Question about Clarion DC625 6-Disc CD Changer
Hi I have a cdc635 6 disc changer in a 1998 alpha it shows error code 6 any ideas on how to fix it Tks Philip
2 Suggested Answers
SOURCE:
gabz81
  • 32 Answers
SOURCE: Clarion 12 Disc CD Changer Model # CDC 1255z What
out of focus.
if all of your discs have the same error code 6, it is optical lens problem. have it checked to the nearest service center.
Posted on Jul 01, 2010
I have a bose wave system. I tried loading cds in the multi changer and kept showing error and never would play. The multi changer still has one of my disc and will not eject. I tried unplugging and...
Hi, The cd disc is not in his place inside the multichanger, you must open the appliance and try to take out the cd without forcing, otherwise you wil brake the mechanical system,
after this the system will work well.
Thanks.
Jan 30, 2011 | Bose Wave music system Multi-CD Changer...
1998 Honda Accord EX stereo/CD player has Code E on the screen... What is the cause of this and what can I do to fix it?
Unfortunately 90% of the time when you get error codes from the CD player/changer it means that there is a mechanical failure in the CD player/changer unit itself and it usually requires CD player/changer rebuild or replacement...
First make sure you have entered the correct anti-theft code. If battery power has been disconnected recently than the stereo display will read CODE if the incorrect anti-theft code is entered the display will read ERR1 thru ERR3. If this is the case you'll have to get the correct anti-theft code. Note; If you enter the incorrect code three times the stereo locks up. Disconnect the battery for more than 30 seconds and then retry.
FYI;Never use adhesive labels or protective disc covers on recordable CD's. Recordable CD's are actually thicker than pre-recorded CD's. Automotive players and changers use rollers to draw the disc into the unit. The added thickness of an adhesive label or protective disc cover may cause the disc to jam. Also CD players and changers are exposed to high temperatures inside the vehicle. High temp will cause the labels adhesive to soften which may cause the labels edges to curl or cause it to bubble. Either one may cause the disc to jam and cause the player to display error codes E-01 thru E-07. If the player can not be disassembled and have the discs removed successfully than it will have to be replaced. -hope this helps.
Oct 18, 2010 | 1998 Honda Accord
ALPINE IVAD310R NOT RECOGNISING ANY DISCS. DISPLAYS DISC ERROR. ANY IDEAS WHAT IT COULD BE? THANKS
don,t want to which alpine 12 dics changer,on my ivad310 screen it said hi- temp, and no the front its say error when i which to my cd changer. so what is the problem is it , the alpine cd changer are the ivad310 needs to be reset are something let me know.
Jun 22, 2010 | Alpine IVA-D310 Car DVD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
Display reads No Disc despite all the discs checking out.
Hi, the optical lens assembly has failed. this is triggering the (no disc) error code. you will need to replace this failed optical assembly.
May 29, 2009 | Pioneer Car Audio & Video
Have alpine chm s620 ,error message say no disc magazine is loade
have you tried a different magazine.  Could this one be warped?
Apr 03, 2009 | Alpine CHM-S620 6-Disc CD Changer
10 disc changer shows error code or no cd
maybe the lens in covered with dust , try to clean it , or it is broken. Who knows , break the device and see it for yourself. good luck
Apr 02, 2009 | Sony CDX-2250 CD Changer
Clarion DC625 6-Disc CD Changer Logo
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
