Raymarine Ray100VHF 2-Way Radio Logo
A
Anonymous Posted on Jun 03, 2014
How do I update my MMSI? - Raymarine Ray100VHF 2-Way Radio
ka4iup
Level 3:
  • Raymarine Master 4,062 Answers
  • Posted on Aug 21, 2014
ka4iup
Raymarine Master
Level 3:
Answers
4062
Questions
0
Helped
1096470
Points
51404
You can download the user manual from here: http://www.manualslib.com/manual/314004/Raymarine-Ray-100.html
2answers
I need to reset Simrad AI50 ais to a new MMSI.. Thank you
This is the official line
Can I change the MMSI number entered into a VHF radio or AIS unit?
Once entered and confirmed, the MMSI number can only be changed by a certified technical dealer. If you need your number reset or changed, it is recommended that you contact the organization or agency which originally registered your MMSI. For more information about MMSI numbers, go to the
United States Coast Guard website at this link.
And
https://www.justanswer.com/boat/au99m-received-emailed-info-from-simrad-reset.html
This doesn't sound hopeful!
https://mt.panbo.com/2015/07/simrad-ai50-mmsi-reset.html
Full story
https://www.google.com/search?q=reset+Simrad+AI50+ais+to+a+new+MMSI
Password for sam electronics AIS debeg 3410 for configuration change mmsi
we are not Password fix dot com.. we do not hack PW here
in fact doing that now is ILLLegall .
it is not any computer, at all .
it is 2008 , 12years old.
lost the manual? google finds it 2nd hit.
a Marine VHF radio, did kid play with it and lock it out? or?
what need to do is reset the radio, (ask maker yet?)
or just changing the
Maritime Mobile Service Identity
why not be clear on what works and not. both matter.
if yes,
read this
https://www.boatus.com/MMSI/MMSI/Home
How do I reset my MMSI number on my Standard Horizon HX751 hand held unit.
You cant. Contact previous owner and ask for mmsi transfer or contact manufacturer about how to program new mmsi number.
WHERE can i get by MMSI NUMBER from on a boat VHF RADIO
here
https://www.boatus.com/MMSI/MMSI/ObtainMMSI#!
Mar 05, 2018 • VHF Boating
Where can I get my MMSI number form
from the marine authority in your country ?
if you were from the usa it is
https://www.boatus.com/mmsi
However I don't know which part of earth you do your boating in ?
google search mmsi and add the country you are from ?????
Entering my MMSI number i can get to the setup screen but won't go to the next step
Has it ever been setup for a MMSI? If so, I think they can only be set once and need to be cleared by the factory to be ready for a "new" MMSI to be entered.
1helpful
How do I enter an MMSI number into my Uniden UM415 It is useless to call Uniden, I have already wasted 3 hours on hold with them.
Hi Peter!
NICE radio Man. You're right, Uniden customer service is horrible.
Ok, here's the deal. You HAVE to get this right the first time, otherwise you pretty much have to send the unit back to Uniden.
Press and hold CALL until the setup menu appears.
Press ENT (1W/25W), that gets you to the user MMSI portion of the program.
NEW should be what you see on the screen.
Press ENT. That'll get you to where you actually get to enter your number.
Using channel up or channel down, set the first number.
ENT
The cursor moves to the next digit.
Repeat until your full MMSI number is entered and displayed on the screen.
IF YOU MAKE AN ERROR, don't panic, press clr/scan and the cursor will move back one spot to the left, erasing the wrong digit.
When the ninth digit is correct, press ENT. The screen will display your MMSI number and ask you to confirm. To save, select yes. To cancel, select no.
Before saving the number, your radio will ask one more time if you wish to confirm and warn you that this is a permanent setting.
Press ENT to confirm, or CLR to start over again.
Hope this helps.
-Steve
Oct 15, 2014 • Boating
Need to reset mmsi number
I don't think the RAY100 is DSC compatible and therefore doesn't have the MMSI programmed into it. Most manufacturers limited the number of times that the MMSI can be programmed to one (!). After that, it has to got the factory or to an authorized dealer who can bypass the restriction.
Need to reset the mmsi
Did you ever solve this problem. I have just purchased a little Leisure 17-SL with a fairly new one of theses radios. I have the handbook and discover you can only program the MMSI once and then return to a dealer to clear it!
Many thanks
Steve http://www.withamweather.co.uk
Top Raymarine Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Raymarine Radio Communication Expert? Answer questions, earn points and help others
