Question about Dell 1600n All-In-One Laser Printer
Dell 1600n and vertucal line while scanning
Our company uses Dell 1600n as a primary hub for printing, copying and scanning. However, lately all the scanned copies have a black vertical line in the middle of the page. We changed a toner, just in case, but nothing was resolved. Cleaning didn't help either. The line happens only while scanning, whereas copying and printing is fine.
Any comments as how to fix the problem would be appreciated!
  • 3 more comments
  • ANLaw Dec 04, 2007
    Our office has the same problem. It is only through the ADF, so we know that is where the problem originates. What do we need to do to fix it?
  • Jim Kainen Jan 20, 2009
    Mine does it only while faxing, not while copying with the ADF.
  • Anonymous Jan 24, 2009
    need a solution!
  • Anonymous Apr 09, 2009
    I have the same problem. Used doc feeder & flatbed but it does not work.
  • Anonymous Mar 16, 2014
    We just got an older Bizhub 211 and it prints and copies fine. I am using Win7 64bit. When I scan using Adobe Pro 10 I only get part of the page. Using the printer cable not a Network. Help?
  • 4 Answers
Any difference between using the document feeder and just the flat bed?
Posted on Nov 29, 2007
I have a dell 1600n printer. Though it prints but the copier is not functioning. The copier light does not come up. It brings a command, "Unlock scanner, then press cancel"
1) Remove the label completely from the scanner module by gently pulling it. The scan unlock switch automatically moves FORWARD to the unlock position.
2) NOTE: When you are moving the multi-function printer or do not intend to use it for a long period of time, move the switch BACKWARD to the lock position. To scan or copy a document, the switch must be unlocked.
Please see page 4 of the owners manual for more details. Here's a link in case you've lost yours:
I hope this response helps you out.
I wish you the very best of luck!
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 22, 2011 | Dell 1600n All-In-One Laser Printer
Dell 1600n. I have to reset the printer constantly.
Do a hard reset of printer to erase all memories. Then also uninstall and reinstall the driver and see what happens. Also make sure that you are using the correct driver for your OS
Sep 12, 2017 | Dell 1600n All-In-One Laser Printer
Mac user can't scan on Dell MFP 1600n
That's because you can't scan over wireless. In order to scan, you need to be connected via USB, so I hope you've got a MacBook...
Jul 24, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n to be used on an imac
Hello! Unfortunately, Dell printers mainly supply Windows drivers on their website. To print to this printer, your new iMac will probably pull a generic driver to use with the printer. It should still work no problem, as you're saying, however you won't be able to use the software that's available on the PC. The downloads available for your Dell printer are here:
Dell 1600n Printer Downloads
You can tell by clicking that link and looking under Operating System that only Windows operating systems are available, as well as the software shown below, which is only made for Windows based systems. As for the PaperPort software, that program is made by a company called Nuance. When you purchased your printer, you most likely received a trial or full OEM version from Dell along with your new printer as a software bundle deal. From what I can see, the software is only Windows based. Sorry!
Below is the link to a free viewer that can still read your PaperPort files:
PaperPort Viewer for PC and Mac OS [Free]
Mar 16, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Slow Printing
Most times the PCL driver will work just fine for printing .pdf documents. Occasionally you will need to us a PS driver to print .dpf docutments. PCL was designed to work best with MS Word, Excel, etc programs and PS drivers were designed to work best with Adobe .pdf.
One way to see if you have the PS driver already installed, is to (in Windows XP) start>control panel>printers and faxes>in here look for an Icon that represents your printer that has PS in place of the PCL. If this is installed then when you go to print your docuement, choose this icon to print with.
If you do not have the PS driver already installed, try adding the printer to your system. You would do this by (Windows XP) start>control panel>printers and faxes>add a printer wizard>Next>Choose your connection(local or network)>Next>Select a printer port>Next>Install Printer Software(If you have downloaded the most recent drivers, choose have disk and navigate to where you saved it. If you have the CD, use have disk and navigate on the CD to where the PS driver is>Next>You may or may not get the next window asking you to choose whick model of printer you are installing, it varies from printer to printer. From here it is pretty straight foward, just read the wizard and click next. The last step you will need to click finish for the drivers to actually install.
As a side note, not all printers have a PS driver available.
Feb 23, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n Scanner bulb doesn't light up
Scanners, when broken, are irreparable. (or at least thats what I was told when I worked for Dell)
Feb 01, 2009 | Dell 1600n All-In-One Laser Printer
Dell 1600n - nothing happening when I push Scan Button
I had the same problem as both posters.
I downloaded the most recent firmware from dell (3.11T, A03) and reinstalled it. When you run the program, there's a radio button that says "printer" and one that says "network". I did the one that said "printer" and nothing happened. Then I ran the firmware update again and picked the one that said "network" and it started working shortly afterward.
I'm assuming that some component of firmware in the network card was messed up. I could still use the network printing but the "scan" button wasn't working. This fixed it for me. Your Mileage May Vary.
Aug 19, 2008 | Dell 1600n All-In-One Laser Printer
Document Jam in Dell 1600n
The Automatic Document Feed (ADF) has a white rubber pad that wears out. You can find it by opening the ADF cover and removing the roller bar. Under that is the white rubber pad. Pinch the sides together and the assembley comes out. Contact Dell for the replacement. You may also refer to the Dell 1600n Owners Manual for instructions.
Jun 14, 2008 | Dell 1600n All-In-One Laser Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1600n ADF Problem
You have either a piece of dust or a scratch on the scanning glass. This will show up as a line because the paper is pulled across the point.
Nov 12, 2007 | Dell 1600n All-In-One Laser Printer
Dell 1600n All-In-One Laser Printer Logo
416 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
