My washer works great but takes forever to fill, I have A good water supply line, is there A pump in the washer? or could something inside the washer be plugged???
  • 97 Answers
Hello Friend, Your problem is simple. Your water inlet valve screen is clogged preventing the water from flowing at maximum pressure. here's what you do: just remove the water supply hoses at back of washer and look inside the hot and cold inlet openings that you just removed the water hoses from. You should see a filter screen in each of them. remove the screens, clean them or just replace with new screens. Also check each end of water supply hoses for the same type of filter screen and clean or replace them as well. Happy to help, Tim.
Posted on Jun 25, 2009
GE P563 takes forever to fill. I think some internal screen may be blocked. How would I get inside it to clean the screen and improve water flow? Screen in hoses to washer are fine.
Most manufacturers put screens inside the water valve where you screw the supply hoses onto the valve. You would need to take the hoses off and look into the valve. When I work on washers that have this type of problem, I usually take those off and use a toothbrush to clean them or I replace them with screens in the hose itself. Hope this helps!
May 05, 2015 | GE Washing Machines
Washer is working during spin, meaning it's still
Hi, a Kenmore washer that is not filling with water may have clogged inlet screens. Place a bucket underneath the hoses to catch any leftover water. Unplug the washer and turn off the water supply. Remove the water hoses from the back of the washer and inspect the screens inside the inlet ports. Often, these clog with sediment. Clean the screens with a small toothbrush. After cleaning, reattach the hoses and turn the water supply and power back on.
Another reason the washer might not fill is something interfering with the water pump. Check the connecting hoses on the water pump to make sure they are not clogged. With the hoses disconnected, check the water pump for obstructions.
Jun 19, 2011 | Kenmore 24722 Top Load Washer
Takes forever to fill water bearly comes out
The water line valves will need to be replaced. The are electrically operated valves so remove all power before replacing them. They are located under the hood, top rear of the machine.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Initial fill up is fine, but when filling up to rinse it takes forever- water just comes in at a sprinkle
Mkae sure to check the water supply lines and make sure there is nothing,restricting the water flow,you may need to replace the water valves
Aug 29, 2010 | Frigidaire FEX831CS Top Load Stacked...
Will not fill up with water before starting, it takes about 3-4 times brfore unit will run with full amount of water. loads take forever.
dish washers have a fill valve. the water supply line most likly has a net like filter that is stoped up with trash. Or fill valve is bad.
same thing happens to washing mashines. when they start filling up very slow you will TURN OFF water supply and diconect hose, look inside and there is the problem.
May 09, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Washer is taking forever to go through rinse and spin. It ends with a code nd. Clothes are still wet and soapy.
HI, check the following to address this issue.
1. Clogged drain line or water pump
Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine).
2. Water Pump
If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
**The most common issue will be an obstructed hose or, line
Sep 20, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water won't dump
When you replace the pump, always to remember to makes sure the pump is pushed all the way in so that the shaft has a good grip. Try taking it out and pushing it all the way in. The 4 legs should touch the motor, as you put the 2 little clamps on the top and bottom.
Good luck, I'm pretty sure it's something really basic with the pump :)
Jul 19, 2009 | Whirlpool LTE6234D Top Load Stacked...
Moved to new home hooked everything up washer will not fill
ther's something wrong with your water supply to the washer the humming noise is the solenoid on water valve working check water taps to make sure there is water there and hoses are not kinked
Jun 24, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Cold water trickles, hot water fills fast as normal
where your water lines connect there is a sc reen inside and if it is clogged with rust lime and or mineral deposit. it needs cleaned out. you can pull it out with a ice pick or something pointy. Check your screen first and if that doesn't fix ya then yes replace the unit.
Apr 18, 2009 | Kenmore 23822 Top Load Washer
GE Washing machine cold water barely dribbles in
Yes remove the hose from where it connects to washer look inside water valve and remove plastic screen with needle nose pliers Without damaging it. Also make sure that it gets back in proper as the valve will be damaged without it.
Jan 19, 2008 | Washing Machines
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
