Question about Sharp 32SC26B 32" TV
Slanting Picture The picture seems to slant from the left to the right. This is most noticeable when watching a letter boxed video or a sporting event that has an information bar on the screen. Are there any adjustment that can be made to straighten the picture?
  • 934 Answers
The yoke has probably come loose and tilted.. From the rear of the set looking on the back of the crt you'll find a copper wire wound magnet called the yoke. It terminates on the neck of the yoke with a clamp. With the set off slightly loosen the clamp and turn the yoke assembly in the opposite direction - key word here is slightly - and apply power to check the alignment.
Keep doing this until you achieve the alignment you want. And always remember to unplug the set between attempts.
Posted on Nov 05, 2007
My philips 240b powervision tv, about 10 years old, while watching, all of a sudden the screen video turned into slanting horizontal whilte lines. the input is from setup box. I guess it happened when i...
Slanting horizontal lines indicate that the horizontal hold is out of adjustment. As the components age they change values and don't have the same effect on the circuit. some units have a horizontal hold adjustment pot on the back that can be adjusted to bring the horizontal back to the middle. If the adjustment pot is not on the back the only way to bring the horizontal hold back is on the inside of the unit and this is not a safe proceedure. If the picture was really good before it went bad then it might be worth the cost of repair. If the picture was getting weak (light colors, washed out look) then the repairs are not cost effective (not worth the money to have the unit repaired) There are some tv repair people that work quite a bit cheaper than others. It would be worth a few phone calls to get an estimate and make an informed purchasing decision.
May 01, 2011 | Televison & Video
I have a samsung CT21B500H5 tv when i'm watching in dark picture i see a visible slanting lines on the LCD how can i remove it????
That sounds like interference from somewhere. Doesit do it on all channels or just the odd one?
If it is clear on other channels it is interference.
Jan 08, 2011 | Televison & Video
Power but imediate black screen theres small point in the middle
From the problem you describe, it seems to me that the picture board on your monitor is bad that is why you have slant line and blank screen, i would suggest you first check all the connection to make sure they are all in place and make contact, if all is in place and yet still have blank screen, you will need to replace the picture board on your monitor because the cause of the problem is the picture board.
Replace the picture board on the monitor to solve the problem, once the picture board is replace, the problem is solve.
Take care.
Jul 13, 2010 | AOC 1556NB 15"
HD channels run off the edges
That solution is likely to be found in the cable or satellite box set up menu. Make sure that the output video format (4:3, letterbox, etc.) matches the TV
Jan 24, 2009 | Mitsubishi WS-65315 65" Rear Projection...
Magnavox 27MS3404/17B tube tv picture slanting.
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 02, 2018 | Televison & Video
Slightly slanted screen/picture
your main filter capacitor in power supply has gone defective.
just replace it .
every thing will be normal.
good luck.
Oct 17, 2007 | Toshiba 36AF43 36" TV
Slanted picture!!
This problem might be caused by an external magnetic field. Most modern Sony tv sets have a picture rotation control. Go to the setup menu and select Picture Rotation. Your user guide will explain.
Dec 23, 2006 | Sony KV-32S26 32" TV
Picture slants right to left
Hope you have fixed this problem by now, if that tv is unserviced, I mean if nobody has ever opened it, it could be a problem with the positioning of your tv, just tilt the tv in different positions and find out the position in which it will show the right fit. If it is serviced, especially yoke is changed, this is rare, it could be because the position of yoke is not aligned properly.
Dec 16, 2006 | Philips 27PT5445 27" TV
Slanted picture
Your deflection yoke (a coil around the neck of the picture tube) must have gotten turned. Your can turn the picture upside down by rotating this coil. If your set is in warranty, you should return it. When this "yoke" is adjusted the color is affected too. If you try this yourself you'd void the warranty and mess up your color. Stargazer
Nov 05, 2006 | Philips Magnavox 20MT133S 20" TV
Sharp 32SC26B 32" TV Logo
102 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
