Question about Aurora Electronics AS1015CD Cross-Cut Shredder
Shredder won't stop running
I have to turn shredder off after shredding. It will not stop on it's own in auto.
  • 21 Answers
You probably need to clean out some debris from the shredder's sensor. The sensor is usually a small switch that is pushed into the "on" position when a piece of paper goes through. If there is some paper sticking this switch "on", then the shredder will not shut off. You can use a small needle nose pliers, or a tweezer to get the debris out. Make sure to unplug the unit before cleaning!
Hoep that helps, good luck!
Posted on Jun 25, 2009
Use an air compressor to blow it out and clean everything.
Posted on Sep 06, 2012
SOURCE: My shredder keeps running and won't stop in on/auto mode
Does the shredder have the electronic eye to sense paper? Sometimes dust will collect on the sensor causing it to keep running.
Posted on Apr 16, 2007
SOURCE: shredder
Check for stuck paper and remove if any. Then check if motor is ok with a multimeter and also main switch.
Posted on May 21, 2007
venexcsd
  • 1185 Answers
SOURCE: the shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Posted on Jun 12, 2009
FixinFax
  • 3085 Answers
SOURCE: Staples SPL-X21G shredder won't turn off
Blow canned air down into the feed slot.
Posted on Sep 22, 2009
  • 41 Answers
SOURCE: Staples 16 sheet titanium shredder keeps running
dirty sensors or need replacing
Posted on May 10, 2010
My shredder won't shred
If the motor will not run, then probably there's paper clogged in the shredder. Turn over the shredder, after unplugging the power cord, and remove the papers.
If the motor will run but not shredding any paper, then the drive gear has broken teeth. This is not usually worth fixing.
Hope this helps.
Mar 27, 2015 | Shredder Office Equipment & Supplies
My Staples 16 sheet Microcut shredder starts the shredding operation after I push the button and continues the shredding operation after I shred a paper. How can I get the shredding mechanism to stop...
It's a tedious process to clean it out. Most auto switch shredders use either a tiny little lever or an optical sensor in the paper feed slot. Usually removing the shred head, picking all the paper out and blasting all the dust out with air will clean it up. Then run a few sheets of paper with shredder lubricant (basically clean mineral oil) to oil the blades and it should be good to go again. Just be careful cleaning that cutting head. I've donated many drops of blood to office equipment over the years.
Mar 14, 2015 | Staples Office Equipment & Supplies
Staples Shredder SPL-S302D I think I need a new
Take a look underneath where the shredding mechanism is and remove every bit of paper. It is a messy job, but necessary. When you finish, the shredder probably will function normally. Also, ignore the advertised sheet capacity and feed one sheet at a time. Stop when the bin is half full, dump it, and repeat the bit-by-bit cleaning process. I just went thorough this exercise yesterday!
Feb 16, 2018 | Office Equipment & Supplies
WON'T STOP SHREDDING WHEN ON AUTO
You will probably find some shredded paper is blocking the sensor in the middle of the paper feed slot
Feb 26, 2013 | Black & Decker BD10P Shredder
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Hello my nane is Tom. The shredder doesn't work. It will run in reverse but when I turn it to forward it run for a second or two than stops. I looked and I can't see anything jamed in it.
I got mine to work by running it on reverse for a moment then sliding it to auto. It stopped. Then I did it again. This time auto ran just for a second then stopped. I did it a third time but I had a sheet of paper ready in the feeder. Ran on reverse. Slid it to auto and it took the paper and shred it. I did it a fourth time. Reverse slide auto and feed shred the paper. Fifth time Auto shred the paper without reverse. :)
Aug 30, 2011 | Aurora Electronics AS662C Shredder
Shredder stops when paper put in
Solution: called customer support, who said "It's broken.? But, it was still under warrantee, so I sent it back for a new one.
Dec 22, 2009 | OfficeMax 0M96431 Shredder
UNPLUG THE SHREDDER.
If this model has electronic eyes (optics) to control the auto-start/stop function and you oil the cutters, chances are the optics are contaminated with shredder oil. Take a cotton swab with a little alchohol and clean and dry the optics.
If you removed the top cover, it is a possibility that you disconnected the wires from the PC Board.
Mar 01, 2009 | Royal VF1012mx Shredder
Aurora Electronics AS1015CD Cross-Cut Shredder Logo
537 people viewed this question
Top Aurora Electronics Office Equipment & Supplies Experts
k24674
skiffy99
skiffy99
Level 1 Expert
Dabu42
Level 1 Expert
Are you an Aurora Electronics Office Equipment and Supply Expert? Answer questions, earn points and help others
