Question about Toshiba DKT-2020 Corded Phone
Trying to Change Display Name
I too, get the same problem here. When I press the DN key and then #621, I only get "DATA PROGRAMMED". There is no way to get into edit mode at all. Is there another way to do this? And please don't give me the same instructions that were posted before. As I said "THEY DO NOT WORK!!!!"
    Problem Solver:
  • 11 Answers
Iicm #620 or #621 will only work if your system is a DK 14, 40, 40i or 424. If it is a 8,16 or 280 try without the #
You may want to try here http://www.sundance-communications.com/cgi-bin/ultimatebb.cgi?/ubb/forum/f/11.html
for more info.
Posted on Jun 27, 2009
2 Suggested Answers
  • 3 Answers
SOURCE: Can't change previous name
DN is your extension number.
Posted on Mar 26, 2010
I am trying to change my display name what does dn mean in the instuction dn+#621
Hold the DN key while pressing # then 6 then 2 then 1 would be my guess.
do yo mean DND - that would be the Do Not Disturb button - not sure what just DN would be
Feb 16, 2010 | Toshiba DKT3020SD Corded Phone
Change name display on Toshiba DKT2020-SD
Press "intercom" button, then #621. Use * to move the cursor all the way to the left. Use the # sign to change from numbers to Alpha. For example: You want "N", but the "M" comes up. Press the "0" to toggle to additional letters on same number key. For a SPACE, use the number 1 and toggle to get a space.
Nov 04, 2009 | Toshiba DKT-2020 Corded Phone
I am trying to change the name display on Toshiba DKT2020-SD... I tryed using #612, or intercom #621 I have no DN button... I get DATA PROGRAMED...but cant seem to do anything from this screen. I know I am...
You are on a CTX system and are using the wrong code. On most CTX systems this must be done through the Admin software which is dealer propriety...good luck
Trying to change the display name on a DKT
DN just stands for "Directory Number", which is also another name for an extension number. That button should either say EXT______, ot DN______ or Intercom.
So, just push any of those buttons, and dial #621
Nov 03, 2009 | Toshiba DKT3020SD Corded Phone
How do I change the persons name that is programmed on the phone already?
go to administrator phone
usually are receptionis phone
press MODE button
press ADMIN
key in pasword "0000"
display show phone name
press HOLD to skip
display show DN ID
DN stand for extn number
key in extn number
the exiting name will shown...use scrool n page for backward n forward the cursor
key in the person name
press hold to confirm
to exit press MODE button untill time n date r displayed
Apr 07, 2009 | Toshiba DKT3010SD Corded Phone
Programming a Name in Toshiba DKT3020-SD
To edit display name on LCD DKT3020-SD.
Follow this sequence:
Mode
Scroll
Enter passwork - 0000 is default
Hold
Hold (again)
DN ID (This is your phone extension #)
Old name should now be displayed. Hit page button to delete letters, scroll button for space.
Use characters for the the associated number key to enter desired name. For example if you want an "F" you would hit the 3 button 3 times. After your name is entered, press hold. Pick up and put down receiver.
Mar 11, 2009 | Toshiba DKT3020SD Corded Phone
Your Toshiba Name Change question of Apr 2008
Maybe I can help, Press ( DN ) + #621
Display changes to USER NAME ?
Enter new name
Press SPKR
1 - moves right
* - moves left
# - toggles between alpha mode / numeric mode
0 - scrolls the alpha / special characters
To blank out any portion of name press 1 ( in alpha mode ) and move cursor to thr right
Good Luck
Aug 05, 2008 | Toshiba DKT-2020 Corded Phone
I am assuming you want to change the display to read another persons name, or blank. If that is correct:
Press a [DN](labeled intercom on my system) + #621.
That opens edit mode.
an example. My phone reads "MARK 29"
where Mark is the user, 29 the extension. John replaced
Mark, so target is "JOHN 29"
so intercom # 6 2 1 puts me in edit mode
# toggles between alpha/numeric
* moves the cursor, I repeat * until cursor is under M
Hit the 5 key, changes the M to J and moves cursor under the A.
Hit the 6 key, the A changes to M, and the cursor moves to under the R. I hit 0 which changes the M to N. I hit 0 again, the N changes to O.
Hit the 4 key, the R changes to G. Hit 0, G changes to H.
Hit the 6 key, K changes to M. Hit 0, that changes the K to M. Hit 0, M changes to N.
We are done, as the extension number stays the same. Hit spkr key to leave edit mode.
Hope that helps!
# toggles alpha/numeric
Dec 10, 2007 | Toshiba DKT-2020 Corded Phone
Change name on LCD display
The Toshiba phone you have can work on a few different Toshiba phone systems that program differently. Before I can look up the correct information to help you I will need to know which Toshiba phone system you have. Someone at the office should know but you can also track down the phone system and get a part number or other identifiable markings from it. Older Toshiba systems were typically a light gray color and the more phones you have the bigger it will be. The newer systems are usually dark gray (almost black) there will be a lot of wires going in and out of it and most likely a punch down block or two right next to it (white, about 12" tall, 3" wide, with hundreds of small metal pins to connect wires to.)
Oct 31, 2007 | Toshiba DKT-2020 Corded Phone
Toshiba DKT-2020 Corded Phone Logo
409 people viewed this question
Top Toshiba Lands Phones Experts
Oloyede Monsuru
Are you a Toshiba Lands Phone Expert? Answer questions, earn points and help others
