My Tricity Bendix Aw1001w is on the blink. It will heat up and wash clothes but when it comes to rinsing them the drum won't spin but it still empties the water slowly at regular intervals(I have tested this when the machine is empty). Is there anything I can do
  • 15,935 Answers
It appears your lid switch/door latch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!!!!!!!
Posted on Sep 15, 2010
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Where is imbalance switch on tricity Bendix aw1000w and how can I reset it
there is no imbalance switch on any washing machine these days. Any imbalance on loads is picked up by the Tachogenerator located on the back of the motor which sends an impulse to the speed control on the machine. Dont bother trying to find it its nothing more than a coil which is not in anyway adjustable. If you are having problems spinning clothes ensure the drum is full but not tightly packed. if you have to do a small load and it won't spin take the clothes out of the machine, separate them then put them back in and try spin again. and ensure your machine is level on the floor and doesn't rock when tumbling.
Nov 23, 2014 | Tricity Bendix Washing Machines
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Tricity bendix aw1001w has an unknown error code, the led labled end flashing 3 times, any ideas?
It could be one of the E30 codes which would relate to the pressure switch or an earth fault on the heating element there could be a wiring fault or p.c.b. fault check wires off heater at bottom rear of machine,remove back plate 4 screws.Hope this helps.
Good Luck.
May 07, 2010 | Tricity Bendix AW1200 Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Washing not being spun properly or machine emptying fully
If it has a filter, remove and clean, check for blockage and or obstuction in drain hose
Dec 12, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1001w
is the door locking if not replace it.
Nov 23, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
