Question about Uniden Cordless Phone
Terrible static on 2.8Ghz 2-line phone Model EX 13226
I'm getting alot of static lately on both lines. I don't think it's the phone line itself, because other phones work and it's a FIOS line. I've had the phone about 10-12 years. Time for a new one ?
The phone has another problem that I've lived with for a long time - when I'm talking on Line2 and a call comes in on Line1, the ring comes in very loud in the middle of my conversation.
  • 4 Answers
Do you have internet plugged in to it. You may need a microfilter which you can buy or if they came with your router .try it
Posted on Jun 25, 2009
Can the digital recording be cleaned; I get lots of static on a recorded message?
There's nothing in your recorder to clean, but. . Static in the message likely indicates a problem with the phone line itself, or at least the connection from the phone line to the recorder. You can clean that.
May 26, 2015 | Lands Phones
I don't know much about this sort of thing, or know if it can be fixed but I'm tired of it. I play online games via steam and the modem, a speedtouch thomson st536, will randomly disconnect. I know...
The line filters may be faulty. You may need to replace some lins filters.
Try disconnecting all your phones and faxes while you are on the Internet to see if the problem still occurs.
Check with your ISP, they can check your modem connection.
Check the line filters on all your phones and faxes.
Aug 27, 2011 | Computers & Internet
Static lines
when you hear static you lines on your cellphone it maybe the time to replace your earpiece, if you don't hear static lines when you use a headset then your earpiece is busted but if you still hear static lines while on your headset it means that something's on your surroundings that interrupts your signal it could mostly be a radio or a metal that could strongly blocks your radio wave. if this is helpful, please vote for me
Jun 27, 2011 | Nokia 3110 Cellular Phone
Crackling static noise on calls
Make sure that there is no fault inthe connection from the line terminals. If both the sets have the same noise connect a base phone and test the line as it can be from the telphone line itself producing the static from the nearest junction or cable line.
If not the base phone input section may have errors.
Sep 26, 2010 | Uniden Cordless Phone
Phone line static
with the modem disconnected and the static is still there , indicates a problem service land line
ask your service provider for a line check because of the noise
Nov 22, 2017 | Motorola Mobility MD481SYS Cordless Phone
How do you receive fax on hp officejet 4110
Do you have any Digital Answering Machines in the house?
or is it a dedicated line?
anyway heres the link for the 3 digit error codes document, its a public document that can be found by searching www.hp.com using this Article #: bpu02549 or buu02549
anyway as you can see 388 result/solution is the following...
Problem: Unable to complete the connection.
Solution: *Reattempt the fax reception at a different time when telephone line conditions have improved.
Now this means that one or both fax machines can have a problem. So lets isolate the problem.
Place a regular phone into the wall jack that the OJ 4110, if there is a static sound then its the phone line that is having the problem. if there is no static continue on...*Note if you have a DSL Internet service you NEED a filter for the fax*
What this is most commonly caused by is Bad line conditions which can occur in some different ways.
1) If there has been recently a Thunder Storm the electrostatic discharges interupt phone signals.
2) Recent power line downage
3) Recent Phone line downage
4) The phone company upgrading the lines
But basically something is BLOCKING the faxes from hearing each other. That is why you get this error code.
You can call your phone company to run a line trace. The reason you want to do this is so that you can eliminate the possibly of Static, Yes there are differnt types of it;
1) the normal static that you and me can hear
2) the SuperSonic Static, AKA Static in the Higher Frequency Ranges, where your DSL internet connection is. the Fax will pick up on those Higher frequency ranges, and it will cause problems. So put a DSL Filter on the Fax it wont hurt, and most of the times it helps alot.
Again Make sure ECM is disabled.
other than that, try unplugging all devices on the phone system an try...
i think there is alot fo information, i cant think of anything else...
Hope that helps
Jun 19, 2009 | HP Officejet 4110 All-In-One InkJet...
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Static from SoundStation Premier
Check the phone cable you are using for your POTS line. Attach a phone directly to the phone jack and see if it is clear or static without the device.
May 20, 2008 | Polycom >>> SOUNDSTATION PREMIER EX /AVAYA...
Incoming calls loaded with static and I cannot hear them clearly
Try connecting line 2 where 1 is connected. If there is no static it is youre system ie phone itself. If there is static there is definately a problem with youre line. Static can usually be attributed to old lines that the moisture barrier has been compramised. If the line is under youre house or in the walls you may have to pay for it. But if it is the companys line it is their issue.
Mar 26, 2008 | Panasonic KX-TG6700 Phone
Poor line condition error Brother intellifax 5750e
Poor line condition is an error referring to the phone line itself. Even though it may sound clear small amount of static confuse the fax machine and cause the error. Try using a new phone line. If that doesn't help I recommend getting a line filter from OfficeMax
Oct 11, 2007 | Office Equipment & Supplies
Uniden Cordless Phone Logo
279 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
