Question about Kohler 2832-96 Garamond 19.5" Cast Iron Bathroom Sink
Hole in an old cast iron sick
I have a 20's house and I think an old cast iron enameled covered sink. I have recently found a hole around the plug area which looks like it has rusted through. It is only small, maybe 2mm but means that the sink leaks and I can't use it. Do you know if I can repair this with anything, like resin or sealant?
  • angelanippar Jun 26, 2009
    what does jb mean?
  • 4 Answers
Jb weld it
Posted on Jun 26, 2009
Adjust flame
Do not attempt to do this task yourself, you should call a Gas Safe engineer to solve the problem.
Jun 29, 2013 | Verona CTG424SE Gas Four Burner Cooktop,...
Will Kohler Disposal Flange K-11352 work with Kohler Sink K-5924?
Kohler makes their sinks standard, and most all sinks are the same size hole, yes it will fit.
May 22, 2010 | Kohler Plumbing
Crack in farm house undermount sink Kohler
Possible you could use an epoxy or J B Weld to repair it. I have fixed a couple of gas tanks with JB weld it should work on Cast also . It not to expensive and may be a start for you.
May 02, 2010 | Kohler Nice Cast Iron Kitchen Sink
Husvarna chainsaw hole in oil lubrication tank
J-B Weld is probably your best option. Cleaning it so it adheres properly is the hard part. Did you ask your local Husky dealer? They may have some options the average owner does not. Phone calls are inexpensive.
Probably cast aluminum, maybe magnesium. HTH and Good Luck.
Lou
Feb 16, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a kohler cast iron enamel sink. The
ALL BASKET STRAINERS ARE PRETTY MUCH THE SAME. PLUMBERS PUTTY WORKS FINE. I BELIEVE ITS THE ORDER OF INSTALL THAT IS CAUSING THE LEAKS. STRAINER AND RUBBER GASKET GOES IN FROM THE TOP. IF NO RUBBER GASKET IS PROVIDED, THEN PLUMBERS PUTTY WILL SUFFICE. UNDERNEATH, ANOTHER RUBBER GASKET AND/OR PAPER GASKET, THEN THREAD ON THE NUT. TIGHTEN IT SNUGLY.
Dec 25, 2009 | Plumbing
I have a black enamal cast iron jacuzzi kitchem sink with 4 holes for the faucet predrilled..the holes are 3" in dia. where can I find a faucet for this sink?
If you have a 3" hole I would definately say that is a special order faucet, But if 3" is a typo you can get what are called "cockhole covers" to cover the hole you're not using. What i usually do is, find a faucet that will use the 3 holes and install a soap dispenser, filtered water spigot, or a instant hot water spigot to fill the fourth hole.
If 3" is not a typo you might try to contact a granite countertop co. or call Jacuzzi and install a larger plate that will cover large holes and have new (smaller) holes drilled for a standard faucet
hope this helps
Jun 03, 2009 | Jacuzzi Kitchen Iron Black Finish...
Belfast sink repair company in ireland?
Sorry to disappoint you, but unlike steel or cast iron ceramic sinks cannot be re-enamelled. To do so someone would have to grind off the remaining enamel and then reapply and re-fire the sink: not only would this be very laboiur intensive but the sink would be unlikely to survive the mechanical and heat processes involved.
If you can't live with your crazed or cracked enamel then buy a replacement sink. They're still manufactured as there is a demand for them.
Mar 06, 2009 | Lefroy Brooks BELFAST SINK SLOTTED WASTE -...
CAN I USE ENAMELED CAST IRON POT ON MY NEW GE GLASS TOP RANGE
yes they can just cant slide them around cause of scratching but as far as performance they are fine
Dec 30, 2008 | GE Spectra JBP78 Electric Kitchen Range
What Kind of Sinks?
Sinks are made of many different materials. These include Stainless steel, Enamel over steel or cast iron, Ceramic, Plastic, Soapstone, Concrete, Terrazzo, Totianota, Wood, Stone, Copper and Glass.
Aug 27, 2008 | Jcp Home Collection Marble-Top Vanity w/...
Enameled Cast Iron Pans In Sharp Convection Microwave 820
It should be fine, but to be sure I'd contact Sharp.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277).
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 10, 2007 | Sharp R-820B Convection/Microwave Oven
Kohler 2832-96 Garamond 19.5" Cast Iron Bathroom Sink Logo
152 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
