Question about Amana PTH153B35AE Air Conditioner
Heater blowing out cold air
The heater worked fine for about 2 weeks and then it started blowing out cold air instead of warm. Could this be a heating element???
    Problem Solver:
  • 18 Answers
Re: Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Posted on Dec 23, 2007
0 characters
3 Points
SOLEUS KFHHP-22 - Heater doesn't blow air at all, warm or cold. Cooling works great but no heat.
Doesn't matter how hot it was when installed, there still should have been proper start up performed. That means running unit thru all cycles and checking charge. If it was installed this summer then installer should warranty service to return and complete install properly.
Nov 15, 2012 | Soleus Air KFHHP-22 22000 BTU Mini Split...
Why is ge ajes12dcc 11600/11400 window air condition/heater combo blowing cold air for heat the air conditioner is working fine but the heater is blowing out cold air
Hi, it sounds to me like your reversing valve is not switching the flow of freon over to heat, stuck in cooling. The valve is located near the compressor, it has a 24 volt coil on it. If you unplug it, it should switch the valve into heat. If not, the valve is probably froze stuck, and will need to be replaced. Something a service tech would have to do.
Nov 06, 2011 | Carrier XHB123D X/Y Series Heat/Cool Air...
Furnace is blowing cold air.
You must have an electric furnace, gas furnaces only come on when the heater is warm. Electric heaters come on with the use of a sequencer. Your sequencer, tstat, and blower is fine, which means you must have broken heating element. I have a nice pictoral of how to restring one HERE
Feb 21, 2011 | Carrier Air Conditioners
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Blowing cold air instead of the heat
Heater coil has possibly burnt out. his coil is located rightr behing the front coil of the a/c You need to pull the unit from its sleeve and look inside behind the a/c coil and there it is. It looks like the inside of a toaster the elements should be incased in a metal box. What causes the burn out is 1 poor air flow over coils due to dirty filter or dirty coil, 2 dust build up, the minute particals the get through the unit 's filter and build up over time causing burnout, 3 possible high limit switch on the coil housing itself. This switch prevents the heater from overheating and causing a fire. Have this look at by a tech the cost incurred isn't really that much.
Good luck on your repair hope this helped
Dec 10, 2009 | Frigidaire FAC126P1 wall/window Air...
I dont know how to get it to heat
hi! there if you have ac running in your house try to see in the contrrol panel the heat logo or the word heater then turn in select heater or warm.then switch on adjust your thermosetting behind that cold and hot control,if you using remote configure on menu.have a warm day thank alot regards
Mar 23, 2009 | Air Conditioners
Intertherm heater blows cold air.
do you have elec or gas heat? nat or propane?
Nov 16, 2008 | Intertherm P3RA-048K Air Conditioner
Unit blows cold air instead of warm (burrrr)
Nov 23, 2007 | Amana PTC153B50AJ Electric Heat Air...
Amana PTH153B35AE Air Conditioner Logo
2,192 people viewed this question
Top Amana Air Conditioners Experts
D. E. Hev
Are you an Amana Air Conditioner Expert? Answer questions, earn points and help others
