40GB and 60GB 1st Gen PS3 consoles are notorious for faults with the Blu-ray lens. With your warranty more than likely expired you will not get a replacement. With no support offered for older versions either I suggest buying a newer 'slimline' version. Bigger hard drive, support offered and more reliable.
Yup its your laser. You need to try wiping it off wih qtip and rubbing alcohol if that doesnt work just replace the laser. Ps3 lasers are the most expensive though due to blu ray.
Your laser is dirty and needs to be cleaned.
DON NOT ATTEMPT THIS IF YOUR CONSOLE IS TILL UNDER WARRANTY!
Otherwise, there are many videos that show you how to disassemble/reassemble..try this http://www.youtube.com/watch?v=bNW1IK0Gyt4&feature=related
There is only 1 Torx screw on the entire system, the rest are all phillips drive. All you will need is Q-tips and rubbing alcohol. When cleaning the actual lens DO NOT press very hard and try using a rotating/twisting with the tip of the Q-tip.
NOTE: KES-410 (dual eye) lasers can sometimes have a bad Bluray and still play CD and DVD movies. http://www.ps3laser.com/ps3-laser-compatibility-chart/
Your model number is on the left rear, starting with CECH
in this case if your out of warranty open your console and clean the laser with iso alchohol and a q-tip re assemble and see what it does if it still has the prob call a company called innex and order a new laser
work case sin is a daughter board replacement hope this helped rate high if so
If you can get to it without it freezing use the System Restore function under:
System->Settings>Restore PS3
If you can't get to it because of freezing you should put your hard drive into another PS3. It will see it as a new drive and prompt you to format it. Afterwards put it back into your PS3 and it will do the same thing again.
It doesn't matter which PS3 yours or the one you put your hard drive into, they're all the same as far as the process goes.
thing again.
yo dude i have the same problem as u like im playing cod4 wen i exit a match it freezes wen i play guitar hero 2 that also freezes while playing a song i think i know sum ways. its either were playin to much u need to buy 1 of those disks that clean inside the ps3 or any dvds its like a special disk it just goes inside and u play it and it takes like 5 min cuz none of my games have scratches
