Question about Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Wireless Issue
I have a Dell Inspiron 6400 and sometimes after I use it for prolonged times the wireless light will switch off and I will be disconnected from the internet. This has nothing to do with the router as other computers can work fine and mine does as well once I restart it. The issue is that it does this automatically when it shouldnt for any reason. It also doesn;t let me access the wireless network connections as it is frozen and nothing pops up. I can do this when I first boot up my computer or am not having this issue. Is there any fix for this? Please advise, thanks
  • 30 Answers
Go to start then run... type devmgmt.msc...then go to network....look what driver is under wireless.
Go to this link... http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
go to network then match the driver to the one that is listed in the device manager. Download the driver and reinstall it.
Posted on Jun 25, 2009
No Internet
You need to check first if the wireless switch is turn on.If it is on, check the function key for the wireless. Some computers have function key. Sometimes it is combination of fn and f5. Press those keys at the same time and you should see a pop up window and check if the current status is on. If it is on, uninstall/reinstall the wireless driver in device manager. and restart your computer. If this didn't work. You need to do re installation of your operating system.
Jul 17, 2010 | Dell Computers & Internet
How do i switch on the wifi in my dell inspiron 6400? The Fn + F2 command is switching on the bluetooth only
You can turn on/off Bluetooth and Wireless using the Fnand F2 key.
To enable or disable wireless networking, press <Fn><F2>.
Turns on when a card with Bluetooth® wireless
technology is enabled.
NOTE: The card with Bluetooth wireless technology is an optional feature, so the ordered the card with your computer. For more information,
see the documentation that came with your card.
To turn off only the Bluetooth wireless technology
functionality, right-click the
area and click Disable Bluetooth Radio.
To quickly enable or disable all wireless devices, press
<Fn><F2>.
Please refer the page #69 to 74 for complete information on the Wireless and Blue-tooth
http://support.dell.com/support/edocs/systems/ins6400/en/om/MD402AO3.pdf
Jun 28, 2010 | Dell Inspiron 6400 Notebook
3 lights o right hand side of laptop what do they mean
The user manual will supply an in-depth explanation of the led-indicators, aswell as there are normally small icons assigned to each light, sometimes engraved in the plastics, normal lights to be active at average usage are the Power led indicator, will glow as long as device is turned on, the Wireless led indicator will glow when the wireless network module is active, the CPU led indicator will flash occasionally when system is idle, and rapidly when system is active under load, and the Battery led indicator will be active when device is running on battery power. When device goes into sleep or hibernate mode the sleep led indicator might continuously glow or slowly switch on & off varying between systems.
May 27, 2010 | Dell Inspiron 6400 Notebook
How toturn on wireless in dell inspiron 6400
There is a wireless switch in Dell ... So try to press and hold the Fn key and then press either F2 or F4 (whichever has the wireless icon made on it).
Nov 18, 2009 | Dell Inspiron 6400 Notebook
you should have a key on keyboard in lower left corner by windows key that says"FN" then hit "F2" that should do it, if that is not the case then there should be a switch along the edge of machine
May 01, 2009 | Dell Inspiron 6400 Notebook
Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
Apr 11, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 cant get wireless connection
The Wi-FI light turns on when wireless networking is enabled. To enable or disable wireless networking, press and hold the blue <Fn> key and press the <F2> key. The <Fn> key is located on the lower left hand side of the keyboard.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 19, 2009 | Dell Inspiron 6400 Notebook
Home wireless network
A wireless router of course :-)
Az.
Sep 17, 2008 | Dell Inspiron 6400 Notebook
DEll Inspiron 6400 WIreless Adaptor Problem
Check if the wireless switch is present or not present.
Manually Enable the Wireless Adapter if present
Check the side of the notebook computer for a sliding switch.
Wireless Switch in the On Position
First you turn off the system flip it upside down then locate the battery and take the battery out and make sure you disconnect the ac adapter,.
http://support.dell.com/support/edocs/systems/ins6400/en/om/parts.htm#wp1052769
Click on this link this will help you to locate the Wireless Mini-Card and try to take it out from the system and reseat it back then turn on your system u will find the sytem will automatically detect the device and will resolve the issue.
let me know if i would have been a help or not
Regards
Moses
Jan 12, 2008 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 Notebook Logo
514 people viewed this question
Alun Cox
