Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Error code on thermostat says return
What does error code on thermostat that says return mean
What type of thermostat
Posted on Jun 26, 2009
AC OFF code keeps coming on. Is this the thermostat or a more expensive problem
If you are seeing this AC code on your thermostat screen that usually means that the thermostat is losing power. If a furnace is overheating the limit switch will shut the burner off cutting power to the thermostat. Check your air filter and make sure all your supply and return registers are open.;
Dec 06, 2017 | Heating & Cooling
Carrier Comfort Zone II Thermostat is blank and the 3 companion thermostats are all showing Error Code C1. What does that mean?
Hi Anonymous,
For all wall mounted and Artcool split system codes
Error code = C1 or CH1
Flashing Light = 1
Fault = Indoor temperature sensor open or closedcircuit.
Display = Indoor.
Indoor Operation = ON
Error code = C2 or CH2
Flashing Light = 2
Fault = Outdoor temperature sensor open orclosed circuit.
Display = Indoor Outdoor.
Feb 14, 2015 | Carrier Heating & Cooling
My Honeywell thermostat shows an error 91 what is that code and can it be repaired
The codes are differernt for each model. You didn't post the model #. However, Code 91 usually means a thermostat fault. Which means either the thermostat needs to be replaced, or there is loose wiring at the thermostat.
Nov 04, 2014 | Heating & Cooling
What does the code E1 mean on Carrier Model # 38KCL112313GP?
thermostat no recognizing ac unit turn off and reboot thermostat
Aug 05, 2014 | Carrier Heating & Cooling
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
F25 error code
The "F25" error code means the control board senses the inlet thermistor shorted. The inlet thermistor is a part of the hi-limit thermostat which is located on the heating element box.
- The hi-limit thermostat kit Part number: AP3094323
Read more: http://forum.appliancepartspros.com/dryer-repair/54078-whirpool-duet-dryer-error-code-f25.html#ixzz2n2Rmgm7a
Dec 10, 2013 | Whirlpool WED9400S Electric Dryer
Dometic model 3313192 thermostat error code E1 what does this mean?
Hi By E1 error it means
Loss of communication between the Single Zone LCD thermostat and the module board. LCD will cycle between E1 error.
Check the link for regular maintenance Of the LCD thermostat.
If it doesn't help then you have to replace the LCD thermostat.
Ajin
http://www.google.com/url?sa=t&rct=j&q=dometic%20model%203313192%20&source=web&cd=1&ved=0CCwQFjAA&url=http%3A%2F%2Fmanuals.heartlandowners.org%2FHeating-Cooling%2FA-C_Units%2FDometic%2FDometic_Single_Zone_LCD_Thermostat_Operating_Instructions.pdf&ei=hOg0T7OUNIjkrAer4Ny6Dw&usg=AFQjCNEn2y9-ItUcF2KRJZ0dm0Ftrq8Jhw
Feb 09, 2012 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
1,297 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
