Question about Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
Is there a circuit breaker - Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier
    President:
  • 1,138 Answers
There should be a fuse holder near the place in the back of the amp where the power cord plugs in. Also some Marshalls have fuses in fuse holders on the circuit board. Always replace with the same value and type as the original fuse. Never open up the amp when it is plugged in to the outlet. When replacing the internal fuses do not touch the capacitors as they retain a lethal charge. If the fuse continually blows it is an indication of a more serious problem which will require servicing by a qualified repair person.
Posted on Jun 25, 2009
Hello good morning i have a peavey 2600 power amplifier, each time i try to turn on the amplifier the breaker switch flies what could cause that to happen
A serious power drain caused by a damaged mains transformer, short circuit power supply, shorted output transistors or a leak to earth taking the earth treip out.
Mar 22, 2018 | Peavey Music
My amp will not power up?
Measure the breaker, measure the power switch, measure the power cable,
Feb 12, 2014 | Peavey IPR-3000 Power Amp
Some of my microphone inputs stopped working
downloads.mackie.com load this bus driver file. use winzip to install.....have fun meder's tv service
Aug 28, 2012 | Mackie 2404-VLZ3 Mixer
Peavey cs1000 x
The most likely case is that one of the main output transistors (if which there are many) is shorted. When the protect circuit senses DC on the final output, it will not allow the output relay to come on to protect the speakers from raw DC. With the power removed, you can check between each outputs Emitter and Collector and you will probably find close to zero ohms. From that point you need to unsolder each of the pins of the bad channel until you find the shorted device(s) and replace them.
Jul 05, 2017 | Music
My adam A3X is suddently having the power switch stuck. I can no longer turn it on.
As loon as the power switch is not also a circuit breaker, just change the switch. If it is also a circuit breaker then there probably is some problem with the amp.
May 27, 2011 | Adam Audio A3X 2Way Studio Monitor...
Hi, I own the Dynaudio BM6A acoustics monitors & I want to know if there is a circuit breaker system inside the monitors, for surge protection? The reason I ask is because I have no power conditioner...
If an internal circuit breaker pops, something has failed. Even surge protectors do little to protect stuff unless they are high level types with filtering. Key thing: ALL your interconnected equipment MUST be powered from the SAME receptacle or power conditioner. Using multiple outlets can allow building "ground bounce" to rupture sensitive input circuits. Use of balanced lines avoids noise in systems.
Apr 21, 2011 | Dynaudio Acoustics BM6A MK II Active...
My line 6 doesnt turn on,its like no electricity is going through it? i would like to know what is the problem???
I can't find a schematic but there should be a circuit breaker or a fuse on the backside of the amp.
Nov 13, 2010 | Line 6 Spider Iii 15 Modeling Guitar...
How do I remove the keys from a Roland KR 4700 piano? We can't figure it out. Please help! I can't afford to get a repairman. I need to replace the contact strip. It's happened before.
If these are semi weighted keys here is a cut and paste from a manual:
19. Disassembling the Keyboard Assembly
* After inserting a round stick (Rod: TX000670)
between the frame and the keys, remove the
circuit boards. (Fig. 23)
19-1 GHD EBUS L, MK SUB Circuit Board
(Time required: about 12 minutes)
Remove the seven (7) screws marked [260A]. The
GHD EBUS L and MK SUB circuit boards can then
be removed. (Fig. 24, Photo 5)
19-2 GHD M Circuit Board
Remove the five (5) screws marked [260B] and the
screw marked [262]. The GHD M circuit board can
then be removed. (Fig. 24)
19-3 GHD H Circuit Board
Remove the four (4) screws marked [260C] and the
screw marked [262]. The GHD H circuit board can
* Keys can be removed without removing the
circuit boards.
* After removing the GHD EBUS L, GHD M and
GHD H circuit boards, and the rubber contacts
can then be removed.
19-4 Rubber contact
Remove the GHD circuit board for the involved key.
The rubber contacts can then be removed.
The rod is inserted above the weighted hammer and the bottom of the keys from one end. It appears to be about 1/4 inch diameter dowel and will run the full length of the keyboard. You might use 3 foot ones from each end.
Screws are removed and the boards removed without taking the individual keys out.
Mar 17, 2010 | Yamaha NP 30 76 Key Lightweight Digital...
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
Amp will not come on
hi thanks for using fixya!!
On this error, you should check still the built in breaker.
Apr 21, 2009 | Peavey Pv 2600 Power Amplifier
Marshall Amplification Marshall MG250DFX 100W Guitar Combo Amplifier Logo
261 people viewed this question
Top Marshall Amplification Music Experts
Michial Gueffroy
matt martin
matt martin
Are you a Marshall Amplification Music Expert? Answer questions, earn points and help others
