Question about Chicco CT 0.5 Sydney Umbrella Stroller
How do you put the pully system back together
  • 20 Answers
What pulley system r u talking botu?
Posted on Jun 26, 2009
Replace ilder pully
Need to disconnect battery, then use a breaker bar to remove tension, remove belt, remove defective part, put back together.
May 15, 2012 | 1998 Plymouth Voyager
How do you put the rewind back together? Is it better to purchase a new unit?
well its not an easy job but it can be done,,,,first you need to put the pully on the spring and wind the spring up tight so it will rewind the starter rope when pulled,,,then tiy the starter rope into the pully,,,easy if you have done it before?
Aug 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
My exercise machine ...i do not know how to put the pully and weights back together
Go to iconservice.com click on manuals input your make and model you will find and manual for your unit.
WEIDER C 875 SYSTEM (WEBE8077)
Jul 12, 2010 | Weider Nutrition Weider WEBE8077 Home Gym...
How to fit a cambelt on a volvo s60 t5
remove drivers wheel then plastic wheel arch then put jack under engine and remove the engine mount then take off fan belt and timing belt cover mark your two top cam pullys and the crank pully then remove your belt and tensioner put new belt and tensioner on making sure all your marks line up then put on the crank pully and turn engine over twice by hand using a ratchett on the crank pully bolt if it turns over and your marks still line up put it all back together and start the car
Mar 14, 2010 | 2002 Volvo S60
I just changed a Timing Belt on my 95 Eagle Talon Esi 2.0 DOHC Non-Turbo, I know the timing is correct, as I started the engine before i put everything else back together. Since I got everything put back...
Sounds like your Hydraulic Timing Belt Tensioner, or could be the Idle Pullys. There's a kit available that includes all needed parts for around $150.00 depending on your location.
Jan 18, 2010 | Eagle Talon Cars & Trucks
Savvy vacuum belt
It is easier when you also take the top off. Then you can put the belt over the roller and re-install it, then put the bottom plate back on, then turn it over, undo the motor and put the belt on the motor pulley, re-install the motor and put the rest back together. To remove the top, thewre are a couple of scres from the bottom, then from the top, remove the Hoover emblem, there is a screw there to remove and the top will come off.
Jul 11, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Jeep CJ-7 304 V8 motor
did you put the washer back on the harmonic balancer this very well could be your problem, and did you use the old balance or a new one.but you are right if they dont line up right the belts wont stay on. give me more info. and i can help you get it straight.
Dec 08, 2007 | Car Audio & Video
Chicco CT 0.5 Sydney Umbrella Stroller Logo
224 people viewed this question
Top Chicco Baby Gear Experts
Rommel Balcita
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Chicco Baby Gear Expert? Answer questions, earn points and help others
