Question about Apple MacBook Pro Notebook
Trying to re-install O/S X in MacBook Pro laptp and while holding down c hey to boot into dvd after getting scrilling rosette, screen will go black as though going to next step of language menu, but stays black
  • 86 Answers
Insert the install disk when the computer is operational. After the disk has mounted, click on the 'Install' icon in the install disk window. You will be prompted that the machine will now re-start. When the re-start happens DO NOT hold down the 'C' key the computer will automaticaly start up from the install disk.
If this fails to work, hold down the 'alt' key on start up. This will bring up a screen with all the available boot folders. (You may need to wait for the disk to appear on the screen). Select the boot disk you want and click the arrow to start from that disk.
Posted on Jun 26, 2009
Brand new apple dvd drive will not accept dvd
The DVD works by just pushing it in far enough till you get resistance, then the drive pulls the DVD in by itself. If after it pulls the DVD in, it just ejects it, The DVD drive thinks you are using an incompatible disk.
You can also try resetting the SMC.
This is how to reset SMC on most modern Mac laptops:
Shutdown your MacBook Air / MacBook Pro
Connect the power adapter to your Mac
On the MacBook/Pro's keyboard, hold down the Shift+Control+Option keys and the Power button at the same time
Release all keys and the power button at the same time
Boot your Mac as usual
Here's the key sequence to hold down:
Reset the SMC of a MacBook Air or Retina MacBook Pro
Do keep in mind that by resetting the SMC you will lose power specific settings, like the time it takes to sleep a Mac and other customizations to power settings. No big deal, but if you have made many changes to your hardware behavior you will want to adjust stuff like sleep behavior again.
Reset SMC of an iMac, Mac Pro, Mac Mini
Resetting SMC is different for non-portable Macs:
Shut down your Mac
Disconnect the power cord
Press and hold the Mac's power button for 5 seconds
Release the button
Reattach the power cables and boot the Mac as usual
Reset the SMC of a MacBook or MacBook Pro's with detachable batteries
sad mac reset the smc Older MacBook laptops with a removable battery can reset SMC with the following approach:
Shutdown the MacBook/Pro and remove the battery
Disconnect the power adapter, hold the Power Key for 10 seconds
Release the power key and reconnect your battery and power adapter
Turn your Mac on
Let boot as usual
Hopefully that will clear up your problems, if not it might be worth a visit to the Apple Store or a certified repair center.
Happy New Year,
Kerry
Jan 24, 2014 | Apple MacBook PC Notebook
2006 Macbook Pro replacement screen problems
You have a bad driver. Reinstall your screen driver or clear your P ram by holding the letters P and R and the control button when you boot your laptop. Hold them until it chimes and reboots.
Apr 12, 2013 | Apple MacBook Pro PC Notebook
MacBook Pro took a drop, boots up but nothing on the screen.
The screen, the cable that connects to the screen or something internal has taken a hit. You'll need to get it serviced to find out which. Sorry, but there's not much diagnosis we can do from a distance.
Apr 03, 2013 | Apple MacBook Pro Notebook
Macbook pro problem
Put the installation cd in your drive, and boot while holding down the C key
then open up "Disk Utility", and choose repair permissions
Oct 17, 2012 | Apple MacBook Pro MB991LL/A 13.3-Inch...
How do you turn off DOS mode on a 13" MacBook Pro?
Is this a trick question? There is no "DOS mode" on a MacBook Pro.
Do you have WIndows installed as part of Boot Camp, and your machine is booting into Windows? To boot back into the Mac, either use the Boot Camp control panel in Windows, or hold down the Option key after you hear the startup chime and select the OS X partition to boot from.
Nov 14, 2010 | Apple 13.3 MacBook Pro Notebook Computer ...
My macbook pro OS 10.6.4 either freezes or crashes on startup. Crashed when trying to startup with Drive Genious 3, TechTool Pro 5, System Disk or Disk Warrior. Not sure what to do next. Tried holding ...
Restart your mac. As it's restarting/booting up, hold down the command, option, R and P keys simultaneously. As it's booting up and you're holding these keys, you should hear the startup chime, continue to hold the keys down, it will cycle and you'll hear the startup chimes again. Let it go thru this cycle 7 (seven) times before you let up on those keys. Once it's cycled 7 times, let it boot up normally.
If that doesn't work, then reinstall the original system software that came with the Macbook. You may have to reformat the hard disk and do a clean install.
Jul 05, 2010 | Apple MacBook Pro Laptop Computer with...
When I booted my Macbook Pro today, I could hear the hard drive being accessed, but the screen remained black. Have you heard of this problem before? Last night, it was fine and showed no symptons
yes this happens. you can try doing this: power down then power up whilst holding down command, option P and R all at the same time. press these after you hear the chime. hold until you hear the chime a second time.
May 05, 2010 | Apple MacBook Pro Notebook
Macbook pro screen boots to black. tried rebooting, screen comes on then goes black again. This happened after I unplugged it from a dell projector. Any suggestions???
Try pulling the battery out then holding the power button for 10 seconds. Put the battery back in.
If not search macbook pro recall apple has extended the warranty on some models due to a bad graphics card.
Feb 02, 2010 | Apple MacBook Pro Notebook
Apple MacBook Pro Notebook Logo
176 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
