Question about Marshall MG100HDFX 100-Watt Amplifier Head
Marshall mg100hdfx loud fuzz and distortion and no guitar sound
When I turn my MG100HDFX on distortion all you hear is fuzz and you can barely hear the guitar sound. When it's on clean, i get the same fuzz and NO guitar sound. Help?
    Sergeant:
  • 336 Answers
I would think the other way, IF you hear fuzz or hear anything at all, your input is fine, wiggle the speaker plug around and listen for changes. You probably have a dirty socket on SPEAKER OUTPUT.
Posted on Mar 08, 2013
  • Joe Patch
    Joe Patch Mar 08, 2013
    I would also wiggle the master volume and check as well. If it is static and scratchy, just working it up and down to see.
  • 32 Answers
There is clearly a problem with your input jack or cable. This should be covered under the warranty.
Posted on Jan 20, 2010
  • 22 Answers
Check your input (guitar signal).
Also, check your gain and volume levels.
Make sure that you have a reliable, steady, and clean power source as well.
If the problem persists, contact the store from which it was purchased. There are a lot of things that can go wrong internally with the cheaper Marshall models.
Posted on Sep 28, 2009
Name some best Distortion Pedal. Where to buy them?
The best top 5 distortion pedal are:-
  • BOSS Audio DS1 Distortion Guitar Pedal
  • Pro Co RAT2 Distortion Pedal
  • Boss BD-2 Blues Driver Guitar Effects Pedal
  • Electro-Harmonix Nano Big Guitar Distortion Effects Pedal
  • Electro-Harmonix Soul Food Distortion/Fuzz/Overdrive Pedal
I use to buy any distortion pedal from this site
Top 5 Best Distortion Pedal You Must Buy New 2017 Musical Study as they guide the best to buy the best.
Jan 02, 2017 | Music
Marshall mg100hdfx head. I get no sound whatsoever plugged into the guitar input but the controls seem to work as I can hear changes in the light ambient static. I will get sound however if I plug directly...
You MAY have a broken input jack. If you can hear changes from the overdrive gain control, that control is just one stage away from the input jack. Also there is a capacitor C60 that is for RF bypassing and if that shorts that will kill the audio. Yes, inout jacks get destroyed by tripping over guitar cables... that is why you run the cord through the amp handle before plugging it in. Of course verify your guitar and cable is good using another amp.
Aug 30, 2011 | Music
When i turn over my fender fuzz wah i hear something rattle or clunk. Is something loose inside? I just got it yesterday.
It is probably the battery or the battery connector. Not to worry or look for the battery compartment and put your mind at rest.
Aug 06, 2011 | Fender Fuzz Wah Guitar Effects Pedal...
My ltd deluxe ec-1000(vintage black) is not producing any distortion on my Marshall mg100hdfx. this is the first time i have had an active pickup guitar, i put a new 9v battery in it but still no change in...
Distortion is not produced in the guitar. Distortion is generated in the amp by circuitry that increses the gain until the waveforms "flat top". This creates higher harmonics and a buzzy sound. If you are getting a very low output from your guitar it is possible that you don't have enough output to get the distortion in the amp to work. Other settings in the guitar add harmonics by mixing more than one pickup. This is not ditortion but adding these harmonics changes the sound immensly.
LOOK AT THIS SITE AND FIND A SCHEMATIC THAT MATCHES THE RESOURCES OF YOUR GUITAR... You might be able to figure where the wire goes... It may be a ground.
http://www.guitarelectronics.com/c=D65u46R1H9tko6CKpPLsjBhiJ/category/wiring_resources_guitar_wiring_diagrams/
Apr 24, 2011 | ESP Ec 1000 Ltd Deluxe Electric Guitar In...
Marshall MG100HDFX, VERY loud painful humming/noises as soon as the amp is turned on. Cant be adjusted by volume or anything, is this a connection problem?
Likely the filter capacitor(s) have failed OR the power amp has shorted driving DC with ripple into your speaker (very bad). Take it for repair before damage might be done.
Jan 10, 2011 | Marshall MG100HDFX 100-Watt Amplifier Head
I'm having some crazy feed back with either my amp and i'm not sure what its from or if its my guitar but, every time i go to practice or to play a show i kill peoples ears. Now i play death metal and i...
If the guitar can "hear" the sound, the strings can resonate from the sound and result in feedback. Running at maximum gain is asking for trouble. That causes distortion which drive the speaker as a square wave and worsens the problem. Also back off the treble as you can have supersonic feedback that you can't hear but will heat up your amp.
Test by allowing the feedback and then dampen the strings... if this stops the feedback you need to move the amp away from the guitar. Being a passive pickup makes NO DIFFERENCE about the problem.
Nov 22, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
I have a Marshall MG100HDFX 100-Watt Amplifier half stack (solid state) and I now am not getting ANY sound out of the amp. I changed the fuse and the power module behind the fan, and still no sound,...
plug headphone in the effects send jack...If you get somme sound (won't be too loud) there, that means preamp sections are probably ok. Drive a signal into the effects return jack... If power amp responds, it is OK... If both these are OK, then suspect the switch contacts on these two jacks that forward the preamp to the power amp when effects unit is NOT plugged in.
These contacts are a chronic problem.
Sep 19, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
The sound on my mg100hdfx cuts out sometimes then its fine what could this be
Common problems are broken or intermittent input jacks or cracked circuit board or soldering or broken volume controls. Another one is a bad switch contact on the jack for PA input connection. All these are internal and require servicing.
External problems are guitar and cable problems.
Jul 15, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
Marshall MG100HDFX 100-Watt Amplifier Head Logo
614 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Bruce Grant
Bruce Grant
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
