with a cost of 374.00 Most costly part of the stove. Sorry wish it could have been better news.
Mar 09, 2010 | Kenmore Kitchen Ranges
Burner dosent get as hot as the others
If you saw a spark from the burner chances are that the burner has shorted out and is in need of replacement.
Apr 06, 2009 | GE Spectra JBP78 Electric Kitchen Range
Kenmore glass top range left front large burner out
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
Burner on range will not turn off
Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Realy is the problem. I had the same problem with my front left burner stuck on high.
After replacing everything works okay.
Apr 07, 2008 | LG LRE30755 Electric Kitchen Range
Kenmore 99123 Electric Kitchen Range Logo
93 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
