Question about Philips Televison & Video
No picture but audio works on a Philips Mod. 55pp9363h projection television. Checked 2 ceramic fuses still good, is there another?
  • bfritzen Jun 25, 2009
    Haven't tried it yet will let you know Thanks
  • 3,230 Answers
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Powering down the set or putting it in standby may have allowed the power supply to cool. Weak capacitors often go out of spec when they cool, thus preventing a section of the power supply from firing up properly again. There is a simple trick...just warm the back of the TV with a hair dryer for 5-7 mins after you have unplugged the TV. Look for the little areas of holes in the back panel of TV. Use these as your guide at where to use the hairdryer, but don't hold the dryer too close (say 5-6inches away). (Make sure the dryer is on High heat). If the TV doesn't turn on after you have heated it up (like it tries to come on but then turns off) you need to unplug the TV again, this resets it. And repeat those steps till it works. Resetting the TV after it fails to turn on is the key.
Good Luck!!
Thanks
Posted on Jun 25, 2009
Bulb out in a Phillips model #55PP9363H/17
you can get a bulb at ( discount-merchant.com) these guys are pretty good as far as availability. prices are also reasonable.
Mar 29, 2010 | Philips 55PP9363 55" Rear Projection...
Magnavox 51MP392H. I have no picture, but do have sound.
Check with the team at www.TvRepairKits.com for a kit. They seem to know the Magnavox sets inside and out.
Aug 02, 2009 | Philips Magnavox 51MP392H Rear Projection...
Sound but no picture
Common problem - Its most likely the HVG on this model. www.TvRepairKits.com has instructions on how to get it fixed.
Apr 17, 2009 | Philips 55PW9363 55" Rear Projection...
Craked screen
You can find a new OEM Philips replacement lenticular screen and Fresnal screen for a model # 55PP9363H17 from a major Philips distributor at the following links:
Philips 55PP9363H/17 Replacement Part Lenticular Screen
Philips 55PP9363H/17 Replacement Part Fresnal Screen
And here's a link for the protection screen if needed:
Philips 55PP9363H/17 Replacement Part Protection Screen
Apr 02, 2009 | Philips 55PP9363 55" Rear Projection...
Turns on but no picture or sound.
please check the connection wire/cable that gives power to your tv. if no fuses are blown. it may be a capacitor problem.
Mar 30, 2008 | Philips 50P8341 50" Rear Projection...
No picture but sound
It could be, but usually something else has caused the fuse to blow. What is the chassis number to your set?
Feb 14, 2008 | Philips 60PP9202 60" Rear Projection...
I have projection TV 55PP9363H/17 SOUND NO PICTURE.
check the horizontal output transistor, it could be open.
Jun 19, 2007 | Philips 60PP9352 60" Rear Projection...
Unit power up have sound but no picture.
Check the damper diode and the protection resistor in the High Voltage circuit. Good Luck.
Jun 18, 2007 | Philips 55PP9363 55" Rear Projection...
Televison & Video Logo
35 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
