My mouse button is lock how do i unlock it - Computers & Internet
    Scholar:
  • 34 Answers
1. The touchpad and external mouse drivers should be able to work together. Just make sure that you have the touchpad enabled. To see if you have the touchpad enabled, hold the Fn key and press F9. The combination Fn-F9 locks and unlocks the touchpad. If pressing Fn-F9 once, twice, thrice does not seem to lock/unlock your touchpad.. then you might not have the Toshiba hotkeys working or enabled. So lets forget it and try step 2. If Fn-F9 solved your problem.. there you go !
Arrow The way it works is you have to keep holding Fn key and have to hit F9 once, that should lock the touchpad. Again if you keep holding Fn and hit F9 again, that should unlock it and so on..
2. Sometimes this solves the problem.. Do a power cycle of your computer.. i.e., unplug the AC.. take the battery out.. Plug the AC back in and try to turn computer ON with AC alone (i.e, leave the battery out and just start computer with AC power).. Once windows loads up and everything is fine, then turn system off. Unplug AC.. put battery back in.. Plug AC back in and restart computer.. All should be working now.. if not, keep reading..
3. Click on START>go to RUN>type devmgmt.msc
4. Now in the Device Manager, click on the + sign next to Mice and other pointing devices. Right click on each device listed under "Mice and other pointing devices" and Uninstall ALL the MOUSE Devices you see listed there..
attention Make sure you ONLY uninstall the Mouse devices and not ALL devices from Device Manager like your CD, Display etc.. Just uninstall the devices listed under Mice and Other pointing devices after you have clicked on the + sign to the left of it..
5.Install Drivers
6. In the page that came up saying Downloads ( All operating systems, All categories ), at the top drop the list Filter by Operating System and select Windows XP (I am assuming you have XP.. if you have another OS, select that instead).. then on the right of it, drop the list Filter by Category and select Touchpad.. then click on the button "Apply Filters"..
7. Now you just see two drivers listed..
09-30-2004 Toshiba Utility
Touchpad Toshiba Touchpad Enable/Disable Utility for Windows XP (v1.27.0.3; 09-24-2004; 5.34M)
06-15-2004 Driver
Touchpad Alps Touchpad Driver for Windows XP/2000 (v6.0.303.5; 05-26-2004; 2.43M)
Click on the Download link on the right.. Save them to your computer somewhere in a folder or desktop, where you can remember.. After the files are downloaded, double-click on the file.. Unzip.. then Run.. and it will install the driver..
8. Restart your computer.. Now the Touchpad should be working fine.. Try Fn-F9 combination.. i.e, keep holding Fn key and tap F9 once, twice to see if it locks/unlocks the touchpad..
If above doesnt solve it, then please post any errors that you get and I will see if we need to try something else. Thanks, CF
Posted on Jun 25, 2009
I accidentally locked my cursor. I'm in Word. I leaned (unwittingly) on my built-in mousepad, the little light in the NW corner of the "mousepad" went on, and locked the cursor. How do I unlock it?
Whats the model of your laptop, it may have a button combination to unlock the mouse, or even a single button that locks / unlocks it.
You could always plug an external USB mouse into it in the meantime.
Apr 27, 2016 | HP Computers & Internet
Unlock gateway touchpad
some touchpads have button for that....
some touchpads have lock pattern to lock touchpad.... and also to unlock it
or...
if you have a mouse plugged in then unplug it then restart your comp
then after restart you can plug in mouse back again
Feb 12, 2014 | Computers & Internet
Hp probook 5520 mouse pad is locked. The keyboard and mouse buttons are working but the touchpad is locked. how do i unlock it?
there would be a small button right beside the touch pad LED. press the button and LED will turn to white or green and your touch pad is unlocked. pls rate the slolution however you find this....
....thanks...may
Jul 12, 2011 | Computers & Internet
How to unlock the key pad on a dell latitude D600 laptop
Hi. Please do troubleshooting steps below:
1. Check to be sure your "Number Lock" or "Function Lock" keys aren't lit. These can lock out certain parts of your keyboard. If either of these is lit, press them to unlock the locked portion of your keyboard. These can be found at the top right on a laptop and between the number pad and main keys on a desktop keyboard.
2. Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
3. Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
4. Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
Have a good one!
  • Step 2 Save all open programs using your mouse. Use your mouse to restart your computer. This will only work if your computer isn't frozen. If your mouse doesn't move, press the power button on your Dell until the computer turns off. Press it again to restart. If the issue was lack of memory or a locked program, this will unlock your keyboard. Continue to Step 3 if the keyboard is still locked.
  • Step 3 Shut down your computer using your mouse or power button. Don't restart. Unplug your Dell.
  • Step 4 Remove the battery if you're using a laptop by turning the laptop over and sliding the battery release latch. Slide the battery out and replace after one minute.
  • Read more: How to Unlock a Dell Keyboard | eHow.com http://www.ehow.com/how_5063232_unlock-dell-keyboard.html#ixzz0uguUk4bZ
    Jul 25, 2010 | Dell Latitude D600 Notebook
    Mouse pad is locked how do I unlock it?
    hi
    your track-pad mouse has a horizontal bar-shaped button above it with an orange light next to it, try pressing that button. The light should turn white and your mouse should begin working again.
    Jun 12, 2010 | HP Pavilion dv6000z Notebook
    Cant unlock
    Try removing the batteries, wait for a while ,reinsert batteries and reconnect to reciever. Let me know how it goes..
    Sep 10, 2008 | Logitech Cordless TrackMan Optical...
    How to unlock
    Logitech mouseware must be installed for this to work.
    Go to the mouse properties and select the drag lock button and set it to "Unassign" in Logitech -> Mouseware -> Mouse Properties.
    Click the "Buttons" tab.
    Scroll down to button "4" and select. Click Modify button and select "Unassigned" And Click "OK" Button, Click "Apply" button. The lock icon will go away and never come back.
    Unlock cursor/mouse
    Press and hold Fn+F9 5 3sec...should do the trick
    Jun 08, 2007 | LG X-Note LM50 Notebook
    Computers & Internet Logo
    1,663 people viewed this question
    David Payne
    David Payne
