Question about Optoma HD70 DLP Projector
Replaced lamp now projecter will not turn on hd70
I had a similar situation, but we fixed it.  I can't exactly tell you why it worked nor whether or not it will for you.  Here's the deal.
First, take your lamp out and re-seat it.  This is one of the easiest ways to get a projector not to power up.
In our case, the thing would fire up, show us the Optoma logo, the blue screen, and then within about 15 seconds, it shut down, lamp fail light came on, and only a hard power reset would let us try again.  The bulb was good; after all, it came on, right?
So, we kept playing this game of power up, fail, unplug, replug.  I gave up and went to do something else.  I came back to the projector, needing it to let me see a screen to configure (weird I know, but that's how it was).  Anyhow, at this point, the projector stayed on, no problems.  So, I kept it running through the night with a kitchen timer on.  After 5 1/2 hours without failure, we knew we were set.
The point?  If it's powering up and showing picture for even a brief period, try cycling it several times.  However, if it's overheating or showing any other signs of distress, you may make it worse using my approach.  I think we may have just been lucky or the projector gnomes came in the night.
Posted on Jul 26, 2009
What's your problem?My hd70 stopped working: when i go to turn it on you can hear the fan spin up but where as in the past there is a brief delay and then the bulb lights up, there is now a long pause
It will be worthwhile to test the lamp on another unit or at a test center to confirm as the fault seems to represent a faulty lamp. If this is confirmed then the we can proceed to access the voltage on the lamp , if so the trip is due to low delivery from the power supply section and so it trips on loading of the lamp.
Dec 12, 2011 | Optoma HD70 DLP Projector
I have a Optoma projector HD70 How do you reset the lamp operating time?
hi,
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
ok
Jul 08, 2011 | Optoma HD70 DLP Projector
How do Ichange the lamp on my hd70.
Look in page 40 of your projector's User's Manual.
If you don't have the manual, you can download it from OPTOMA support pages: OPTOMA HD70 USER'S MANUAL
Oct 11, 2010 | Optoma HD70 DLP Projector
Used my OPTOMA HD70 ABOUT 2years now -and had to replace the lamp i unplugged it and when turning it back on to work - it does not start , it`s dead the green led lamp does not flicker , does not work...
There is a switch on the side where you insert the lamp, it's black with a metal contact. If, when the lamp cover is replaced, it does not "activate" this switch for some reason (i.e. it is loose or perhaps bent) then the projector will not power at all.
Just remove the lamp and take a look at the switch for possible damage incurred from when you replaced the lamp.
Sep 29, 2010 | Optoma HD70 DLP Projector
HD70 DLP Projector: after replacing bulb warning message of "replaceme...
You need to reset the light counter. Access through right most menu item. Then arrow down to lamp settings.
May 17, 2010 | Optoma HD70 DLP Projector
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
Good luck!!
Feb 23, 2010 | Optoma HD70 DLP Projector
How do you install a new bulb in the Optoma HD70 projector. Got a new bulb but no instructions
unscrew the screw on the lamp door, unscrew the lamp screws, pull the lamp out, replace with new lamp (making sure it's securely plugged in), screw it in, replace the door, plug the projector in, turn it on, enjoy!
Nov 07, 2009 | Optoma HD70 DLP Projector
Hi, I have an Optoma Hd70 and it keeps turning off after about a 1 min and the temperature indication is blinking red. Is there an airfilter I can clean or something?
Sounds like there is a overheat sensor failed in this unit in the lamp balast sure a cloaged filter could heat the unit as well so yeah check that..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 03, 2009 | Optoma HD70 DLP Projector
Optoma HD70 DLP Projector Logo
807 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
