Question about HP LaserJet 4350TN Printer
Printing one line on every other page
When I print a document that is more than one page, it prints only one line on every other page. I was told it was a margin issue in my software, but when I pick a different printer to print to, it prints fine.
    Genius:
  • 1,018 Answers
I really would need to see a print file to know what is going on.
Set the printer driver to "Print to File", when prompted, name the file "line". The driver will append a .prn to the name.
The resulting file: "line.prn" can then be analysed using any Hex Editor if it is a PCL file or A Postscript error analyser if the job is in Postscript.
Also, fyi - I do not believe you have a simple margin error. But just to make sure, under page setup, make sure that you have the correct page size selected in the driver and the same on the printer.
Don
Posted on Jun 25, 2009
On my Laserjet 3015, in Microsoft Word, if I set top, bottom, left, and right margins to 1", on the printed page, the margins print as Top 1", Left 15/16", Right 1-1/8", and Bottom...
The default paper selection/ size in MS Word is 'letter'. you may have designed the document on letter size and while printing you have A4 size paper in the printer.
So, Make sure that you design the document on the same paper size (such as A4, which is commonly used). Secondly, while printing don't print the document directly. From the Print dialogue option choose the exact paper size and un-check (de-select) any option of paper resizing (if available). You will have the documents printed exactly as designed.
Let me know if any further clarification/ assistance is required.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 12, 2011 | HP LaserJet 3015 All-In-One Printer
I am a teacher. We have Dell computers with windows 7 on them. Recently our school district downloaded Microsoft Office 10. Since the new microsoft office, my xerox phaser 8500 is printing strange. ...
Hi fsaltzman,
You need to check the margin settings in the print preview option, make sure you decrease the margins that are set by default and try printing a test page , this should work fine.
On the File menu, you need to click Page Setup, and then click the Margins tab.
Here you can adjust the margins as per your convenience.
To View page margins :-
  1. You need to go on the Tools menu, select Options, and then select the View tab.
  2. Under Print and Web Layout options, select the Text boundaries check box.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
May 11, 2011 | Office Equipment & Supplies
The printer cuts off the top part of the document when printing. Is this a margin issue?
Yes, most likely your application's margin settings are incorrect. Try printing a test page - NOT from the application. If this is Windows, go to printers in control panel, right-click on the subject printer, choose Properties, then click the Print Test Page button. You should get the standard Windows printer test page with the logo at the top and all the printer specifics below. If the test page is also cut off, look around in the HP-provided software for any margin and/or page size settings that are incorrect, such as A4 paper when it should really be Letter size.
Feb 18, 2011 | HP Officejet Pro L7680 All-In-One Printer
THIS IS NOT AN ISSUE WITH MY MARGINS. I have Microsoft word 2007, an HP Officejet Pro 8500 Premier and windows vista. After some research I found a commonality with my problem and these three operating...
The problem may lie in the printers setting for the margins. Do you set the margins only in word 2007 or do you check the printers margins too?
Also the issue may lie with the printer having the incorrect paper size
Have a look in the printer properties (When you go to print, its beside the printer selected) and look through there and see if there are any issues.
Dec 02, 2009 | Toshiba Satellite P205D-S7454 Notebook
Printer cuts off last line of text on document
go to control panel and click printers, right click printer and select properties, go to ports tab and uncheck 'enable bidirectional support' box or see thie website http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01672454&lc=en&dlc=en&cc=us&lang=en&rule=22909&product=3560280
Jun 18, 2009 | HP Photosmart C6380 All-In-One InkJet...
Printing problem in Microsoft Word 2003
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Apr 09, 2009 | Microsoft Word 2003 for PC
Printer will occasionally print incomplete document
Sounds like an issue with the bottom margin and/or footer if you are using a footer. Check the page setup and reduce the bottom margin.
Jan 24, 2009 | HP Photosmart C6280 Printer
Envelope margin error
have you adjusted the page setup on your software?
I'm assuming you're using Word to print a mail merge. yes?
Check that the margins are setup properly in the "word document"
Go undetr file, page setup, and confirm the envelope size is set properly.
Check the page setup in the printing preferences.
File, Print, Printing Preferences.
The printer accepts whatever margins microsoft word tells it to use.
Best wishes
www.techvisitor.com
Oct 20, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
Unusual character where special character or underline is given
If you have a spare USB cable around the house, try that first and see if the cable was bad.
Aug 21, 2008 | HP DeskJet 640c InkJet Printer
HP LaserJet 4350TN Printer Logo
106 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
