SOURCE: installing T2250 tally printer
The link is :-
http://members.driverguide.com/driver/detail.php?driverid=230334
Thnks.
SOURCE: Tally T2250 showing an error..
If you are using re-fill ribbon then the problem may arise , if you are using original then clean the encoder strip with isopropile if not solved change the encoder strip .
SOURCE: Tally T2250 Matrix Printer does not pull up paper to be printed
I would guess you are getting error messages on the diplay to tell you what the bleeping noise is about....Please read this message.....
I would guess the message is something like LOAD SINGLE, and you are using tractor feed paper. If this is the case the paper path on the pritner has changed and needs to be changed to Tractor 1 again.
To do this;
You should be back in action, if not post the message you see on the printers LCD display.
SOURCE: I have a tally 2250 printer to beused under win98.
you can installed this printer driver of genric text only.
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
