Question about Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429
Its not getting cold enough. It has been cleaned.
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 23, 2010
Freezer is not cold enough, even though the control panel says that the temperature is where it should be.
pull the panels inside and check the fan usually in a fridge freezer the fan cacks out or is full of ice clean it out and clean the overflow tube if fridge is cold enough then it is the freezer fan
Jun 07, 2015 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
Freezer is not freezing
Good Morning Friend,
I understand that your Frigidaire freezer is not getting cold enough to freeze your food. I suggest cleaning the compressor, underneath your appliance, by using an attachment on your vacuum. I also suggest lowering the temperature and giving your freezer 4-24 hours to stabilize at that temperature. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dishwasher status has changed successfully. If further troubleshooting is needed, please leave me the model number of your freezer. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Frigidaire Freezers
What can I do to get the ice cream to be frozen?
It might be a good idea to clean the condeser coil. If the coil is blocked, your freezer will not get cold enough.
Jun 03, 2014 | Sub-Zero Freezers
NOT GETTING COLD ENOUGH 25 DEGREES CLEANED
High suction pressure is telling you there is a blockage in the coolant system usually. It most often occurs at the drier. If the drier is clogged it will cause the symptom you describe. This may sound crazy but take two wooden handles (hammers whatever) but WOOD and strike the drier simultaniously. (I.e at the same tame with the handles. Don't be afraid to give it a good whack.. just don't dent it or the lines. It may or may not snap out of it. Additionally the capillary tube can cause the exact same symptom. You have coolant flow.. just not enough.
You may sadly have to have to system bleed off (recaptured coolant) and purged until restriction vanishes with nitrogen if you can not find the current restriction. These can be real easy or a nightmare there is no in between.
Thanks for choosing FixYa.
Kelly
Aug 22, 2010 | Delfield Freezer 6125XL-S
What cause the freezer to not get cold enough?
Make sure condenser is clean with proper air flow around freezer.
May 07, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
FRT21FR6A Frigidaire Top freezer not freezing and refrigerator not getting cold enough...what could be the problem? Just got it used
Have you cleaned out all the lint under the frig, Use a vacuum and a brush clean from front and rear of the frig. if not then the freon is low and it needs a charge
Aug 19, 2009 | Freezers
Commercial freezer (Randall) with a Ranco thermostat, not cooling
clean condenser? is evaporator free of ice? may need defrosting or low on freon. Tom
Jun 30, 2009 | Freezers
Freezer not getting cold enough to freeze.
First culprit could be a refrigerant leak and needs to be charged. If the evaporator is frozen solid it won't push enough sub zero air to freeze. Call a trusted ac&or repair man
Sep 23, 2017 | Frigidaire Freezers
My GE upright freezer does not get cold.
Sounds like the system is low on freon. The other common problem is a dirty condenser. Insure the condenser is clean, if it is. You will need to charge the system with freon. Which only a qualified refrigeration tech should do.
Nov 28, 2008 | GE 13.7 cu. ft. General Electric Upright...
Hoshizaki ice machine repair?
seems that its low on water or float switch is bad. try to clean float
Sep 02, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore 13.7 cu. ft. / 388 liter Upright Freezer 23429 Logo
88 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
