Brother HL-2170W Laser Printer Logo
A
Anonymous Posted on Jun 03, 2014
I fixed the drum and error light but i still can't print
Ron
Level 2:
Scholar:
  • Expert 67 Answers
  • Posted on Jun 05, 2014
 Ron
Expert
Level 2:
Scholar:
Answers
67
Questions
0
Helped
18752
Points
224
Unplug the printer for 20 seconds and then plug it in and turn it on.
Does the printer power on correctly and seem to be ready to print? Are there any flashing or colored lights? If it is connected through a network you can go to the IP address of the printer and see if there are any messages in the control interface. If it is connected usb you can do the same thing through the program that installs with the drivers.
If the printer seems fine then check in Devices and Printers on your computer and double click the printer. ( For Windows, not sure on Macs ) This will tell you if it's paused or if it has a job that is stuck waiting to print. Delete any waiting jobs and unpause it if necessary.
Veronica Bergman
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 10 Answers
Veronica Bergman
Contributor
Level 1:
Welcome Back:
Answers
10
Questions
21
Helped
1319
Points
18
Http://mycomputerbytes.wordpress.com/2011/11/16/reset-brother-hl-2170w-network-settings/
If printing via network and you have not set a static (meaning it doesn't change) ip setting for your printer, then your ip address may have changed. IF this is the case, http://mikebeach.org/2011/03/02/assigning-the-brother-hl-2170w-a-static-ip-address/
Also, have you updated your printer driver? Be sure to go to control panel, device manager, printer, and then uninstall before installing new driver. Also, uninstall/remove the printer.
http://support.brother.com/g/b/downloadtop.aspx?c=us&lang=en&prod=hl2170w_all
Hope this helps.
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
25helpful
Will not print the error light and the drum light flash. Replaced drum but still will not print and error light and the drum lights still flash.
The drum counter will have to be reset, Use the following steps.
1. Open the front door.
2. Press and hold the cancel button (x button) until all the lights flash in in order.
3. Then close the front cover.
This will reset the drum counter so that you can continue to print.
Dell 1700n error light after print job.
double pressing the continue button twice , the printer will give a secondary error code: then check here (link below) : toner is low, with blinking lights = Replacing the Imaging Drum
http://support.dell.com/support/edocs/systems/1700n/en/index.htm
download the manual above and look under Troubleshooting->Maintenance for your printer-> replace imaging drum...
good fortune, please leave rating...
2answers
Orange light is flashing and printer is not printing. It is not the crescent , not the triangle, but the one abve the triangle and below the colored catridge rotation button.
Imaging drum is empty or missing (Error 40204) Light pattern c00187081.jpg Description The imaging drum is empty or missing. The imaging drum light is blinking, and then printer stops printing. An error 40204 is written to the event log. The printer cannot detect the imaging drum correctly. Action
  1. Reinsert or replace the imaging drum.
  2. If the imaging drum light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. Repeat Steps 1 and 2 with a new imaging drum.
  4. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Imaging drum e-label reader is faulty (Error 10004) Light pattern c00187081.jpg Description The imaging drum light is blinking, and then printer stops printing. An error 10004 is written to the event log. The imaging drum e-label reader is faulty and the printer cannot detect the imaging drum correctly. Action
2helpful
2answers
Kyocera FS-1920 error message: "call service 6400:0295998"
Your drum unit is not seated correctly. Look inside for a bent drum ground clip.
1helpful
Drum error
Sounds like it's time for a new drum but, here's the reset procedure that should make the drum light go off and allow printing.
Make sure the machine is turned on and the drum light is blinking. Press and hold the "GO" button for 4 seconds (approx.) until all four lights are lit. When all four are lit, release the "GO" button. Make sure the drum light is off now. The drum is now reset.
THIS WILL NOT IMPROVE THE QUALITY OF PRINT as the drum will need to be replaced in order to do that but it will allow you to continue using the drum until it reaches and unacceptable quality.
Hope that helps you.
Print error
Replacing the drum should fix this issue. The PC drum, aka, photoconductive drum, is light sensitive, if it has been exposed long enough to light, it can cause this problem.
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Norman Weimar
Norman Weimar
k24674
