Question about Dell Dimension C521 PC Desktop
When i press f1 it gose to windows xp but never starts up
  • 478 Answers
Try delete
Posted on Jun 26, 2009
Press f1 start windows
It may be asking you to press the "F1" key because it is having a hardware problem which should be checked, or you may need to adjust the settings in BIOS. It can also be an indication that you need to replace the CMOS battery. Try this: Go to your BIOS and load default settings.2 Mar 2012
Press F1 key to start Windows - Ccm.net
ccm.net/faq/9372-press-f1-key-to-start-windows.
also go to this link might help you out. Press f1 start windows Google Search
Oct 13, 2017 | ASUS Computers & Internet
Primary hard disk failure press f1
Replace the hdd and reinstall windows.
May 22, 2017 | Computers & Internet
When i on my system its start windows and stop and shows hdd error press f1 continue press 2 del f1 i press its booting failed
Your Hard Disk Drive is crashing or has crashed. You need to buy a new hard disk drive, and then you will have to reinstall windows and start over.
Jan 27, 2012 | Mercury Computers & Internet
When I startup my pc I have to press F1 before it starts . I am running windows xp home
This has nothing to do with windows, but is a cmos or bios issue. There should be an error something like, Time incorrect press F1 to continue or F2 to enter setup. Check the error and then press the correct key to enter setup. If the issue is the time, fix the time and date in set up. Most other issues will clear when you exit and save set up.
If you would like more information, please provide the exact wording of the error that you are pressing F1 to continue from.
Dec 14, 2011 | Microsoft Windows XP Home Edition
My computer starts on black screen... drive 1 not found: serial ATA, SATA-2.. strike the F1 to continue, F2 to run.. if i press F1 it says NTLDR is missing what di i do? I have the operating sys. disk..
  • Insert the Windows XP CD-ROM into the CD drive, and then restart the computer.
  • Click to select any options that are required to start the computer from the CD drive if you are prompted.
  • When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  • Press 1 (One) to select windows XP and then hit enter.
  • When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  • At the command prompt, start typing
COPY D:\i386\ntldr C:\ (Considering that D is your CD Rom Drive)
COPY D:\i386\ntdetect C:\ (a file that may also be missing)
Then rebuild the boot configuration boot.ini file by
Attrib -H -R -S C:\boot.ini (if not found skip the next line)
DEL C:\boot.ini
BootCfg /Rebuild
Feb 03, 2011 | Dell Dimension E310 PC Desktop
Hi, When I try to start my Dimemsion 5150C in Windows XP computer, I received one of the following error messages "Floppy diskette seek failure Strike the F1 key to continue, F2 to run the setup...
The "floppy" disk-drive (3.5-inch diskette) on your computer is broken.
Press F1 to ignore the error, and to boot from your C: drive.
Or, press F2 to enter BIOS SETUP, and then navigate through those "setup" screens to tell the computer to "disable floppy seek", or change the setting from "3.5 1.44Mb drive" to "none".
Or, take the computer to a technician, and buy a replacement disk-drive, and get it installed.
Sep 12, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Windows xp always starts with keyboard
Go the control panel> device manager and uninstall the keyboard but keep the drivers. When the system reboots it will recognize the hardware and reload the drivers. If asked, let windows search online for an updated driver. When it is finished installing the hardware, reboot to check the results.
Sep 15, 2009 | Computers & Internet
Help!!!!!
when you turn on the computer, press F8 before the xp logo shows up. then choose "Safe Mode".
if widows loads ok, a window will come up. click no to restore to a previous date.
If windows does NOT load, you have to re-install windows. Put the CD that came with your computer and run the setup.
NOTE: if you want to keep your files, do not choose any options that format your drive.
Aug 06, 2008 | Computers & Internet
Formating the Pc
Is the Hard Drive NEW and unused ?
If YES, XP should install no problem.
If NO,
Format with DOS boot disk and then install.
Mar 14, 2008 | Computers & Internet
Toshiba Satelite
Can you tell me if your operating system is Windows XP. when it shows the windows screen is it the "boot up screen" showing and returns to the same thing?
Sep 17, 2007 | Toshiba Satellite A15-S129 Notebook
Dell Dimension C521 PC Desktop Logo
37 people viewed this question
Alun Cox
