Question about Logitech Attack 3 Joystick
Throttle will not reduce below 30percent when down all the way .os is xp flight sim version x
Downloaded a simular jet that has a better indicator as to when spoiler is on or off.with some buttons that i do not know what their markings mean .or what they do. i change from lear which has a better panel that i understand but has a poor indicator as to when spoiler is in use. i use spoiler and flaps to control speed when airport or runway is in sight and with auto pilot off.
however still very difficult to taxi at airport due to the throttle above 25 percent.
Posted on Jun 27, 2009
I loaded flight simulator 2004 on my new computer with windows 8.1. It loaded fine. After when I clicked on the flight simulator icon, the program will not run.
if you ck the box the game came in you will see that its only 4 win2k and maybe win-xp depending on the time you bought it , it wont run in a windows version that was created long after it was written , now that being said , win 2kpro version does have a backwards compatibility version , but then the other newer software you have loaded will not run stable and is prone to crash"s (blue screen of death)
a possible solution to your problem is something like I've done ,I've taken a old laptop with win xp running on it ,and islanded it (never connects to internet or network) so that m-soft cant ever shut it off this one I load all my great ole games to it (flight sim, trainz ,etc.) and it works just fine
Sep 28, 2015 | Microsoft Flight Simulator 2004
Tip
Learn About an Aircraft, Part 3
, ://i.fixya.nethttp://i.fixya.net25650279-w123deulyqo0pc5nhlq3ghvj-3-0.jpg">
  • Straight and Level Cruise:
Start by setting the RPM to a cruise setting of 2200 RPM, using the throttle. This should give us a cruise speed of about 108 Knots.
Use the yoke to maintain level flight by keeping the small aircraft symbol level and exactly on the "Artificial Horizon" line of the six pack . Keep scanning the rest of the six pack to help maintain level flight. Scanning the six pack will show if you are going straight or turning, climbing or descending or if the airspeed or altitude starts to change. Always use small corrections to the aircraft's attitudes and wait to see the response.
  • Climbing Phase:
We will climb by increasing the throttle to full throttle. Now you can pull back on the yoke to raise the aircraft nose to about ten degrees above the horizon. Now set your climb speed (using the yoke), by changing this 10 degree climb, until you have an airspeed of about 80 knots. meanwhile continuing to scan the six pack at all times and make sure that nothing is changing that you don't want to change. Scanning the six pack will show if you are going straight or turning. or if the airspeed starts to change.
This Aircraft will stall (in a turn) at approximately 53 knots (no flaps) so keep your turns shallow and avoid any speed below 75 knots to allow yourself a margin of safety. Always use small corrections to the aircraft's attitudes and stay well out of any limit zones that are indicated on the instruments.
  • Descent Phase:
A descent to a lower altitude is done by reducing the throttle to an engine speed of about 1500 RPM while setting the air/fuel mixture at full rich (red knob fully inward). If you intend to be descending a long time at low engine power, then you should use carburetor heat to prevent icing. At reduced RPM, the engine will not be producing as much heat so we may have to put on the carburetor heat, or you can occasionally increase the engine speed for a minute to gain some heat and clear the engine.
on Apr 16, 2015 | Sport & Outdoor - Others
Loaded but wont run when activated
Check this link for more info...
Also don't know your OS ?
Flight Simulator 2004 doesn't run correctly on Windows 8. It runs on my Windows 8 laptop bought in April 2013. But, none of the aircraft, including any add-ons, show up in the preview window - it is always black. Also, If I download weather and try to save a flight, when I go back to that "saved" flight, it always reverts to the default flight with the Cessna @ the default airport. If anyone knows how to make the flights save, on the Windows 8 platform, please let me know - likewise, with the aircraft previews. Flight Simulator 2004 did quite well on the Windows XP platform for me.
Apr 18, 2014 | Microsoft Flight Simulator 2004 Update
Sir i have china NOKIA E 71 copy and flight mode is activated in it. How to deactivate flight mode in it?
hi
i am hanzilla
you have selected the flight mode so your mobile cannot access your sim card the solution for this mobile is given below
first open the "manue"
then open the "setting" option
then open "duel sim setting"(if your Mobile has duel sim other vise select sim setting)
then select the option you want to do (exept flight mode)
thanx
Jan 25, 2011 | Handmark Software MobileLists (950142) for...
When i on my phone it shows the message called activate your sim in flight mode then i press any key it dont work........
When you switch on the mobile you get Activate your sim in flight mode because the flight query in settings is out to ON.
When it asks please press NO or YES it goes into the mobile phone.
To OFF the flight query please follow the below step
Menu > Settings > Phone > Flight query > OFF
Thank You
Aug 18, 2010 | Nokia 3110 Cellular Phone
Speed doesn't work
The markings on the TQ are not to be used literally. I suggest you use it to get the speed you want on your gauge and ignore markings on the TQ iteslf. Try re-calibrating in your sim program so it knows what the full range of the throttle is.
Apr 26, 2010 | Saitek Pro Flight Yoke System Flight...
I dont know how to fly in microsoft flight simulator x demo and there is no tutorial in the demo
Yes the full version includes a learning center and has some instructor missions that teach you how to fly gradually. It is well worth grabbing the full version. Look for Flight Simulator X Gold Edition. This includes the FSX program plus the Acceleration Expansion pack bundled together. This bundle has all the latest fixes and patches deployed by Microsoft incorporated into it as well.
For more detailed flight lessons, grab a flight simulator magazine subscription. One like Computer Pilot Magazine is dedicated to Flight Simulator X and other sims and regularly features detailed flight lessons etc.
Feb 18, 2009 | Microsoft Flight Simulator X for Windows
Logitech Attack 3 Joystick Logo
281 people viewed this question
Top Logitech Video Game Consoles & Games Experts
Zhenya Ogorodnikov
Alun Cox
Are you a Logitech Video Game Console and Game Expert? Answer questions, earn points and help others
