Question about Ruud UAMB Air Conditioner
Compressor kicks out and it's new
I had a cooling coil replaced a few weeks ago. My old coil was an older style (slab) 3 ton coilI. I upgraded to a carrier 3-1/2 ton cube coil and left the old condensing unit in place. My condensing unit compressor (17yrs. old also) starting shutting off at night. The tech was having to run refrig. pressures a little higher than normal to get the return line to sweat. After a week of cutting on and off we decided to replace the old CU with a new Linux 3-1/2 ton model. Things seem fine at first (2nd day on 6-25-09) but that unit started shutting off as well. It ran for most of the night and cooled the house from 83 deg to 76 deg. First thing this morning the compressor would not kick in. After a rest of 30-45 min it begin running but It will run for 30-45 min or so and the compressor will kick out (fan stays running). The air supply fan is starting to show it's age and will be replacing the fan soon; thinking there's maybe not enough air flow. When the unit is running I'll get 54deg air at the air device and the condensate with flow normal. I do have a medium grade digital programmable thermostat installed (Lowes or Home Depot type). One last thing the circuit board in the unit has been replaced 3 times due to capacitor's and fans going out in the condensing over the years (again 17 yrs old). Please help...this replacement thing is getting expensive.
    Problem Solver:
  • 22 Answers
You need to find another hvac contractor from all the things you stated it's not the equipment it's the people doing the installtion/service. For starters theses days you never use a 3.5 ton coil on a 3.5 ton air conditioner it won't ever achieve the efficiency labeled on the energy label. Also it sounds like before you replaced the outside unit they might have had a r-410a metering device for your older R-22 unit then when they switched to the new 410a they probbably did not flush the system out mixing oils from r-22 over to 410a is not a good thing. I'd try to get your money back find a qualified company don't go for the cheapest nor the big ad companies find a small family ran buisness that has referrals Facebook is a great place to find contractors the yellow pages and craigslist avoid these days. If the unit is new cleaning it will not solve anything this is clearly a bad installtion.
Posted on Aug 14, 2014
First of all, clean your outside coils so that you are assured of good cooling air. The compressors have an overtemp device that is usually internal to protect them against heat. If you have an air compressor use it to blow out the coils good. If the compressor will start, the capacitor is good so it sounds like a cooling problem with the compressor
Posted on Jun 25, 2009
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Replacement for 20yr old A/C system
I you have a 2.5 ton condenser on a 3 ton coil, and he gave you an estimate for a 1.5 ton condenser only, he missed something, or you need a second estimate. Now if give you an estimate for a complete system, with a 1.5 ton condenser/evap, coil, your ductwork will/may be oversized for that unit. Need a second estimate. You've been happy with a 2.5 ton cooling capacity in the past, don't settle for anything less, unless you've completely updated with new doors, windows, insulation, ect.... I'd call around and ask for an estimate, with a load, and then ask for the cooling tonnage and furnace BTU's from that load, when they call with the price. Most reputable companies will/can prove a proper load calculation and my city just made it mandatory to prove a load was achieved when a permit is pulled due to the Dept. Of Energy passing laws on this subject in 2015. Ask if its mandatory for a load calc. if they pull a permit. And they are supposed to pull a permit in city limits I'm sure. It's not a good practice to miss match systems with current designs. 20+ years ago it was, but now there are codes against this practice. And also shortcuts to try to make more money with less invested may not be considered GOOD PRACTICE. Hope this helps!
Mar 13, 2017 | Heating & Cooling
I have an older Lowrance, Model X65, which until a few weeks ago worked as if still new. I hadn't used the boat for the past few weeks and when I did the Lowrance screen now has a large brown spot in...
You need to contact Lowrance about the repair.
My really older, but loved, unit failed and Lowrance pointed out that techonlogy is SERIOUSLY imporved, and convinced me to upgrade to a new unit. I disliked the price, but LOVE THE unit. TONS easier to read, even in bright sunlight, depth sounder portion much improved...twin beams really makes accurate reading, and fast readings (unlike older units).
May 08, 2011 | Lowrance Boating
I have a new kenmore ac unit model 580.75101500 i bought about two weeks ago and installed last week. its been blowing ice cold as it should no problems until today. Now the ac turns on runs about 5...
Take it back or call Sears. A 2 week old unit should not do that. I'll assume the settings are right like set on AC Auto or Max cool and not just fan. Are the coils icing or were they icing behind the filter? If not, I think it may need to be serviced.
Aug 07, 2010 | Kenmore Heating & Cooling
I have a Lennox CH23.51 series coil unit using R22 freon installed one year ago. Compressor is 9 years old. Down the road when replacing compressor (R410A ), will CH23.51 unit be compatible after changing...
This evaporator core is R-22 / R-410A compatible. The Thermostatic Expansion Valve (TXV) is for R-22. If retrofitting to R-410A, a new TXV metering device would be required, but the evap. core itself could be re-used (as long as you stick with the same Tonnage you have now). If upgrading to a higher tonnage system (like going from 4-Ton to 5-Ton), then you would need a totally new evaporator core.
Jun 08, 2010 | Heating & Cooling
Is there a system mismatch with an American Standard 13 seer 3 ton compressor and a Nordyne 3.5 ton air handler? Noise at TRV when heating.
This must be a heat pump? Sometimes the unit can be more efficient with this combonation. What you are probably hearing is the reverse direction of the
refrigerant going back through the liquid line.
If in cooling sometimes you can hear a gurgling sound going through the expansion valve, sometimes
this is a sign of low refrigerant or the system is fine..
If you recently had the outdoor unit replaced and noise is an issue, check to see if the unit has isolation pads installed underneath the unit whether
it be on concrete slab or on brackets mounted to
house. Sometimes the new units come with compressor that has a jacket installed over it
Feb 14, 2010 | Ruud Central System Air Conditioner
New Goodman condenser unit run almost contiously using too much e
I'm not sure of the kilowatts. The 10 min on and 5 off is telling me there is to much heat by the thermostat or you house needs more insulation. The new compressor is designed for more efficient run time. The other thing is the unit to big for your house? It should run 10 -15 min when low humidity is in the house. Otherwise longer if its pretty warm inside.
Jun 11, 2009 | Goodman Heating & Cooling
Residential HVAC - Repair vs Replace? Heat Pump? Two Stage AC?
for 65 dollars i would replace the coil I do however love gas and heat pump combos it will cut your gas bill by about 75% only uses gas below 30 deg
you may want to try a honeywell 8000 stat it has random circulation fan comes on and just circulates the air also used for gas hp combo with an out door sensor and you don't need the fossil heat kit as for the copper if possible replace it due to don't trust any ones soldering as for units the are all about the same look for warranty some replace unit others have life time comp if only going to be in house for 10 yrs hard to recover cost give replacement allowance when sell
May 11, 2009 | Ruud UBHC Air Conditioner
Ruud UAMB Air Conditioner Logo
277 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
