Question about Canon imageCLASS D320 Digital Copier
Copies have white stipe down the page, like its out of ink?
  • 41 Answers
You have some obstruction like torn paper or something either inside your drum unit or just under it on yur transfer.Have a look.
Posted on Jun 26, 2009
I down loaded escape from raven hearst and there is a black page with a white stipe on top. What does that mean. Please help i really would like to play this game.
How To Get Free Robux?
Navigate to the section of this article where you can find the "Access Online Generator" button, and click on it.
Fill your Roblox account details and add your username to proceed.
Choose the number of Robux that you want to generate for free.
Click on the "Generate Button".
Robux Mania Unlimited Free Robux Roblox Hack Tool
Dec 07, 2017 | Black Video Game Consoles & Games
Fax has stipe down middle
When you open the topt cover, there are 2 scanner glasses. A small one a and a big one, the small one is used when using the feeder. Spray some windex direclty on soft cloth and clean the 2 scanner glasses as well as the white reference above( there are 2 small and big). You may even see it, a mark it the middle of the glass.
This should resolve the issue
Apr 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Printer doesn't copy
indicates that the page on the scanner is upside down
the printed side faces down
Oct 26, 2017 | HP Photosmart C4180 All-In-One InkJet...
Dirty printing
1) try cleaning the heads this is usually a job within the printing programmes,
2) using a cotten wool Q tip "the baby typr" and metholated spirits "do not use white spirits or turps too greasy" clean the inside "tram rails " that the carrage slides on "
dont use to much liquid though"
also bleach is very good at removing opld ink that lays on the rails " it is time consuming but well worth the time
Aug 16, 2009 | HP LaserJet 4 plus Printer
Cannot copy because printer says "out of ink" and shows WHITE ink
Try this really quick and see.
uninstall the printer completely, take out the the inks and replace them. then follow the initial steps you used in installing the printer when you bought it. If it doesn't work, try installing it on another computer. Cheers!
Apr 17, 2009 | HP Photosmart C6180 All-In-One InkJet...
Dark strip down center of page when coping from tray
There is a small strip of glass on the left side directly under the edge of the scanner, About a half an inch wide. It has something on it.
May be very hard to see, use a strong glass cleaner or some alcohol and a regular piece of paper to clean it with.
May 08, 2008 | Xerox Phaser 3200MFP/N Laser Printer
Line down center of page.
Hi Sherrey, I think I can help! If you open the ADF cover where you insert your pages to make a copy. You will see a scanner glass about 1/2 inch wide and runs across the width of the printer. You can take a soft towel and some glass cleaner and clean the glass. There will probably be some white build up that looks like white out on the glass just make sure you clean it very well. I hope this helps!!!!
Dec 04, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
My printed and copied pictures have horozontal lines
White lines through copies White lines can appear on a copy in either a horizontal or vertical direction. How the white line appears on the copy will determine the cause and solution. Horizontal lines Horizontal white lines usually indicate the ink cartridge is running out of ink or has some clogged ink nozzles. Try the following steps: 1. Some of the ink cartridge ink nozzles may be clogged with dry ink. Use the ink cartridge cleaning service to try to clear them. Follow the steps below: 1. Verify that there is plain white paper in the Input tray. 2. Press Setup. 3. Press or to select Tools and then press OK. 4. Press or to select Clean Print Cartridge and then press OK. The unit prints a test page. 5. Examine the test page. If the print quality of the page is good, stop here. If the print quality appears to be getting better, run the Clean Print Cartridge utility again 2. If the self test appears better, Increase the copy quality setting (Normal or Best) and try copying again. If the quality is still poor, continue to the next step. 3. If the quality is still poor, one or more of the cartridges may be low on ink or empty. Follow the steps below to check the ink levels. 1. Open HP Solution Center. 2. Click Settings. 3. Click Print Settings. 4. Click Printer Toolbox. 5. Click the Estimated Ink Levels tab. Figure 1: Estimated ink levels - both cartridges low NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab and then click Printer Services button then click the Estimated Ink Levels tab. 6. Replace any ink cartridge that is low on ink. 4. If the ink levels are not low, clean the cartridge face and electrical contacts at the back of the print carriage. 1. Open the front of the unit to access the ink cartridges. 2. After the ink cartridges are at the center, unplug the power cord from the back of the unit, and remove the ink cartridges. The power cord must be removed to ensure that the unit is not damaged during the cleaning process. 3. Clean the cross-hatched area of the ink cartridge with a soft clean cloth that is slightly dampened with clean water to remove any build up. Avoid cleaning the ink cartridge nozzle plate. Cleaning this area can force foreign matter into the ink nozzles and plug them. Figure 2: Cleaning the ink cartridge 1 - Clean in the cross-hatched area only 2 - Do not touch the nozzle plate 3 - Clean the copper-colored contacts 4. With a soft lint free cloth slightly dampened with clean water, clean the copper-colored contacts on the back of the ink cartridges. 5. Allow the cartridges to dry before reinserting them. 6. Close the unit, and plug the power cord back in. 7. Print a self-test page to check the results. Follow the steps below to print a self-test page. 1. Press Setup. 2. Press or until Print Report displays and then press OK. 3. Press or until Self-Test Report displays and then press OK. The self-test report prints. 5. If the problem is not corrected by cleaning the ink cartridges, replace the ink cartridge(s). Vertical lines Vertical white lines usually indicate the scanner did not calibrate correctly. This can be caused by debris on the scanner glass or white reference pad. Try the following steps: 1. Turn off the HP all-in-one product and unplug the power cord. 2. Open the document cover to access the scanner glass. 3. Using a non abrasive glass cleaner, thoroughly clean the scanner/copier glass, and white lid backing on the inside of the top cover. CAUTION: Spray the cleaner onto the cloth. Never spray fluids directly onto the HP all-in-one product. 4. Plug in the power cord and turn on the HP all-in-one. Let me know what happens, Good Luck, Tim
Mar 14, 2007 | HP PSC 1315 All-In-One InkJet Printer
Canon imageCLASS D320 Digital Copier Logo
70 people viewed this question
old marine
old marine
