Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
What causes water to accumulate in the bottom of the refrigerator cabinet?
  • 52 Answers
This would be a blocked outlet.
Posted on Jun 27, 2009
Water accumulating in bottom of refrig.
What is your model number? Every different model leaks differently but the same reason (defrost drain frozen shut) causes water to appear in different places in different models. Click here=> Leaking Refrigerators
I'm here should you have question, Thanks, Sea Breeze
Oct 11, 2015 | Refrigerators
I have water accumulating in the refrigerator compartment. How do I access the condenser area to figure out what is wrong.
http://beverage-air.com/uploadedFiles/docs/SPE60%20Cutting%20Top.pdf
REFRIGERATION
More robust refrigeration system
provides added capacity and efficien-cy. Systems are designed using CFC free R134a refrigerant. Forced
air from evaporator is moved under pans, which are recessed 2" from
top of cabinet. Forced air over the condenser is drawn from back and
bottom of cabinet. Automatic condensate evaporator is provided to
eliminate the need of floor drains.
Automatic condensate evaporator malfunction.
Jun 13, 2015 | Beverage-Air SPE60
Pooling water in drawers and selfs.
This is likely a condensate drainage issue. When warm air enters the refrigerated space it contains moisture. Warm air is able to hold more moisture than cold air, so as the air cools the moisture condenses (hence the term condensate.)
Every refrigerator needs a way for this condensate to drain out of the cabinet. Many have a drain hole on the bottom, but some have a cup on the back (inside) of the cabinet that funnels the condensate to a drain behind it. I'm guessing yours is the latter.
Over time these drains have an annoying habit of becoming plugged with algae and/or spilled food/drink. When this happens water accumulates in the cabinet.
What you need to do is find the drain and clear it. The best tool for the job is a 4' piece of 1/8" steel cable (aka, wire rope) with a fitting crimped onto the end, or a dab of JB Weld, to keep it from unraveling and to keep loose strands from snagging. Gently snake the cable down the drain several times and rinse with a mild bleach solution, or chlorine-based cleaner.
Note that if a lot of water has accumulated the drip pan under the refrigerator may not hold it all, in which case it will spill onto the floor. This is not a problem, as in normal operation that amount of water would not be allowed to accumulate.
Jul 17, 2014 | Kenmore Refrigerators
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
Water accumulates at the bottom of the freezer unit and leaks
You must clear the drain of anything that would cause water to pool up after each defrost cycle. Check your door gaskets for wear. Air entering the ice box can cause excessive frost.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 06, 2009 | Refrigerators
Water accumulation in the bottom of our refrigerator
There is a drain line on the back of the refrigerator. Trace it out to find where it empties into the drain pan on the bottom behind the grill. Take a piece of stiff wire (coat hanger) and gently push through it to remove any blockage.
Apr 20, 2009 | Whirlpool Refrigerators
Water is accumulating in bottom of fridge under produce drawers
Possibly your defrost drain found inside the freezer back wall is blocked. If you could send me the model number I could help you better. Thanks, Sea Breeze
Look at following areas for the model number
  • Beneath Or Inside Food Compartment On Cabinet Frame
  • On Plate Lower Front Or Rear Of Cabinet
  • Beside Compressor Door On Right End
  • Near Rear Of Cabinet
  • Inside Liner At Top
Mar 28, 2009 | Refrigerators
Kenmore Refrig
It appears the defrost drain inside freezer is blocked or the drain tube leading to pan near compressor is clogged I would unplug refrigerator and remove the back panel in freezer to examine the drain and get back with me to let me know what you find, also get model number for your refrigerator so I can help you better. Sea Breeze Look at following areas for the model number
Mar 27, 2009 | Refrigerators
Ice in Refrigerator Section
there are 2 possibilities. first the drain is blocked causing water to overflow from the defrost water gulley at the bottom rear of the inside of the fridge. this can form ice as it is close to the division between fridge and freezer. second, the .fault of ice growth can be caused by breakdown of the cabinet insulation. of the two, the first is the moree likely. to test drain is cloear, pour a little water down the drain. if it does'nt flow freely, push something flexible down the drain hole till blockage is clear
Apr 14, 2007 | Sub-Zero 650 / O Bottom Freezer...
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
124 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
