Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Unable to print 30 or 50
I am getting 2 error messages- 1. unable to print 30 2. unable to print 50this happened after a paper jam... NO PAPER LEFT ANYWHERE I CAN SEE OR TOUCH'
  • 526 Answers
The encoder strip is probably out of its socket. its a long mylar strip that goes from one side to the other, and goes underneath the printhead.
Posted on Jun 26, 2009
Hp 5660 photo paper jam from placing in wrong tray.
HP Printers - 'Paper Jam' Error ' HP® Customer Support
https://support.hp.com/ca-en/document/c04348351
This document troubleshoots how to clear different types of paper jams from error ... 5542, 5544, 5545, 5546, 5547, 5548, 5640, 5643, 5644, 5646, 5660, 5664, ...
Solved: HP Envy 5660 - Paper jam message - HP Support Forum ...
https://h30434.www3.hp.com/t5/Inkjet-Printing/HP...5660-Paper-jam.../td.../4673198 Nov 4, 2014 - 4 posts
Solved: Our HP Envy 5660 printer is 2 weeks old. It was purchased at an ... An error message popped up reporting a paper jam issue. Followed ...
help HP printer Envy 5660 Error "load photo paper in tray" - HP ...
https://h30434.www3.hp.com/t5/LaserJet...HP...5660...photo-paper-in/td.../5285421 Oct 5, 2015 - 2 posts
A new Envy 5660, can't get it to print 8x11" size, keeps error message, "load photo paper in tray", need to know how to set printer to print on regular size paper. ... I see you are trying to print to your HP Envy 5660 but you keep getting an 'Load photo paper in tray' error message.
HP ENVY 5640, DeskJet 5640 Printers - A 'Paper Jam' Message ...
https://support.hp.com/ca-en/document/c04759464 There are three different areas where paper might become jammed. Clear any jammed paper from one area, and then try to print again. If the error persists, ...
Paper Jam Or Tray Problem - Hp Envy 5660 Instruction Manual [Page ...
https://www.manualslib.com > ... > Instruction manual HP Envy 5660 Manual Online: Paper Jam Or Tray Problem. Paper has become jammed in the printer. Before you try to clear the jam, check the following: Make ...
Fixing a Paper Jam on the HP ENVY 5540 Printer - YouTube
? 14:06
https://www.youtube.com/watch?v=mrjGs1ahOjw
May 17, 2016 - Uploaded by HP Printer Support
Learn how to clear a paper jam hp 5660 photo paper jam Google Search
Jun 20, 2017 | HP Office Equipment & Supplies
Unable to print
I have a Brother MFC665CW and it has error message
"Unable to change 50" after paper jam. Paper is all cleaned
out of machine and still shows message.
cenprop@bigpond.com
Apr 08, 2010 | Brother Office Equipment & Supplies
HP Deskjet F2290, unable to print after paper jam
just On it twice and then off,, check you have removed paper jam and installed drivers.. aall
Sep 28, 2009 | Office Equipment & Supplies
Paper jam. caused error print unable 30
"Machine Error 30" (or "Unable to Print") indicates either a simple problem such as a paper or part of a paper stuck inside the machine, which of course is solved by opening the machine as much as possible and remove the reason for the jam.
Even a ripped part of a paper will be able to cause the paper, so it's important to be careful when taking jammed paper out to not rip the paper (do this by carefully pulling the paper among the same way as it would go when printing, not the opposite direction).
However, if that doesn't work, the error is mechanical (but still most likely caused by the jam, either a sensor getting dirty and unable to do it's work, or actually getting broken), and there isn't much you can do. If the message comes back right after turning on the machine, you'll have to have service performed on the machine.
Jun 16, 2009 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
Epson R320 "General Error" message - unable to clear
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam,
and then press OK to continue' error message
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Reconnect the power cord and turn on the printer.
http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
Feb 22, 2009 | Epson Stylus Photo R320 InkJet Printer
Clearing an error
well, one of two things have happened, 1. you haven't removed all of the jammed paper, maybe you left a small piece of a piece of paper or you may bent or broken your paper jam sensor. go through the paper path very carefully and check both things.
mikey
Mar 14, 2008 | Sharp UX-B20 Plain Paper Inkjet Fax
Error message print unable 50
the encoder strip which gives the printhead the position is out of place (error 50). You have to open the printer and reinsert the strip:
http://www.fixya.com/support/t211210-brother_mfc845cw
Stick a 1.5 inch tape onto the printhead cover where the strip runs thru. This will prevent this accident in future!
Nov 05, 2007 | Brother IntelliFax-2480C Fax
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
942 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
