Question about Canon Office Equipment & Supplies
PRINTER WILL NOT PRINT FROM ANYTHING,I CAN TURN IT ON OK, IT GOES THOUGH ITS NORMAL OPERATION BUT WHEN I SEND A PRINT JOB MESAGE COMES UP FAILED TO PRINT.
    Problem Solver:
Replaced the printer, it was not worth spending any more time or money on.
Thank you for your time and trouble
Posted on Jun 26, 2009
Why do print jobs print out normal, faded, or color (for an all black job) randomly?
I would suggest using the printers self head cleaning as it sounds like the heads need cleaning
Mar 03, 2016 | HP LaserJet CP3505dn Printer
CANON W6400 NO INK COMING OUT
Enter in the mantenace mode and select the head cleaning,roller cleaning nozzle cleaning.
Feb 04, 2013 | Canon imagePROGRAF W6400 InkJet Printer
Minolta Magicolor 3100 ... Printer sayes its online and ready to print. When i send a print job it spools it ok but when it goes to print it goes offline. I delete the print job and the printer is back...
Does the printer show any message on it's display ?
Most common problem with these printers is the driver setting (mostly media type/weight) conflicting with the settings made via the front panel menu's.
Jan 04, 2011 | Minolta magicolor 3100 Laser Printer
I have a Minolta Di351f printer that keeps failing to send scanned documents over FTP. After several restarts it eventually comes back to normal and sends the documents properly again. Is there anything I...
This is somewhat common on these aging machines. The NIC card in your Pi3502 print controller is going bad. It is a common symptom when this happens that print jobs and or scanning jobs take forever to print/send or will stop altogether. The only fix is to try and find another NIC card for your Pi3502 Print Controller. But this can be risky as even another NIC may not work or work for very long as they are getting to be about 8 years old now. I have had to upgrade a few of my customers from the Di251/351 because of this issue.
Good Luck and Thank You for using Fixya.
Aug 30, 2010 | Minolta Di3510f Bizhub Copier
We have an error 49.2 F83 come up on our HPLJ 4015n, How do I fix this and what is causing this?
Thank you for contacting FixYa with your printer inquiry.
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
1- Turn the Machine on.
2- Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
3- Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Feb 26, 2010 | HP LaserJet P4015N Printer
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
Printer problem
Cancel all print jobs because most likley you have an error in a print job so cancel them shut off your printer turn it on nd try to print again
BestWishes                  -SunShine-
Jul 04, 2009 | HP LaserJet P2015dn Printer
Epson printer won't print
That sounds a lot like the print spooler has suffered some kind of problem...
Try the following:
  • Click START > Run
  • Type "MMC" and click OK
  • Click on the "File" menu then "Add/Remove Snap-in"
  • Click on "Add..."
  • Select the "Services" snap-in and then click "Add"
  • Select "Local Computer" and then click "Finish"
  • Click "Close" and "OK"
  • Select the "Services (Local)" line
Tip: This is the same thing as going to Control Panel > Adminstrative Tools > Services
From here you:
  • locate the "print spooler" service
  • Right click and choose "Restart"
This will restart the print spooler.
If the spooler is the problem you should be able to send a print job to the printer and it should now start printing.
If not then the chances are this is either a port misconfiguration or a driver error in which case you should try:
  • unplugging the printer (leave it unplugged for now)
  • uninstalling the drivers and software for your printer,
  • restarting your computer
  • download the latest drivers from the epson website
  • install these newest drivers (plug in the printer when prompted to do so)
If the port was misconfigured this SHOULD solve the issue but there's no guarantees... If you're still having issues, post again and we'll go from there..
Hope this helps.
Martin
Mar 15, 2009 | Epson Stylus 1400 InkJet Photo Printer
Printer won't work, even if goes through printing motion, says ready, etc , shoots out paper.
Do you have the installation disk for either printer? If so simply reinstall over the existing ones. If you do not- Go to Start/printers and Faxes Clcick on install new printer. Select from list Select make Select model select OK
May 06, 2007 | HP DeskJet 648c InkJet Printer
24 people viewed this question
old marine
old marine
