Question about RCA RS2625 CD Shelf System
Sound Won't play
I was listening to my stereo and something popped and the sound stopped working. It still registers that its playing and if I plug headphones into it the sound comes through them but it won't come through the speakers. I switched the speaker cables around but nothing changed, and I checked the fuses and they are fine and nothing looks burnt or blown.
  • 1 more comment
  • cliffwc Nov 05, 2007
    Also I wasn't listening to it loud.
  • Cosby1260 Mar 15, 2008
    No sound at all
  • Anonymous May 14, 2009
    No Sound at all ?
We had the same problem with our last rca stereo. I don't remember what model it was. My husband took it apart and found that there was and area on the circuit board that was fried. I don't know of any other solution then the one we chose. Trash it. I'm not expert but I would imagine that you could by a new stereo for the price of replacing that circuit board. Just don't buy an rca. They are junk. Our new rca just quit playing cds.
Posted on Nov 06, 2007
Hs 200 harman kardon stop working
Check the capasitors in the power supply. These often have a popped top surface, not flat like normal. These need to be changed. It can be as many as 10-15 bad ones.
Feb 14, 2015 | Harman Kardon HS 200 Theater System
The kenwood KDC-MP333 in my truck is connected to a set of kenwood speakers. But when I turn it on they won't work the stereo still shows the display but when I turn the stereo on it makes a sort of...
Disconnect the speakers and try it with another speaker or speakers not in the truck. If it works, the speakers or the wires to them are messed up. If it doesn't you probably damaged the output capacitor in the radio by turning it on without speakers attached. Realize that the speakers are part of the radio circuit and act as resistance. Without them, there is no resistance and it puts a strain on the radio.
Jan 02, 2013 | Car Audio & Video
Some of my speakers arn't playing sound on my HT-E555OW
If you are trying to play a cd, you must manually tell the unit to play it in surround sound. Cd audio defaults to stereo only. Does it do the same thing if you are playing a dvd? If it happens on dvd's as well, then something in the speaker setup menu is wrong.
Dec 25, 2012 | Shure Samsung Ht-E5550 3D Home Cinema...
Panasonic DVD-S31 won't play sound
Did you change the audio cable, "just to rule out" If it won't work on the Tv or stereo, there probably is a audio processor problem, or a issue with the laser pickup assembly, to repair this kind of problem would not justify the cost.
Apr 12, 2012 | Panasonic DVD-S31S DVD Player
JVC auto return turntABLE - mODEL al-a95bk
when you said "no sound enough to enjoy listening" did you mean that you could hear something coming thru the speakers, but it isn't loud enough? if so, you may be plugging the turntable into a "ceramic" phono input on your stereo. it may be that your stereo doesn't have a pre-amplifier on the phono inputs. Ceramic tonearm cartridges (the part that holds the stylus - which you may call the needle) have enough output level to drive an amplifier. if your cartridge is magnetic, the output is very low compared o the ceramic. the trade off is that magnetic cartridges have a much wider dynamic range than the ceramic, and when properly pre-amplified, sound MUCH better than a ceramic unit. you can probably find a separate pre-amp at radio shack (i know they sold them several years ago). you plug the turntable into the inputs of the pre-amp, then plug the pre-amps output into your stereo. hope this helps.
Dec 19, 2011 | Audio Players & Recorders
Why my samsung s5570 Radio doesnt play FM stereo Sound
I queried this and was told you can only listen to the FM radio through earphones.
Nov 22, 2011 | Samsung Galaxy GT-S5570
Popping sound in the Rocoton Advent Wireless speaker
Double check your connections at the transmitter. Swap inputs to see if the popping moves to the other speaker. Popping usually means blown, however......
Dec 13, 2009 | Recoton Advent Advent AW810 Main / Stereo...
Mazda 6 Stereo Problems
is it a factory unit you have in the vehicle
Aug 07, 2009 | 2004 Mazda 6
Crackling and popping sounds in surround sound speakers
Could be your head unit or the connection to the speaker may be bad. Also if the wire to the speakers in your ceiling is bare and touching any ground it would interfere. Start by checking connections by playing something and messing with wires. Listen for a difference. Next check by putting the wires that power those speakers in a known working output and listen for different quality
Apr 04, 2017 | SpeakerCraft 8" 150W In-Ceiling Speaker...
No Sound
most ram trucks came with a infinity system. the amps are in the front doors, mounted to the 6x9 speakers. and they power the tweeters in the columms, and also rear speakers if you have them. I had to replace the entire system.
Aug 23, 2006 | Pioneer DEH-P47DH CD Player
RCA RS2625 CD Shelf System Logo
305 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
