Question about Dryers
The blower wheel on my dryer has begun to rub against the panel
The blower wheel on my GE dbxr453ga2ww has begun to rub against the front of the cabinet housing. I have aken the dryer apart and the blower wheel is connected by a shaft directly to the motor. The motor seams sturdy and I do not believe it bent out of shape or moved in any way causeing the wheel to move. Also the blower wheel is plastic so I highly doubt it bent out of shape. I was going to try and tighten the screw holding the wheel to the fan tonight, but if that doesn't work I was wondering if you have any other ideas. Any help would be greatly appreciated.
  • 126 Answers
Your blower is held onto shaft with 2 clips,inner and outer.loosen bolt slightly and you should be able to push blower back a little be careful not to loosen too much ,they can be a pain to realign.Hope this helps,please rate my solution.:)
Posted on Jun 25, 2009
I have had to replace the blower wheel on my Maytag Performa Dryer twice in the past 2-3 months. The wheel when removed looks as though it is being ground down. Could there be something else wrong?
Just check that the dryer vent out the back hasn't been pushed into the machine. Sometimes when the dryer is pushed against a wall the vent can be pushed back into the machine somewhat, which will in turn push the blower wheel housing forward and deform it slightly, causing the blower wheel to rub on the housing.
Jul 06, 2011 | Dryers
My GE dryer is making a real loud noice while drying model #DBXR463ED2WW
hELLO THERE
If your dryer is noisy, check these: Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time. Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it. Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them. Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn. Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
Dec 04, 2010 | GE Dryers
Our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
our dryer turns on, is getting gas, but does not produce heat. the dryer is 10 years old and is the GE - quiet by design - dbxr453ga2ww.
Mar 20, 2010 | GE Dryers
We have a GE stackable laundry center (model WSM2400LEBAD). There's a rattling sound when the dryer is running. The part that appears to be the culprit looks like the paddle that you would see on the...
The part you're describing is a blower wheel. Here is your part: 5303209769. Use "New10" coupon for 10% off.
Although I do not remember exactly how to remove the front panel, I believe you'll need to remove the top to get to the screws holding the front panel. There should be a lot of wires, if you have to disconnect them, write the colors and positions and/or take pictures :)
I'd recommend to remove the tilted panel between the dryer and washer compartment first and try to get to the blower wheel from there. You'll need to remove the front of the blower wheel housing to be able to take the wheel out.
Good luck
Oct 22, 2009 | Dryers
Kenmore Dryer 110 is making a loud squeaking noise.
Only a few things will make that noise. The squeaking is caused by a moving part having trouble turning while rubbing against a fixed part.
  1. The idler pulley is worn
  2. The drum support rollers are hard turning on their shafts
  3. The felt seals at the front or back of the drum is worn allowing metal to metal contact while turning
  4. An article has fallen into the housing around the blower wheel and the wheel is rubbing on it.
Listen for the frequency of the sound. The drum rollers and drum felts will squeak at the frequency of the tub turning. The idler pulley turns much faster as does the blower wheel. Knowing this will help pin down the cause.
The following link has valuable information on taking apart your style of dryer:
Sears Dryer Disassembly
Sep 20, 2009 | Kenmore Dryers
Ler7646eq2 shaking and blower noise
To remove the blower wheel you will need to get it from the front of dryer.You will need to first remove the screws where your lint screen is.Then you will need to lift the top up and remove the front panel.There are 2 1/4 inch screw on the inside part of the front panel on the left and right corner area.After that you will need to take the belt off and remove the drum.After the drum is removed you will need to use a cresent wrench and a pair of vice grips to remove the blower wheel. first take off the motor clip around the blower wheel area then Put the cresent wrech on the plastic blower wheel it is square.wendge the cresant wrench against the drum roller shaft then clamp on your vice on the opposit side of the motor shaft then give it a good turn so that the cresant wrench is pushing aganst the drum rollor shaft that should remove the blower wheel and just reverse after done.Hope i helped
May 18, 2009 | Whirlpool LER7646E Dryer
Dryer makes noise when turning like bearings going or belt squeek
check the following -
It's noisy
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
good luck.....
Mar 28, 2009 | GE WSXH208A Front Load Washer
When our dryer is turned on it has a very high pitched noise as if some metal is rubbing on the drum. It is model number DBXR453GVOWW.
It's noisy If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Mar 07, 2009 | GE Dryers
Kenmore dryer front of drum rubs
Check your plastic drum slides. I get em(2) out of the drum and reverse them and that sometimes stops it.
Feb 14, 2009 | Kenmore 62602 Electric Dryer
Asko T700 dryer
Seems like you need new drum rollers. If one(or both) is bad, the drum will rub in the plastic.
Dec 10, 2007 | Asko T700 Electric Commercial Dryer
Dryers Logo
253 people viewed this question
Top Dryers Experts
