Question about iRobot Roomba 560 Robotic Vacuum
How do I replace the cliff sensors? I've taken
How do I replace the cliff sensors? I've taken the robot apart but cannot find how to get to the sensors.
    Sniper:
  • 61 Answers
You're not supposed to be able to replace your own cliff sensors. They're recessed into the bumper. If you're out of warranty and determined to replace them, there are forums online where that information is laid out in detail. You can probably Google them.
Posted on Jul 06, 2009
My roomba no longer works on my area rug, it starts backing up continuously once it encounters the rug.
Sorry to read about your problem, I hope this helps you out.
iRobot Roomba Vacuuming Robots and the iRobot Dirt Dog Workshop Robot are equipped with four infrared Cliff Sensors that prevent robots from falling off stairs or ledges. The Cliff Sensors are located along the inside of the bumper. If the Sensors become obstructed by dust or debris, the infrared signal is weakened. Regularly inspect and clean the Sensors. Use compressed air for best cleaning results.
http://homesupport.irobot.com/app/answers/detail/a_id/314/p/5
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Roomba Robotic Floor Bagless Vacuum
My roomba won't go forward; it just rotates right ~90 degrees and then left ~90 degrees. I've cleaned the brushes, taken it apart and cleaned the brush gears, popped off the front wheel and cleaned the...
Hi. You will need to replace the old/damaged IR LEDs in the front bumpers optical. If you are comfortable using a soldering iron, I can supply you the parts needed.
Sep 19, 2010 | iRobot Roomba 550 Vacuum
I robot rumba- does not go forward, keeps backing up and turning
sounds like one of the cliff sensors has gone bad. I think your options are to send it in for repair or buy a replacement sensor and swap it in.
Good luck, immorion check out robotreviews.com for detailed walk through and a great community
Jul 14, 2010 | iRobot Roomba 560 Robotic Vacuum
Bumper switches on continues
Hi. An IR LED is damaged. You can replace the sensor or purchase a complete cliff sensor bumper.
May 15, 2010 | Roomba Robotic Floor Bagless Vacuum
Roomba 560: it only spins in one place, then stops & doesn't dock either.
If there's no message its probably a sensor malfunctioning. It might be a cliff sensor, the bump switch, or wheel-drop (left, right, or caster). Try cleaning the sensors and vacuuming things out as a first step.
Nov 22, 2009 | iRobot Roomba 560 Robotic Vacuum
Runs but doesn't vacuum/****. Sidebrush works fine. Cleaned the roller brushes, and that seemed to confuse the robot and now it keeps going backward a few inches, turning, and then starts going backward...
sounds like a sensor problem. pull and clean the front black/white caster assembly and the revealed movement sensor and the 4 cliff sensors along the bottom of the front. Make sure the front caster wheel turns freely. You may have to remove the roller from the caster assemply and push the axle out and clean it.
Oct 08, 2009 | iRobot Roomba 560 Robotic Vacuum
ERROR MESSAGE
The "cliff sensors" are what help Roomba make sure that it doesn't tumble down stairs or over a cliff. You can see picture of their locations here:
http://static.howstuffworks.com/gif/robotic-vacuum-16.jpg
You can try just blowing a bit of compressed air on the lenses of those sensor since they can malfunction if dust builds up on them. If the sensors have gone bad, you can find new ones at places like
www.roboticvacparts.com or at this link
http://cgi.ebay.com/NEW-Roomba-500-series-optical-cliff-and-bumper-sensors_W0QQitemZ270396528717QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ef4e3984d&_trksid=p4634.c0.m14.l1262&_trkparms=|301%3A1|293%3A1|294%3A30
Jun 07, 2009 | iRobot Roomba 560 Robotic Vacuum
ERROR MESSAGE
When Roomba says "Please Inspect and Clean Roomba's Cliff Sensors" it means that Roomba 500 series sees a constant cliff.This can happen if Roomba was started on an uneven surface or got stuckon an obstacle during the cleaning cycle. Extremely dark-colored floorsurfaces may also contribute to this error. If this error occurs on aneven, light-colored floor surface, Roomba’s Cliff Sensors could be dirty or obstructed.To troubleshoot this issue, please follow these steps:
  1. Check the Cliff Sensors for obstructions.
  2. Clean the Cliff Sensor windows using clean, dry cloth.
  3. Move Roomba and restart in a new location.
The location of the (4) optical sensors can be seen here:
Occasionally these sensors do go bad and that can be a hassle since iRobot doesn't like to sell replacements...they prefer you send the whole robot back to them. If you are handy and willing to replace yourself, you can purchase replacements from some reputable vendors like www.RoboticVacParts.com
Jun 07, 2009 | Roomba Robotic Floor Bagless Vacuum
Can not charge thr battery
bbaker58,
When you press the "clean" button after charging, does the Roomba give you any audible tones? Those tones are the key to understanding failures in the 400 series. See chart below to decode those tones
If you get no tones at all, then either (1) you're not getting power from the battery to the main circuit board or (2) the main circuit board is dead. You really have to open the unit up to figure out which it is. Circuit board replacement is a pretty involved procedure since it requires disassembly of almost the entire robot. If you are brave and want to try it, replacement PCAs are available from places like www.RoboticVacParts.com. They are my favorite shop because they sell parts tha iRobot refuses to sell to consumers and they're prices always beat what iRobot charges.
Roomba Says
What It Means
What You Should Do
Plays 4-note song as Power button blinks RED
Play sound The battery is low and needs recharging
• Connect the robot to the charger or Home Base® and recharge the battery. “Ehh”
Play sound The Cliff Sensors are dirty or malfunctioning
• Pick up your robot and turn it over.*
• Check for any debris that might be caught underneath the front bumper, around the Cliff Sensors.
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out.
"Uh-oh"
A wheel is stuck or is not touching the ground
• Lift the robot and place it down again.
• Press the Clean button to restart the cycle. “Uh-oh” plus 1 beep
The robot's main brushes are stalled
• Pick up your robot, turn it over* and remove the wire guard.
• Look for something blocking the brushes; you may need to remove and reinstall the brushes to remove the obstruction. “Uh-oh” plus 2 beeps
The robot's Side Brush is stalled
• Pick up your robot and turn it over*
• Check to see if something is wrapped around the Side Brush.
• Remove the Side Brush with a screw driver and check for string or hair wrapped under it.
• Replace the Side Brush, place Roomba in the center of the room and press Clean to resume cleaning. “Uh-oh” plus 3 beeps
The robot's vacuum is stalled
• Remove and empty the Dirt Bin.
• Use a flat-head screwdriver to remove the grill at the back of the Dirt Bin.
• Spin the Vacuum Impeller around, shaking out any debris that may be stuck.
• Replace the grill and the Dirt Bin. “Uh-oh” plus 4 beeps
Play sound
The robot's Drive Wheels are stalled
• Your robot may be stuck, or something may be caught in a wheel.
• If it's stuck, place it in the center of the room and press Clean. It should resume cleaning.
• If it is not stuck, lift the robot, turn it over* and look for something caught in the wheels. Test the wheels by pushing them in and out and making sure they rotate freely. Place robot in the center of the room, press Clean, and it should resume cleaning.
If this continues to happen every time you clean, you may need a software upgrade. Contact iRobot Customer Support.
“Uh-oh” plus 5 beeps
The robot's Cliff Sensors are obstructed
• Wipe the Sensors with a lint-free cloth or use compressed air to clean them out. “Uh-oh” plus 6 beeps
The robot's Wheel Drop Sensors are overloaded (robot is stuck in a bumpy area)
• Pick up your robot, place it in the center of the room, then power it off and then on again.
• Select the cleaning cycle you prefer and let it go to work.
“Uh-oh” plus 9 beeps
The robot's Wheel Drop Sensors have failed at startup
• This failure requires you to contact iRobot Customer Support. Click here to send us an email. “Uh-oh” plus 10 beeps
The robot's bumper is not registering obstacles
• If the robot travels for a long distance without bumping into anything (which would be unusual), it might think it’s stuck and can’t move; press Clean again and it should resume cleaning.
Jun 02, 2009 | Roomba Robotic Floor Bagless Vacuum
I robot won't go forward
HAVE YOU TRIED OPENING UP THE ROOMBA AND CLEANING THE SENSORS?
Jul 06, 2008 | iRobot Roomba Discovery SE Bagless Robotic...
iRobot Roomba 560 Robotic Vacuum Logo
482 people viewed this question
Top iRobot Vacuums Experts
Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
