Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Water in dispenser at end of wash cycle.....have checked the owners manual, troubleshooting area and cannot find anything that addresses this. Any ideas? Thanks, Bill
  • 1 more comment
  • Liana Nov 10, 2007
    I have this same problem, and I have cleaned out the dispenser thinking that it may have been plugged, but it was fine...its still happening. Not only that, my last wash leaked out the back which looks like from excessive suds. I use HE (High Efficiency) detergent, so I'm not understanding what could be wrong.
  • Anonymous Dec 12, 2007
    Definitely have the same problem. Doesn't seem consistent though. Probably happens about 40% of the time and doesn't seem to make a difference with load size.....??
    Definitely have the same problem. Water usually sitting in the detergent/softener/bleach cups after load is done. Doesn't matter what load size, water temp. etc. Help??
    New Friend:
  • 60 Answers
The cups work on a siphon so they will never be completely empty but check the level of the unit if there seems to be alot left in the cups. For the excessive suds, even if you're using HE detergent you are probably using too much. Don't put more then a tablespoon in per load. The suds may have come out of the clothes you were washing in that load too.
Posted on Dec 20, 2007
Bosch Maxx softener dispenser full of water at end of cycle
it seems that there must be a blockage in the siphon tank softener.
Remove the drawer and wash well, remove the siphon softener (just pull up)
Dec 22, 2013 | Washing Machines
Fabric Soft and Bleach despenser on MAYTAG TL FAV6800 won't drain
I'll see if I can help. Can you just clarify if by won't drain. Does it look like no water flow is flushing the the Bleach and Fabric Softener dispensers?
The Fabric Softener dispenser could be clogged but I suspect the dispenser’s valves are not opening to flush the dispenser’s. If the Fabric Softener dispenser is clogged you can flush with White Vinegar solution and clean exit port with a pipe cleaner. I do not suspect a clog with the Bleach dispenser.
You could go into Service Mode and turn on the water valves for the dispensers to check if water is sent to the dispensers.
If you have no water flow to the Softener dispenser here is the non technical troubleshooting I would take. Go into Service Mode (page 14 of the Service manual) by Pressing Enviro Plus and Spin Only keys (simultaneously) for three seconds or until the console beeps.
Now go to page 16 to Service Manual and enter Board Output Test by pressing the Delicates key. This will lock the lid. Now press the Wrinkle Control Key Pad on the console. The Control Board will send 120VAC to the bleach dispenser water valve. Did you hear the Solenoid hum? If so and you have no water flow diverted to the Softener dispenser the solenoid valve may be stuck closed. If you did not hear the solenoid valve hum the solenoid field coil may be open. Do the same process for the Bleach dispenser water valve with Bulky Items Key Pad.
Final technical troubleshooting as a technical owner of the machine would be to take my DVM and verify 120VAC from the Control Board to the Bleach/Fabric Softener dispenser valves.
See page 36 lower left hand corner is the Bleach/Softener dispenser valve.
Here is the Service Manual for reference. Sears Parts Direct for reference.
The Part Number for the Dispenser Valve is 25001043 you can order from this site or search the internet for best price.
Good luck…….Rich
Mar 09, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Fabric softener/bleach dispenser full of water
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 08, 2009 | Kenmore 46462 Front Load Washer
Water remains under rubber seal. Water too high in bleach dispen.
Did you try taking the dispenser tray apart and cleaning it? The exit ports tend to clog over time. Best thing I have found is to remove the tray at the end of wash day, rinse it out, dry it and put it only partially in the machine, thereby allowing air circulation. Some water will always remain at the end of the wash cycle...inherent in the design.
As for the gasket, you'll have to wipe it down at the end of wash day and leave the door open to dry everything out. I leave mine open all the time.
May 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Apr 26, 2009 | LG Washing Machines
Leaking // bleach/fabric softener dispener isnt emptying
Remove the dispenser cup and clean it. Be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 10, 2009 | Washing Machines
The softener holder just fills with water but will not drain.
Is water left in the dispenser at the end of the cycle?
About two tablespoons of water remaining in the dispenser compartment at the end of the cycle is normal. At the end of the wash cycle, fresh water automatically cleans the dispenser. Check that the cycle is complete before opening the dispenser drawer.
Is the dispenser drawer clogged?
A clogged dispenser can block the flow of water through the dispenser and cause water to leak out. Manually remove the dispenser, and clean any leftover detergent or additives that could clog the flow of water through the dispenser. Also, check that the detergent drawer is always completely closed during the cycle. If the drawer is not closed completely, water can leak out onto the floor.
Are the additives dispensing too early?
Here are a few things that can cause the additives (detergent, fabric softener or liquid chlorine bleach) to dispense early:
  • Check that the dispenser is not overfilled. Do not fill past the MAX fill lines on the dispenser. Overfilling can cause early dispensing of liquid chlorine bleach and/or fabric softener.
  • Check that the detergent separator is in the correct position. For liquid detergent, the separator should be in the front position. For powdered detergent, the separator should be in the rear position. If the separator is in the rear position while you are using liquid detergent, it will dispense immediately, which is not how it is designed to work.
  • Use powdered HE detergent when using the DELAY WASH option. Liquid detergent may dispense prior to the start of wash.
Are the additives dispensing too late?
The additives will not dispense until the proper time if the DELAY WASH option is selected.
Dec 17, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch Next Pemium Washer-intermittent detergent dispensing cycle
Sounds like the valve that lets the water in on the dispensing cycle is sticking, if you can hear the valve buzzing i would certainly suspect it to be faulty
Nov 23, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
93 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
