Question about Kenmore 25842 Top Load Washer
Top Loading washer fills and stops.
Kenmore Elite Mod 110.24964301 first was reluctant to run but after pauses ran the load. Now it will not run after filling with water. I do not see a lid switch and assume it is connected to or operates off the lid hinge somewhere under the top. I'm embarrassed to admit I don't know how to remove the top to see the switch. I believe this machine is at least 7 or 8 yrs old. We have not had to make any repairs until now. We usually buy our appliances from the Sears outlet which sells scratched, dented or returned equipment. I have no reason not to continue this practice. I used to rely heavily on information from Sears about parts and do it yourself repair. While in the Army I could get parts even overseas.
    Problem Solver:
  • 3 Answers
I recognized that I failed to give enough information to allow experienced people to diagnose my washer problem so I decided to watch the entire cycle and hopefully obtain symptoms of the failure. The washer filled with water and then did nothing until I lifted and dropped the lid a second time. The washer started and ran without problems until I lifted the lid during the second rinse. It failed to continue until I raised dropped the lid and dropped it again when it resumed running until the whole cycle was finished.
I believe from this that the lid switch is marginal, fouled with corrosion possibly or otherwise compromised and perhaps near failure. I propose to order a new switch and operate with awareness of the probable problem until the switch can be installed. If anyone can advise how to access the switch I would appreciate that help. I still don't know how to remove the top although once I can view the rear it may reveal options for doing that.
By the way I have a solution for washers that want to move around. I attached four rubber stoppers with a center hole to the washer and the wall using copper pipe brackets used to mount pipe to wood. These are located onto the upper back of the washer at each side. Then two pieces of very heavy wire are shaped like a wide U with a flat bottom and short legs. The width of the bottom determines how far from the wall you want the washer. Turn the U shaped wire legs down and insert them into the stoppers and you will have a vibration resistant hold on the washer that is easy to detach for maintenance.
Posted on Jun 26, 2009
Keeps Stopping and saying UE
uE error code 79631512210 Kenmore Elite Washer - Sears ...
www.searspartsdirect.com > Ask an Expert
Jan 10, 2014 - uE error code 79631512210 Kenmore Elite Washer ' SearsPartsDirect. ... After unloading the washer completely, the machine attempts to rebalance the .... to ensure proper fit and to keep appliances running for years to come.
UE Error code on my front loading Kenmore washing machine
www.shopyourway.com > Manage My Life > Questions
Jun 13, 2011 - I have a Kenmore 3.5 cu. ft. front loading washing machine (model #4027) and it is 1 year old. ... what does the F35 error code on my kenmore elite front loading washing machine mean? F13 code on Kenmore Elite HE3 front loadingwashing machine.
Jan 21, 2016 | Kenmore Washing Machines
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
CAN ANYONE HELP, MY TOP LOADING WASHER KENMORE FILLS UP BUT WILL NOT START
It sounds like the wig wam solenoids are not working,they are what shifts your washer from wash to spin, rinse,etc.They should be mounted under the drum in the center should have a small solenoid on each side 4 wires running to it.It can be tested if you can get it out and if you have a dvom digital multi meter.
May 13, 2012 | Kenmore Washing Machines
Water dripping
Turn the water off at supply valve, this will stop the water. Then you will need to replace the fill valves on the washer.
Jul 05, 2010 | Kenmore 24032\24036 Top Load Washer
My top loading kenmore elite washer model #20972
No, this is probably a direct drive that has a faulty plastic coupling from motor to transmission. Go to:
http://www.fixya.com/support/r385252-replacing_motor_coupling_W... by jsrock516
Please give him a pat on the back for the help.
Oct 12, 2009 | Washing Machines
My Kenmore top loading washing machine is leaking from the bottom. The water is dripping from the bottom of the front panel. What needs to be fixed and how do I do it?
This symptom usually indicates that you have a failed inlet solenoid water valve assembly. Completely unplug the washer from the electrical supply and see if the water stops filling. If it does, then you likely have a control board failure. This is rare but possible. If the water continues to fill with the washer unplugged from electricity, I recommend shutting off the hot and cold water supply faucets behind the washer. It is likely that the water will stop filling the washer. This would indicate that you have a failed water valve assembly.
Jun 28, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite front loading wash & dryer-5 yrs old: should i buy?
all kenmore named washer will have 110 as first 3 digits of model #..the he washers are usually good washers..like all front loads they have their quirks ..if you read reviews from other consumers they indicate problems ..most of which are easily remedied by reading owners manuals..mold /mildew usually a bleach clean every few months ..vibration need real solid floor..oversuds use HE detergents only..just a matter of changing mind set from top loads with 25 gals of water each fill to a front load with 5-6 gals each fill..top load with 750-850 rpm spin speed to front load 1000-1200 rpm ..if willing to learn proper use and what to expect they can best investment..just don't let opinions of those unwilling to adapt affect your decision
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Kenmore 25842 Top Load Washer Logo
99 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
