Question about HHP Dolphin 7200
Dolphin 7200 Scanner won't power on
I have tried using the 3 keys to reset scanner, and have used the reset button to reset the scanner. Still does not power up.
  • 121 Answers
Try holding down 7 and 9 then power on + shft + bksp
simultaneously then release 7 + 9 first. Let me know how you get on.
Posted on Mar 21, 2010
Scanner error message
is your printer is detected in the device manager settings??
Mar 05, 2008 | HP LaserJet 3030 All-In-One Printer
Dolphin bluetooth won't pair with iPhone 5
Clear the memory on the Dolphin by pressing the CALL and END buttons together for about 5 seconds. The 'clearing memory' message will be heard followed by "Memory cleared".
now pair your phone using 0000 or 1234 as the pass key.
Feb 25, 2013 | Dolphin Radio Communications
Honeywell dolphin 6000 cold boot (hard reset)
Factory reset for Honeywell Dolphin 6000
With the pocket off press this combination of keys.
Up volume button, up cursor button, down cursor button and power button.
Then in a green window it will ask for reset all the dispositive by pressing the down cursor button or cancel the action by pressing any other key.
And thats the way of how to reset the Honeywell Dolphin 6000
Mar 15, 2012 | Computers & Internet
My pro 2018 was unplugged for a month or so and lost its memory,how do i reprogram,ive tried reset but i cant get it to take my freqs that i program in
  • After you reset the scanner you have to initialize it again.
  1. 1. Power the scanner off and on.
  2. 2. Press and hold the "TUNE/CLEAR" key and stick the end of a paperclip in the reset hole and hit the rest button.
  3. 3. Now remove the paperclip off the reset button and wait for the display to turn back on.
  4. 4. Now release the "TUNE/CLEAR" key.
  • The scanner is no initialized and ready to be programmed again.
  • Now program the scanner.
  1. 1. Press "PGM" key.
  2. 2. Now enter a channel you want to store a frequency.
  3. 3. Press "PGM" again.
  4. 4. Now you will be on that channel.
  5. 5. Now enter the frequency you want to program and don't forget the decimal.
  6. 6. Now press the "ENT" key.
  • Repeat steps to program more frequencies.
  • Hope this helps.
Nov 27, 2011 | Radio Shack Pro-2018 Scanner
I cant reprogram the scanner. It is only in channel 6
To restore normal operation, try RESETTING the scanner:
- Power the scanner OFF, then power it ON again.
- Insert a pointed object, just as the end of a paperclip, into the RESET opening on the side of the scanner, then push the small button inside the opening.
In many cases, the RESET will restore operation. If not, you'll need to perform the more drastic INITIALIZE process. NOTE: INITIALIZE will erase all information that you've programmed into the scanner and restore it to original factory settings. To INITIALIZE the scanner:
- While holding sown the TUNE/CLEAR key, press the RESET button as above. The scanner display should shut off.
- When the display turn on again, release the TUNE/CLEAR key.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
Bill B
May 22, 2010 | Radio Shack Pro-82 Scanner
Scanner will not move when turned on It will move if i force it.
If the scanner Fails it will give this message, Try the steps bellow to check if it can be cleared.
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector.
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing a test page or make a copy
If it still makes a loud noise and the message comes up as scanner failure, then either the scanner or the scanner machanisum is bad, you may have to replace the unit
Good Luck
Sep 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanner doesn't work
Sccaner open through screew driver & properly wash Logic board with ethiel alkohal. Plz properly check connection streep wire so connected with the warming lamp to logic board.
May 16, 2008 | Dolphin Computers & Internet
Pro=95 key pad does not work
Hi, Have you tried switching the key lock to OFF? This could be done by pressing FUNC (2nd button topmost) then keylock (leftmost bottom button), you will then hear KeyUnlocked confirmation of 3 beeps. A last effort is to try and reset the scanner done by powering off then on again, press on the recessed reset button inside a hole on the side of the scanner (try using a straightened paper clip). Hope this be of some idea/help. Post back how things turned up or should you need further information. Good luck and kind regards.
Sep 29, 2007 | Radio Shack Pro-95 Handheld Scanner
HHP Dolphin 7200 Logo
314 people viewed this question
Top HHP Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
